urmel 0 Posted ... Every other server works. Only Furud isn´t working for me since some time. I always used Furud as preferred server. Here are the logs (time from logs ist CET / UTC+1): ! 2016.01.16 15:25:47 - Connecting to Furud (France, Villeneuve d'Ascq). 2016.01.16 15:25:47 - SSL > 2016.01.16 15:25:47 LOG5[ui]: stunnel 5.17 on x86-pc-mingw32-gnu platform. 2016.01.16 15:25:47 - SSL > 2016.01.16 15:25:47 LOG5[ui]: Compiled/running with OpenSSL 1.0.2a 19 Mar 2015. 2016.01.16 15:25:47 - SSL > 2016.01.16 15:25:47 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI. 2016.01.16 15:25:47 - SSL > 2016.01.16 15:25:47 LOG5[ui]: Reading configuration from file C:\xxx\xxx\\AppData\Local\AirVPN\48407a7fe0eef229816d8df45748879f483fdcb6ca4a1549736cc26944c54618.tmp.ssl. 2016.01.16 15:25:47 - SSL > 2016.01.16 15:25:47 LOG5[ui]: UTF-8 byte order mark not detected. 2016.01.16 15:25:47 - SSL > 2016.01.16 15:25:47 LOG6[ui]: Initializing service [openvpn]. 2016.01.16 15:25:47 - SSL > 2016.01.16 15:25:47 LOG5[ui]: Configuration successful. 2016.01.16 15:25:47 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.01.16 15:25:47 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.01.16 15:25:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.01.16 15:25:47 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.01.16 15:25:47 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.01.16 15:25:47 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.01.16 15:25:47 - OpenVPN > Socket Buffers: R=[8192->131072] S=[49152->131072]. 2016.01.16 15:25:47 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:52769 [nonblock]. 2016.01.16 15:25:47 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:52769. 2016.01.16 15:25:47 - OpenVPN > TCPv4_CLIENT link local: [undef]. 2016.01.16 15:25:47 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:52769. 2016.01.16 15:25:47 - SSL > 2016.01.16 15:25:47 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:1295. 2016.01.16 15:25:47 - SSL > 2016.01.16 15:25:47 LOG6[0]: Failover strategy: round-robin. 2016.01.16 15:25:47 - SSL > 2016.01.16 15:25:47 LOG6[0]: s_connect: connecting 46.29.125.15:443. 2016.01.16 15:25:57 - SSL > 2016.01.16 15:25:57 LOG3[0]: s_connect: s_poll_wait 46.29.125.15:443: TIMEOUTconnect exceeded. 2016.01.16 15:25:57 - SSL > 2016.01.16 15:25:57 LOG5[0]: Connection reset: 0 byte(s) sent to SSL, 0 byte(s) sent to socket. 2016.01.16 15:25:57 - OpenVPN > Connection reset, restarting [-1]. 2016.01.16 15:25:57 - OpenVPN > SIGUSR1[soft,connection-reset] received, process restarting. 2016.01.16 15:25:57 - OpenVPN > Restart pause, 5 second(s)! 2016.01.16 15:25:57 - Disconnecting Quote Share this post Link to post
Staff 10510 Posted ... Hello, problem confirmed, we are investigating. Kind regards Quote Share this post Link to post
avpnhome 3 Posted ... Still not working and no status update on the status page. In fact, it's connecting, but there's no traffic passing through. Regards. Quote Share this post Link to post
urmel 0 Posted ... Furud is still not working for me - no problems on other hosts. Any updates on time-to-repair on Furud? Quote Share this post Link to post
