Flo5701
Bug with OSX 10.11.3
I have some issues with the AirVPN Client on OSX, i can't strat a connection with automatic mode, i need use TCP unfortunatly after few moments, i loose the connection and i need restart.
If y use connection with tor it's work well.
I try Tunnelbrick and it's a same thing,  UDP doesn't work and TCP work for few moments. When a want disconnect tunnelblick tell me, openvpn  doesn't work.
Thank's for your time
Since you can connect in TCP it's not a client bug. Both the Air client and Tunnelblick are OpenVPN wrappers. It's OpenVPN that can't enter the VPN in UDP. Before anything else you should make sure that no packet filtering tool, either on your system or router, is interfering with UDP (and/or OpenVPN) packets.
If it's your ISP the culprit blocking UDP or anyway interfering with it, the only solutions are connections over TCP or changing ISP.
