LZ1
AirVPN.exe Unknown Publisher
I'm new and happy to be a part of this great thing.
I just have 1 question and I tried looking around to no avail. I just wondered: why doesn't Eddie have "AirVPN" or something similar, as its "Publisher" when downloading the installer?
Isn't this normally bad practice and/or potentially insecure? I checked my hashes and all and I think I'm in the clear regardless. But is this intentional and if so, why?
Thank you
This requires to obtain a special "Code signing" certificate from a trusted Certificate Authority (CA).
While most trusted software packages want to have this kind of a signature for their installer
packages, the fact that AirVPN is providing a free, open-source client actually makes this a little
redundant.
Let me try to explain why.
The code signing certificates can be potentially issued to anyone claiming to have a brand. There
are many examples where a person can obtain a certificate for an entity he doesn't control, just for
example, if you now register a domain such as AirVPN.nl, and would like to have a code signing
certificate for this entity, you will most likely be granted to have it for something like ~$100/year.
So you have to check even signed executables very carefully, they don't mean anything except
that the publisher was partially verified by a CA. Just like you cannot trust a site with SSL green
"lock" not to be malicious, for the matter. This is only a small part of the bigger picture.
A Windows "code signing" certificate is relatively easy to obtain (unlike the Windows Driver
signing certificates that are much harder and require physical contact with Microsoft).
There are many examples of Adware programs that do have a code-signature, just to name
a few, anything you download from these shady "Registry/PC cleaning" websites will be signed,
usually by some east-European or Asian company, like one of the hundreds examples:
https://forums.malwarebytes.org/topic/165518-adware-digitally-signed/
What you have to do, if you want to maintain security, is to verify the hashes of the AirVPN client
you are downloading, and the hashes are available just near the download button, you can't miss it.
This will not only ensure that you download the trusted, unmodified installer, it will also mean that
every time you upgrade it you can still rely on the new hashes that are published by the authors.
The way software is distributed in other platforms, such as *nix, already have this imlementation
for years, and usually the package manager does the signature verification for you transparently.
This process ensures integrity on much higher levels than just checking the issuer brand/email.
So, to summarize, the code signing certificate only adds a cosmetic "trust", where the real trust should
be based on what you download, from which origin, and the best of course is - is this software really
open source and can be built on your own system, producing the same executable? (deterministic builds).
Thank you very much for that detailed explanation! That was excellent. I understand now.
CA's seem quite useless, when put like that. But isn't there some sort of danger of impersonation? Like, couldn't someone
else take AirVPNs brand name and start issuing malicious versions of their software, especially as the code for the software is open-source?
They can.
The higher danger is usually with bigger brands that have many distribution platforms.
For example, it is really hard for popular P2P or music apps to verify their integrity with
their potential users, since any *torrent client downloaded from some 3d party location
can be bundled with adware/malware, just like happened before with CNET and SourceForge.
AirVPN however has only 2 official locations, the SSL website and Github source tree.
This is why you have to download it only from https://airvpn.org/windows or from Github,
and then verify the hashes.
Any other builds should be considered untrusted.
I see.
Thank you very much :]
