tetsuia
AirVPN over Tor not working
Hi, I'm trying to create a AirVPN over Tor tunnel. I'm on OSX, using TunnelBlick and TorBrowserBundle.
OpenVPN connects correctly and estabilishes the tunnel using the socks proxy. But afterwards, I cannot route any packet.
This is how Tunnelblick modifies the routing table in response to redirect-gateway def1:
us=335050 /sbin/route add -net 127.0.0.1 192.168.0.1 255.255.255.255
add net 127.0.0.1: gateway 192.168.0.1
us=341745 /sbin/route add -net 0.0.0.0 10.5.0.101 128.0.0.0
add net 0.0.0.0: gateway 10.5.0.101
us=344827 /sbin/route add -net 128.0.0.0 10.5.0.101 128.0.0.0
add net 128.0.0.0: gateway 10.5.0.101
us=351491 /sbin/route add -net 10.5.0.1 10.5.0.101 255.255.255.255
add net 10.5.0.1: gateway 10.5.0.101
This is the routing table:
Internet:
Destination Gateway Flags Refs Use Netif Expire
0/1 10.5.0.101 UGSc 1 0 tun0
default 192.168.0.1 UGSc 78 0 en0
10.5.0.1/32 10.5.0.101 UGSc 1 0 tun0
10.5.0.101 10.5.0.102 UH 5 0 tun0
127 127.0.0.1 UCS 0 0 lo0
127.0.0.1 127.0.0.1 UH 17 413810 lo0
127.0.0.1/32 192.168.0.1 UGSc 0 0 en0
128.0/1 10.5.0.101 UGSc 0 0 tun0
169.254 link#4 UCS 0 0 en0
Looks legit to me, and works for other OpenVPN-based VPNs. If I attach tcpdump to tun0, I only see packets going out, but nothing coming back to me.
How can I further debug this?
@tetsuia
When you connect without TOR, is everything ok?
Can you please send us the connection logs both with and without socks proxy?
