Anontor 5 Posted ... How to filter or not to filter applications and protocolls ? How can i choose what program should use AIR VPN and which ones should not ? By default it seems that AIR VPN do not run these through the VPN service: 1. Freenet, 2. TOR, 3. I2P Is this correct as they connect to the localhost ? Quote Share this post Link to post
Staff 10693 Posted ... How to filter or not to filter applications and protocolls ?How can i choose what program should use AIR VPN and which ones should not ?By default it seems that AIR VPN do not run these through the VPN service:1. Freenet, 2. TOR, 3. I2PIs this correct as they connect to the localhost ?Hello!By default the Air servers push routes in order to tunnel everything. Freenet, TOR and I2P are routed over AirVPN too, as long as they are run after the connection to an Air server. All the programs that were running before the connection will not be tunneled, because they are already using a socket/established a connection. Looking at your routing table after the connection can clarify.Examples: if you run TOR after you have connected to an Air server, you will have TOR over AirVPN for the programs configured to use TOR, all the other programs will be tunneled through AirVPN only. If you run TOR before the connection to Air, then you have two options: connecting directly to Air or connecting Air over TOR (please see https://airvpn.org/tor). In the first case, programs configured to be tunneled through TOR will use TOR only, all the other programs (launched after the connection to Air) will use AirVPN only. In the latter case, any and each program launched after the connection will be tunneled over AirVPN over TOR.Please do not hesitate to contact us for any further information or support.Kind regards Quote Share this post Link to post
