AirVPN Client stuck when trying to connect.
Hi everyone,
since a day or two I've been having this issue. When connecting to any server, with or without network lock, the AirVPN client gets stuck when connecting. See attached for the exact stuck position. I've also added the logs. The only way to then exit the client is to force quit it via the Apple menu.
OS X 10.11.5 | Eddie Version 2.10.3
Logs:
I 2016.05.28 13:51:21 - Session starting.
I 2016.05.28 13:51:21 - IPv6 disabled on network adapter (Wi-Fi)
I 2016.05.28 13:51:21 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2016.05.28 13:51:21 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2016.05.28 13:51:22 - Checking authorization ...
! 2016.05.28 13:51:22 - Connecting to Wezen (Germany, Frankfurt)
. 2016.05.28 13:51:22 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [SSL (OpenSSL)] [LZO] [MH] [IPv6] built on Aug 13 2015
. 2016.05.28 13:51:22 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.05.28 13:51:22 - Auto retry with another port.
. 2016.05.28 13:51:22 - OpenVPN > MANAGEMENT: Socket bind failed on local address [undef]: Address already in use
. 2016.05.28 13:51:22 - OpenVPN > Exiting due to fatal error
! 2016.05.28 13:51:22 - Disconnecting
. 2016.05.28 13:51:22 - Connection terminated.
I 2016.05.28 13:51:25 - Checking authorization ...
! 2016.05.28 13:51:25 - Connecting to Subra (Netherlands, Alblasserdam)
. 2016.05.28 13:51:25 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [SSL (OpenSSL)] [LZO] [MH] [IPv6] built on Aug 13 2015
. 2016.05.28 13:51:25 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.05.28 13:51:25 - OpenVPN > MANAGEMENT: TCP Socket listening on [undef]
. 2016.05.28 13:51:25 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.05.28 13:51:25 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.28 13:51:25 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.28 13:51:25 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2016.05.28 13:51:25 - OpenVPN > UDPv4 link local: [undef]
. 2016.05.28 13:51:25 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.98:443
. 2016.05.28 13:51:25 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.98:443, sid=779b8605 b123ecd3
. 2016.05.28 13:51:25 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.05.28 13:51:25 - OpenVPN > Validating certificate key usage
. 2016.05.28 13:51:25 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.05.28 13:51:25 - OpenVPN > VERIFY KU OK
. 2016.05.28 13:51:25 - OpenVPN > Validating certificate extended key usage
. 2016.05.28 13:51:26 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.05.28 13:51:26 - OpenVPN > VERIFY EKU OK
. 2016.05.28 13:51:26 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.05.28 13:51:28 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.05.28 13:51:28 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.28 13:51:28 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.05.28 13:51:28 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.05.28 13:51:28 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.05.28 13:51:28 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.98:443
. 2016.05.28 13:51:31 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.05.28 13:51:31 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.68.52 255.255.0.0'
. 2016.05.28 13:51:31 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2016.05.28 13:51:31 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.05.28 13:51:31 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.05.28 13:51:31 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.05.28 13:51:31 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.05.28 13:51:31 - OpenVPN > route: writing to routing socket: File exists
. 2016.05.28 13:51:31 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.05.28 13:51:31 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.05.28 13:51:31 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2016.05.28 13:51:31 - OpenVPN > Opened utun device utun1
. 2016.05.28 13:51:31 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.05.28 13:51:31 - OpenVPN > /sbin/ifconfig utun1 delete
. 2016.05.28 13:51:31 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2016.05.28 13:51:31 - OpenVPN > /sbin/ifconfig utun1 10.4.68.52 10.4.68.52 netmask 255.255.0.0 mtu 1500 up
. 2016.05.28 13:51:31 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.68.52 255.255.0.0
. 2016.05.28 13:51:31 - OpenVPN > add net 10.4.0.0: gateway 10.4.68.52: File exists
. 2016.05.28 13:51:31 - OpenVPN > /sbin/route add -net 213.152.162.98 192.168.1.1 255.255.255.255
. 2016.05.28 13:51:31 - OpenVPN > add net 213.152.162.98: gateway 192.168.1.1
. 2016.05.28 13:51:31 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2016.05.28 13:51:31 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1: File exists
. 2016.05.28 13:51:31 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2016.05.28 13:51:31 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1: File exists
. 2016.05.28 13:51:31 - Starting Management Interface
. 2016.05.28 13:51:31 - OpenVPN > Initialization Sequence Completed
. 2016.05.28 13:51:31 - OpenVPN > MANAGEMENT: Client connected from [undef]
Hello !
Did you actually solve this? If so, how?
There's a new experimental release if you'd like to try it.
