Ernst89 11 Posted ... The BBC website is very, very slow from Naos. This doesn't happen from a non AirVPN IP address. IPlayer does work it just takes a long time to start. Quote Share this post Link to post
squ1bby 1 Posted ... The BBC website is very, very slow from Naos. This doesn't happen from a non AirVPN IP address. IPlayer does work it just takes a long time to start. Evening, Have noticed the same thing. BBC website very slow to load. The live text commentary on the sport pages also fails to load. Have tried accessing from UK and NL servers but get the same result. When I disconnect AirVPN and route normally via my ISP, everything on the BBC website loads fine. Currently connected to Alterf and seeing this issue. All other websites load normally. Only using the AirVPN DNS servers. Regards, S. Quote Share this post Link to post
cymba 0 Posted ... no access to any bbc site via any airvpn server, normal access and response to bbc.co.uk when not using airvpn Quote Share this post Link to post
Valerian 22 Posted ... The BBC websites have now gone from being extremely slow to not loading at all. No problem when not using AirVPN. Quote Share this post Link to post
fursday 3 Posted ... So I found a quick (and dubious) fix to get iPlayer working - Google Data Saver add-on (chrome only), which acts much like a proxy. Thanks go to whoever mentioned this on another thread in this section a while back. Manage to play videos connected to Naos at time of writing. So it appears that (at the very least) the host www.bbc.co.uk is being blocked by all of the UK servers at present. I've not dug deep enough to see if any of the myriad other bbc.co.uk and bbci.co.uk hosts iplayer uses are also affected or which ones google is relaying with this ad-on (I'm doubting the stream itself) but my guess is that it's using the google cache to deliver the main site which is blocked/throttled, which enables access to the unaffected video. Obviously from a privacy/anonymity/security perspective, I wouldn't advise using this add-on for normal browsing... Quote Share this post Link to post
squ1bby 1 Posted ... fursday, Just noticed that in the last hour or so the BBC website appears to be loading a lot quicker. However I also noticed that www.bbc.co.uk redirects to www.bbc.com (which it did when they had the outage last week). This redirect is happening outside of AirVPN so doesn't appear to be anything they've done. Are the BBC still having issues?? S. Quote Share this post Link to post
p9063806 0 Posted ... The BBC website has not been accessible today from Naos. Just checked Nunki and Carinae with the same result. All UK servers It loads OK on my iPhone with 4G in the UK Is there anything that can be done to resolve this? Kevin Quote Share this post Link to post
vangosh 3 Posted ... I'm still having spotty service since the site came back after the DDoS attacks. Does it work from any US servers? Quote Share this post Link to post
Wombat27 1 Posted ... Whatever was causing the problem seems to have been cleared up. Haven't had any problems today. Quote Share this post Link to post
nitehawk 4 Posted ... BBC iPlayer TV programmes are available to play in the UK only. Find out why.If you are in the UK and see this message please read this advice. on theSabik - United States all browsers not working giving same error , Edge , Firefox and Internet Explorer trying too watch On Now08:00 - 09:00Breakfast (BBC News Channel)10/01/2016 edit , and just like that a refresh has fixed it..though it dident fix it before i posted.. wow its very hit and miss but thanks Quote Share this post Link to post
polga 0 Posted ... Hi Brand new trial user from 30 mins ago My 'Tunnel bear' stopped working today and I could no longer access BBC player or website TV shows. Downloaded trial version of AIR VPN but no luck and No access. Usual message about "only access from UK" even though my location is showing as 'London' Is there likely to be a 'fix' for this or have BBC just outsmarted everyone.??? So much for 'Nation speaking unto nation' :-( thanks for any help Quote Share this post Link to post
Khariz 109 Posted ... Iplayer works just fine for me. How are you connecting to AirVPN? Are you using the Eddie client or OpenVPN? Quote Share this post Link to post
silvaticus 0 Posted ... iplayer also working just fine for me using Eddie Quote Share this post Link to post
Khariz 109 Posted ... Yeah, if you aren't using Eddie, you must. Eddie is capable of doing SmartDNS based geo-routing that you can't do with OpenVPN. In fact, if you ARE using Eddie, purposely do not connect to a UK server. Connect to Canada. It's amusing. Quote Share this post Link to post
Staff 10432 Posted ... Yeah, if you aren't using Eddie, you must. Eddie is capable of doing SmartDNS based geo-routing that you can't do with OpenVPN. In fact, if you ARE using Eddie, purposely do not connect to a UK server. Connect to Canada. It's amusing. Hello! That's not an Eddie feature. You just need to use our VPN DNS. Eddie takes care of that, just like other OpenVPN wrappers such as OpenVPN GUI, Tunnelblick... Of course, if you run OpenVPN under Linux or *BSD, and you don't take care about DNS push from the server, then your system would not query VPN DNS. Additional info here: https://airvpn.org/topic/9608-how-to-accept-dns-push-on-linux-systems-with-resolvconf Kind regards 1 Khariz reacted to this Quote Share this post Link to post
nitehawk 4 Posted ... trying too watch today and its super slow . my connection is good ..50/20 so no problems therelota of "failing too initialize"and lots of buffering..anyone else having issues todayIm in australia using heze right now .. its happened on 3 different servers now.usa servers and sweden serveralso happening on Hong Kong serverhttp://www.speedtest.net/result/5008922753.pnggood enough to stream Quote Share this post Link to post
Khariz 109 Posted ... Yeah, if you aren't using Eddie, you must. Eddie is capable of doing SmartDNS based geo-routing that you can't do with OpenVPN. In fact, if you ARE using Eddie, purposely do not connect to a UK server. Connect to Canada. It's amusing. Hello! That's not an Eddie feature. You just need to use our VPN DNS. Eddie takes care of that, just like other OpenVPN wrappers such as OpenVPN GUI, Tunnelblick... Of course, if you run OpenVPN under Linux or *BSD, and you don't take care about DNS push from the server, then your system would not query VPN DNS. Additional info here: https://airvpn.org/topic/9608-how-to-accept-dns-push-on-linux-systems-with-resolvconf Kind regardsOh, duh. I should have known that. The feature worked for me on my Mac with Tunnelblick. I guess that wouldn't have been possible if it was an Eddie feature. Sorry to add confusion to this issue. Quote Share this post Link to post
magnumpi 4 Posted ... Had been using Naos until yesterday my IP address from my Tomato router seems to have stopped showing in the UK and of course now iPlayer fails to play anything. It seems my 'client certificate' setting won't save. I cannot seem to get the VPN to start.... Quote Share this post Link to post
