illedan2 0 Posted ... Hello everyone, I have had a look on the forums and there are guides on how to set this up, but with Linux, Android or Windows and there is no guide for openwrt. I have looked at the guide on how to setup openvpn on openwrt which is very easy to follow but I dont know what to do next. The guide I have read can be found here https://airvpn.org/topic/15405-using-airvpn-with-openwrt/ Note I am using virtualbox with chaos calmer 15.05 with another VM (CentOS) so I can putty in to openwrt or use the gui (Luci). I decided to try this on a virtual machine before buying a router etc. Thanks. Quote Share this post Link to post
go558a83nk 389 Posted ... I think for openwrt you must install entware. Then you'll be able to install many common linux packages at the command line. this is the same as I have to do for merlin asus. Quote Share this post Link to post
illedan2 0 Posted ... I think for openwrt you must install entware. Then you'll be able to install many common linux packages at the command line. this is the same as I have to do for merlin asus.Thanks so once this is installed can I use AirVPN stunnel guide for Linux? I will have a read up on entware. Quote Share this post Link to post
go558a83nk 389 Posted ... I think for openwrt you must install entware. Then you'll be able to install many common linux packages at the command line. this is the same as I have to do for merlin asus.Thanks so once this is installed can I use AirVPN stunnel guide for Linux? I will have a read up on entware. I don't know. I never read the guide. Quote Share this post Link to post
zhang888 1067 Posted ... If you run it on x86 in any case, why not trying pfSense then?You will have to install many untested software if you go with OpenWRT. Don't get me wrong, it's a great project for almost any architecture, butfor x86 pfSense has no competitors for a routing+firewall solution. Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
illedan2 0 Posted ... If you run it on x86 in any case, why not trying pfSense then?You will have to install many untested software if you go with OpenWRT. Don't get me wrong, it's a great project for almost any architecture, butfor x86 pfSense has no competitors for a routing+firewall solution. Thanks I will have a look in to it. I have searched far and wide for stunnel setup and cant find anything that makes sense to me being a noob. There is a guide as well for pfsense on this forum so I will have a look at that. Thanks for taking your time to reply. Quote Share this post Link to post
ulmwind 6 Posted ... You can see my manual https://airvpn.org/topic/20303-airvpn-configuration-on-openwrt-preventing-traffic-leakage-outside-tunnel/ Quote Share this post Link to post
