tetsuia
Re: AirVPN over Tor not working
frIt doesn't work without tor as well.
This is a full log of OpenVPN when not using Tor; I'm now connecting through a local SSH tunnel but without any SOCKS proxy (I do not want to connect directly). This is the full log with raise verbosity.
4:28 *Tunnelblick: OS X 10.7.3; Tunnelblick 3.2.3 (build 2891.2932) Unsigned
4:28 *Tunnelblick: Attempting connection with AirVPN through local; Set nameserver = 1; monitoring connection
4:28 *Tunnelblick: /Applications/Tunnelblick.app/Contents/Resources/openvpnstart start AirVPN\ through\ local.tblk 1337 1 0 0 0 49 -atDASNGWrdasngw
4:29 *Tunnelblick: openvpnstart message: Loading tun.kext
4:29 us=279733 Current Parameter Settings:
4:29 us=280001 config = '/Users/XXXXXXX/Library/Application Support/Tunnelblick/Configurations/AirVPN through local.tblk/Contents/Resources/config.ovpn'
4:29 us=280016 mode = 0
4:29 us=280026 show_ciphers = DISABLED
4:29 us=280036 show_digests = DISABLED
4:29 us=280049 show_engines = DISABLED
4:29 us=280060 genkey = DISABLED
4:29 us=280070 key_pass_file = '[uNDEF]'
4:29 us=280079 show_tls_ciphers = DISABLED
4:29 us=280089 Connection profiles [default]:
4:29 us=280099 proto = tcp-client
4:29 us=280108 local = '[uNDEF]'
4:29 us=280118 local_port = 0
4:29 us=280127 remote = '127.0.0.1'
4:29 us=280137 remote_port = 1080
4:29 us=280146 remote_float = DISABLED
4:29 us=280155 bind_defined = DISABLED
4:29 us=280164 bind_local = DISABLED
4:29 us=280174 connect_retry_seconds = 5
4:29 us=280183 connect_timeout = 10
4:29 us=280193 connect_retry_max = 0
4:29 us=280202 socks_proxy_server = '[uNDEF]'
4:29 us=280212 socks_proxy_port = 0
4:29 us=280221 socks_proxy_retry = DISABLED
4:29 us=280230 Connection profiles END
4:29 us=280239 remote_random = DISABLED
4:29 us=280252 ipchange = '[uNDEF]'
4:29 us=280263 dev = 'tun'
4:29 us=280272 dev_type = '[uNDEF]'
4:29 us=280281 dev_node = '[uNDEF]'
4:29 us=280290 lladdr = '[uNDEF]'
4:29 us=280300 topology = 1
4:29 us=280309 tun_ipv6 = DISABLED
4:29 us=280318 ifconfig_local = '[uNDEF]'
4:29 us=280328 ifconfig_remote_netmask = '[uNDEF]'
4:29 us=280337 ifconfig_noexec = DISABLED
4:29 us=280346 ifconfig_nowarn = DISABLED
4:29 us=280356 shaper = 0
4:29 us=280365 tun_mtu = 1500
4:29 us=280374 tun_mtu_defined = ENABLED
4:29 us=280384 link_mtu = 1500
4:29 us=280393 link_mtu_defined = DISABLED
4:29 us=280402 tun_mtu_extra = 0
4:29 us=280412 tun_mtu_extra_defined = DISABLED
4:29 us=280421 fragment = 0
4:29 us=280431 mtu_discover_type = -1
4:29 us=280442 mtu_test = 0
4:29 us=280456 mlock = DISABLED
4:29 us=280465 keepalive_ping = 0
4:29 us=280475 keepalive_timeout = 0
4:29 us=280484 inactivity_timeout = 0
4:29 us=280493 ping_send_timeout = 0
4:29 us=280502 ping_rec_timeout = 0
4:29 us=280515 ping_rec_timeout_action = 0
4:29 us=280524 ping_timer_remote = DISABLED
4:29 us=280534 remap_sigusr1 = 0
4:29 us=280543 explicit_exit_notification = 0
4:29 us=280552 persist_tun = ENABLED
4:29 us=280561 persist_local_ip = DISABLED
4:29 us=280570 persist_remote_ip = DISABLED
4:29 us=280579 persist_key = ENABLED
4:29 us=280589 mssfix = 1450
4:29 us=280598 passtos = DISABLED
4:29 us=280607 resolve_retry_seconds = 1000000000
4:29 us=280616 username = '[uNDEF]'
4:29 us=280625 groupname = '[uNDEF]'
4:29 us=280635 chroot_dir = '[uNDEF]'
4:29 us=280644 cd_dir = '/Users/XXXXXXXXX/Library/Application Support/Tunnelblick/Configurations/AirVPN through local.tblk/Contents/Resources'
4:29 us=280669 writepid = '[uNDEF]'
4:29 us=280680 up_script = '/Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw'
4:29 us=280690 down_script = '/Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw'
4:29 us=280699 down_pre = DISABLED
4:29 us=280711 up_restart = ENABLED
4:29 us=280721 up_delay = DISABLED
4:29 us=280731 daemon = ENABLED
4:29 us=280740 inetd = 0
4:29 us=280750 log = ENABLED
4:29 us=280759 suppress_timestamps = DISABLED
4:29 us=280768 nice = 0
4:29 us=280778 verbosity = 5
4:29 us=280787 mute = 0
4:29 us=280796 gremlin = 0
4:29 us=280805 status_file = '[uNDEF]'
4:29 us=280815 status_file_version = 1
4:29 us=280824 status_file_update_freq = 60
4:29 us=280833 occ = ENABLED
4:29 us=280845 rcvbuf = 65536
4:29 us=280855 sndbuf = 65536
4:29 us=280865 sockflags = 0
4:29 us=280874 fast_io = DISABLED
4:29 us=280883 lzo = 7
4:29 us=280892 route_script = '[uNDEF]'
4:29 us=280902 route_default_gateway = '[uNDEF]'
4:29 us=280911 route_default_metric = 0
4:29 us=280921 route_noexec = DISABLED
4:29 us=280930 route_delay = 0
4:29 us=280939 route_delay_window = 30
4:29 us=280949 route_delay_defined = DISABLED
4:29 us=280958 route_nopull = DISABLED
4:29 us=280967 route_gateway_via_dhcp = DISABLED
4:29 us=280980 max_routes = 100
4:29 us=280991 allow_pull_fqdn = DISABLED
4:29 us=281001 management_addr = '127.0.0.1'
4:29 us=281010 management_port = 1337
4:29 us=281020 management_user_pass = '[uNDEF]'
4:29 us=281031 management_log_history_cache = 250
4:29 us=281041 management_echo_buffer_size = 100
4:29 us=281051 management_write_peer_info_file = '[uNDEF]'
4:29 us=281068 management_client_user = '[uNDEF]'
4:29 us=281080 management_client_group = '[uNDEF]'
4:29 us=281097 management_flags = 6
4:29 us=281112 shared_secret_file = '[uNDEF]'
4:29 us=281127 key_direction = 0
4:29 us=281142 ciphername_defined = ENABLED
4:29 us=281158 ciphername = 'AES-256-CBC'
4:29 us=281174 authname_defined = ENABLED
4:29 us=281190 authname = 'SHA1'
4:29 us=281208 prng_hash = 'SHA1'
4:29 us=281219 prng_nonce_secret_len = 16
4:29 us=281229 keysize = 0
4:29 us=281238 engine = DISABLED
4:29 us=281248 replay = ENABLED
4:29 us=281258 mute_replay_warnings = DISABLED
4:29 us=281268 replay_window = 64
4:29 us=281277 replay_time = 15
4:29 us=281287 packet_id_file = '[uNDEF]'
4:29 us=281296 use_iv = ENABLED
4:29 us=281310 test_crypto = DISABLED
4:29 us=281321 tls_server = DISABLED
4:29 us=281330 tls_client = ENABLED
4:29 us=281340 key_method = 2
4:29 us=281350 ca_file = 'ca.crt'
4:29 us=281377 ca_path = '[uNDEF]'
4:29 us=281388 dh_file = '[uNDEF]'
4:29 us=281398 cert_file = 'user.crt'
4:29 us=281411 priv_key_file = 'user.key'
4:29 us=281427 pkcs12_file = '[uNDEF]'
4:29 us=281445 cipher_list = '[uNDEF]'
4:29 us=281455 tls_verify = '[uNDEF]'
4:29 us=281478 tls_export_cert = '[uNDEF]'
4:29 us=281492 tls_remote = '[uNDEF]'
4:29 us=281507 crl_file = '[uNDEF]'
4:29 us=281558 ns_cert_type = 64
4:29 us=281583 remote_cert_ku = 0
4:29 us=281603 remote_cert_ku = 0
4:29 us=281617 remote_cert_ku = 0
4:29 us=281627 remote_cert_ku = 0
4:29 us=281637 remote_cert_ku = 0
4:29 us=281646 remote_cert_ku = 0
4:29 us=281657 remote_cert_ku = 0
4:29 us=281672 remote_cert_ku = 0
4:29 us=281687 remote_cert_ku = 0
4:29 us=281704 remote_cert_ku = 0
4:29 us=281721 remote_cert_ku = 0
4:29 us=281737 remote_cert_ku = 0
4:29 us=281752 remote_cert_ku = 0
4:29 us=281767 remote_cert_ku = 0
4:29 us=281777 remote_cert_ku = 0
4:29 us=281786 remote_cert_ku = 0
4:29 us=281796 remote_cert_eku = '[uNDEF]'
4:29 us=281806 tls_timeout = 2
4:29 us=281816 renegotiate_bytes = 0
4:29 us=281826 renegotiate_packets = 0
4:29 us=281836 renegotiate_seconds = 3600
4:29 us=281846 handshake_window = 60
4:29 us=281855 transition_window = 3600
4:29 us=281865 single_session = DISABLED
4:29 us=281875 push_peer_info = DISABLED
4:29 us=281884 tls_exit = DISABLED
4:29 us=281894 tls_auth_file = '[uNDEF]'
4:29 us=281904 pkcs11_protected_authentication = DISABLED
4:29 us=281915 pkcs11_protected_authentication = DISABLED
4:29 us=281924 pkcs11_protected_authentication = DISABLED
4:29 us=281934 pkcs11_protected_authentication = DISABLED
4:29 us=281944 pkcs11_protected_authentication = DISABLED
4:29 us=281954 pkcs11_protected_authentication = DISABLED
4:29 us=281964 pkcs11_protected_authentication = DISABLED
4:29 us=281973 pkcs11_protected_authentication = DISABLED
4:29 us=281983 pkcs11_protected_authentication = DISABLED
4:29 us=281993 pkcs11_protected_authentication = DISABLED
4:29 us=282003 pkcs11_protected_authentication = DISABLED
4:29 us=282012 pkcs11_protected_authentication = DISABLED
4:29 us=282022 pkcs11_protected_authentication = DISABLED
4:29 us=282032 pkcs11_protected_authentication = DISABLED
4:29 us=282041 pkcs11_protected_authentication = DISABLED
4:29 us=282051 pkcs11_protected_authentication = DISABLED
4:29 us=282061 pkcs11_private_mode = 00000000
4:29 us=282071 pkcs11_private_mode = 00000000
4:29 us=282081 pkcs11_private_mode = 00000000
4:29 us=282091 pkcs11_private_mode = 00000000
4:29 us=282101 pkcs11_private_mode = 00000000
4:29 us=282111 pkcs11_private_mode = 00000000
4:29 us=282120 pkcs11_private_mode = 00000000
4:29 us=282130 pkcs11_private_mode = 00000000
4:29 us=282161 pkcs11_private_mode = 00000000
4:29 us=282172 pkcs11_private_mode = 00000000
4:29 us=282182 pkcs11_private_mode = 00000000
4:29 us=282192 pkcs11_private_mode = 00000000
4:29 us=282202 pkcs11_private_mode = 00000000
4:29 us=282211 pkcs11_private_mode = 00000000
4:29 us=282221 pkcs11_private_mode = 00000000
4:29 us=282231 pkcs11_private_mode = 00000000
4:29 us=282241 pkcs11_cert_private = DISABLED
4:29 us=282251 pkcs11_cert_private = DISABLED
4:29 us=282261 pkcs11_cert_private = DISABLED
4:29 us=282270 pkcs11_cert_private = DISABLED
4:29 us=282280 pkcs11_cert_private = DISABLED
4:29 us=282289 pkcs11_cert_private = DISABLED
4:29 us=282299 pkcs11_cert_private = DISABLED
4:29 us=282308 pkcs11_cert_private = DISABLED
4:29 us=282318 pkcs11_cert_private = DISABLED
4:29 us=282328 pkcs11_cert_private = DISABLED
4:29 us=282337 pkcs11_cert_private = DISABLED
4:29 us=282347 pkcs11_cert_private = DISABLED
4:29 us=282356 pkcs11_cert_private = DISABLED
4:29 us=282366 pkcs11_cert_private = DISABLED
4:29 us=282376 pkcs11_cert_private = DISABLED
4:29 us=282385 pkcs11_cert_private = DISABLED
4:29 us=282395 pkcs11_pin_cache_period = -1
4:29 us=282405 pkcs11_id = '[uNDEF]'
4:29 us=282415 pkcs11_id_management = DISABLED
4:29 us=282456 server_network = 0.0.0.0
4:29 us=282470 server_netmask = 0.0.0.0
4:29 us=282481 server_bridge_ip = 0.0.0.0
4:29 us=282492 server_bridge_netmask = 0.0.0.0
4:29 us=282503 server_bridge_pool_start = 0.0.0.0
4:29 us=282514 server_bridge_pool_end = 0.0.0.0
4:29 us=282524 ifconfig_pool_defined = DISABLED
4:29 us=282535 ifconfig_pool_start = 0.0.0.0
4:29 us=282546 ifconfig_pool_end = 0.0.0.0
4:29 us=282556 ifconfig_pool_netmask = 0.0.0.0
4:29 us=282566 ifconfig_pool_persist_filename = '[uNDEF]'
4:29 us=282577 ifconfig_pool_persist_refresh_freq = 600
4:29 us=282587 n_bcast_buf = 256
4:29 us=282596 tcp_queue_limit = 64
4:29 us=282606 real_hash_size = 256
4:29 us=282616 virtual_hash_size = 256
4:29 us=282625 client_connect_script = '[uNDEF]'
4:29 us=282635 learn_address_script = '[uNDEF]'
4:29 us=282646 client_disconnect_script = '[uNDEF]'
4:29 us=282655 client_config_dir = '[uNDEF]'
4:29 us=282665 ccd_exclusive = DISABLED
4:29 us=282675 tmp_dir = '/var/folders/ry/gsscm_nj73vg4vx9wyg2gwm00000gn/T/'
4:29 us=282685 push_ifconfig_defined = DISABLED
4:29 us=282696 push_ifconfig_local = 0.0.0.0
4:29 us=282707 push_ifconfig_remote_netmask = 0.0.0.0
4:29 us=282716 enable_c2c = DISABLED
4:29 us=282726 duplicate_cn = DISABLED
4:29 us=282736 cf_max = 0
4:29 us=282746 cf_per = 0
4:29 us=282755 max_clients = 1024
4:29 us=282765 max_routes_per_client = 256
4:29 us=282775 auth_user_pass_verify_script = '[uNDEF]'
4:29 us=282784 auth_user_pass_verify_script_via_file = DISABLED
4:29 us=282794 ssl_flags = 0
4:29 us=282819 port_share_host = '[uNDEF]'
4:29 us=282830 port_share_port = 0
4:29 us=282839 client = ENABLED
4:29 us=282849 pull = ENABLED
4:29 us=282859 auth_user_pass_file = '[uNDEF]'
4:29 us=282874 OpenVPN 2.2.1 i386-apple-darwin10.8.0 [sSL] [LZO2] [PKCS11] [eurephia] built on Jan 8 2012
4:29 us=283011 MANAGEMENT: TCP Socket listening on 127.0.0.1:1337
4:29 us=284958 Need hold release from management interface, waiting...
4:29 us=402511 MANAGEMENT: Client connected from 127.0.0.1:1337
4:29 us=417655 MANAGEMENT: CMD 'pid'
4:29 us=417976 MANAGEMENT: CMD 'state on'
4:29 us=418171 MANAGEMENT: CMD 'state'
4:29 us=418422 MANAGEMENT: CMD 'hold release'
4:29 *Tunnelblick: openvpnstart: /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.2.1/openvpn --cd /Users/XXXXXXXXX/Library/Application Support/Tunnelblick/Configurations/AirVPN through local.tblk/Contents/Resources --daemon --management 127.0.0.1 1337 --config /Users/XXXXXXXXX/Library/Application Support/Tunnelblick/Configurations/AirVPN through local.tblk/Contents/Resources/config.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SUsers-SXXXXXXXXX-SLibrary-SApplication Support-STunnelblick-SConfigurations-SAirVPN through local.tblk-SContents-SResources-Sconfig.ovpn.1_0_0_0_49.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw --down /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw --up-restart
4:29 *Tunnelblick: Established communication with OpenVPN
4:29 us=419386 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
4:29 us=429159 WARNING: file 'user.key' is group or others accessible
4:29 us=436462 LZO compression initialized
4:29 us=437655 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
4:29 us=437880 Socket Buffers: R=[65536->65536] S=[65536->65536]
4:29 us=438036 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
4:29 us=438202 Local Options String: 'V4,dev-type tun,link-mtu 1560,tun-mtu 1500,proto TCPv4_CLIENT,comp-lzo,cipher AES-256-CBC,auth SHA1,keysize 256,key-method 2,tls-client'
4:29 us=438341 Expected Remote Options String: 'V4,dev-type tun,link-mtu 1560,tun-mtu 1500,proto TCPv4_SERVER,comp-lzo,cipher AES-256-CBC,auth SHA1,keysize 256,key-method 2,tls-server'
4:29 us=438513 Local Options hash (VER=V4): '958c5492'
4:29 us=438746 Expected Remote Options hash (VER=V4): '79ef4284'
4:29 us=438907 Attempting to establish TCP connection with 127.0.0.1:1080 [nonblock]
4:29 us=439057 MANAGEMENT: >STATE:1329785069,TCP_CONNECT,,,
4:30 us=439295 TCP connection established with 127.0.0.1:1080
4:30 us=439535 TCPv4_CLIENT link local: [undef]
4:30 us=439693 TCPv4_CLIENT link remote: 127.0.0.1:1080
4:30 us=439885 MANAGEMENT: >STATE:1329785070,WAIT,,,
RTue Feb 21 01:44:30 2012 us=533152 MANAGEMENT: >STATE:1329785070,AUTH,,,
4:30 us=533343 TLS: Initial packet from 127.0.0.1:1080, sid=11f42577 de3963e4
RRTue Feb 21 01:44:31 2012 us=715231 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
4:31 us=718758 VERIFY OK: nsCertType=SERVER
4:31 us=718978 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
RRRRRRTue Feb 21 01:44:34 2012 us=224998 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
4:34 us=225161 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
4:34 us=225271 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
4:34 us=225363 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
WWTue Feb 21 01:44:34 2012 us=225531 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
4:34 us=225729 [server] Peer Connection Initiated with 127.0.0.1:1080
4:35 us=229915 MANAGEMENT: >STATE:1329785075,GET_CONFIG,,,
4:36 us=235742 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
RRRTue Feb 21 01:44:36 2012 us=372441 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.5.0.1,comp-lzo no,route 10.5.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.5.0.102 10.5.0.101'
4:36 us=373035 OPTIONS IMPORT: timers and/or timeouts modified
4:36 us=373307 OPTIONS IMPORT: LZO parms modified
4:36 us=373525 OPTIONS IMPORT: --ifconfig/up options modified
4:36 us=373650 OPTIONS IMPORT: route options modified
4:36 us=373800 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
4:36 us=374121 ROUTE default_gateway=192.168.0.1
4:36 us=374595 TUN/TAP device /dev/tun0 opened
4:36 us=374858 MANAGEMENT: >STATE:1329785076,ASSIGN_IP,,10.5.0.102,
4:36 us=375155 /sbin/ifconfig tun0 delete
ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
4:36 us=383427 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
4:36 us=383769 /sbin/ifconfig tun0 10.5.0.102 10.5.0.101 mtu 1500 netmask 255.255.255.255 up
4:36 us=387602 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1560 10.5.0.102 10.5.0.101 init
4:38 *Tunnelblick client.up.tunnelblick.sh: Retrieved name server(s) [ 10.5.0.1 ] and WINS server(s) [ ] and using default domain name [ openvpn ]
4:38 *Tunnelblick client.up.tunnelblick.sh: Up to two 'No such key' warnings are normal and may be ignored
4:38 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and WINS configurations for later use
4:38 *Tunnelblick client.up.tunnelblick.sh: Set up to monitor system configuration with process-network-changes
4:38 *Tunnelblick: Flushed the DNS cache
4:38 us=709800 /sbin/route add -net 127.0.0.1 192.168.0.1 255.255.255.255
add net 127.0.0.1: gateway 192.168.0.1
4:38 us=721447 /sbin/route add -net 0.0.0.0 10.5.0.101 128.0.0.0
add net 0.0.0.0: gateway 10.5.0.101
4:38 us=727457 /sbin/route add -net 128.0.0.0 10.5.0.101 128.0.0.0
add net 128.0.0.0: gateway 10.5.0.101
4:38 us=734494 MANAGEMENT: >STATE:1329785078,ADD_ROUTES,,,
4:38 us=734969 /sbin/route add -net 10.5.0.1 10.5.0.101 255.255.255.255
add net 10.5.0.1: gateway 10.5.0.101
4:38 us=742660 Initialization Sequence Completed
4:38 us=742970 MANAGEMENT: >STATE:1329785078,CONNECTED,SUCCESS,10.5.0.102,127.0.0.1
5:14 *Tunnelblick process-network-changes: A system configuration change was ignored because it was not relevant
6:28 us=817698 Connection reset, restarting [0]
6:28 us=818722 TCP/UDP: Closing socket
6:28 us=819132 /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1560 10.5.0.102 10.5.0.101 restart
6:28 *Tunnelblick client.down.tunnelblick.sh: Cancelled monitoring of system configuration changes
6:28 *Tunnelblick client.down.tunnelblick.sh: Restored the DNS and WINS configurations
6:28 us=974524 SIGUSR1[soft,connection-reset] received, process restarting
6:28 us=974826 MANAGEMENT: >STATE:1329785188,RECONNECTING,connection-reset,,
6:28 us=989486 MANAGEMENT: CMD 'hold release'
6:28 us=989765 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
6:28 us=989982 Re-using SSL/TLS context
6:28 us=990172 LZO compression initialized
6:28 us=990474 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
6:28 us=990694 Socket Buffers: R=[65536->65536] S=[65536->65536]
6:28 us=990875 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
6:28 us=991075 Local Options String: 'V4,dev-type tun,link-mtu 1560,tun-mtu 1500,proto TCPv4_CLIENT,comp-lzo,cipher AES-256-CBC,auth SHA1,keysize 256,key-method 2,tls-client'
6:28 us=991261 Expected Remote Options String: 'V4,dev-type tun,link-mtu 1560,tun-mtu 1500,proto TCPv4_SERVER,comp-lzo,cipher AES-256-CBC,auth SHA1,keysize 256,key-method 2,tls-server'
6:28 us=991442 Local Options hash (VER=V4): '958c5492'
6:28 us=991609 Expected Remote Options hash (VER=V4): '79ef4284'
6:28 us=991795 Attempting to establish TCP connection with 127.0.0.1:1080 [nonblock]
6:28 us=991958 MANAGEMENT: >STATE:1329785188,TCP_CONNECT,,,
6:29 us=992351 TCP: connect to 127.0.0.1:1080 failed, will try again in 5 seconds: Connection refused
6:34 us=993889 MANAGEMENT: >STATE:1329785194,TCP_CONNECT,,,
6:35 us=994630 TCP: connect to 127.0.0.1:1080 failed, will try again in 5 seconds: Connection refused
6:37 us=918698 /sbin/route delete -net 10.5.0.1 10.5.0.101 255.255.255.255
delete net 10.5.0.1: gateway 10.5.0.101
6:37 us=923439 /sbin/route delete -net 127.0.0.1 192.168.0.1 255.255.255.255
delete net 127.0.0.1: gateway 192.168.0.1
6:37 us=927636 /sbin/route delete -net 0.0.0.0 10.5.0.101 128.0.0.0
delete net 0.0.0.0: gateway 10.5.0.101
6:37 us=929945 /sbin/route delete -net 128.0.0.0 10.5.0.101 128.0.0.0
delete net 128.0.0.0: gateway 10.5.0.101
6:37 us=931967 Closing TUN/TAP interface
6:37 us=932515 /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1560 10.5.0.102 10.5.0.101 init
6:38 *Tunnelblick client.down.tunnelblick.sh: WARNING: No existing OpenVPN DNS configuration found; not tearing down anything; exiting.
6:38 us=958320 SIGTERM[hard,init_instance] received, process exiting
6:38 us=958591 MANAGEMENT: >STATE:1329785198,EXITING,init_instance,,
6:39 *Tunnelblick: Flushed the DNS cache
[EDIT] Please note that the account "tetsuia" is not authorized to access the VPN servers, as it is not subscribed to any plan. If you are trying to connect with the key of that account, this is the reason for which the connection fails. Ignore this message if you're trying to connect with a premium account.
About the first part of the log, please see this known issue (from the Tunnelblick wiki http://code.google.com/p/tunnelblick/wiki/cKnown) and uncheck "Monitor connection" to see whether it solves the problem.
If "Monitor connection" is checked, Tunnelblick monitors the network interface that connects to the VPN and will restart the connection if changes to DNS or WINS are detected. With some network configurations this causes repeated disconnects/reconnects every few seconds. To avoid this, uncheck "Monitor connection" for the problematic configuration on the "VPN Details…" window. Please post your complete log (showing the problem with "Monitor connection" checked) to the Tunnelblick Discussion Group so we can fix this problem. (Be sure to cross out any sensitive information such as server IP addresses before you post your log.)
In the second part, though, there seems to be a problem with 127.0.0.1:1080 (see 6:29 [...] Connection refused [...]), was your local tunnel active? The first disconnection might have been caused by your 'SSH tunnel' going down, not by a Tunnelblick fault.
We're looking forward to hearing from you.
