Not connected, Your IP: 216.73.216.190
voltaire
Connection trouble in some location
I got difficulty to connect from from home, everywhere else it work perfectly. At home I can connect to other vpn (also on openvpn) and they work perfectly.
Strangely the only thing that I can acces from home if I'm connected with airvpn is www.wikipedia.org (just the welcome page) and nothing else. As if the DNS was not working properly... But if I try to ping from the console the dns resolution is working as expected.
2012-02-08 19:57:49 *Tunnelblick: OS X 10.6.8; Tunnelblick 3.2.3 (build 2891.2932)
2012-02-08 19:57:49 *Tunnelblick: Attempting connection with air; Set nameserver = 9; monitoring connection
2012-02-08 19:57:49 *Tunnelblick: /Applications/Tunnelblick.app/Contents/Resources/openvpnstart start air.ovpn 1337 9 0 0 0 51 -atDASNGWrdasngw
2012-02-08 19:57:49 *Tunnelblick: openvpnstart message: Loading tap.kext
Loading tun.kext
2012-02-08 19:57:49 *Tunnelblick: Established communication with OpenVPN
2012-02-08 19:57:49 OpenVPN 2.2.1 i386-apple-darwin10.8.0 [sSL] [LZO2] [PKCS11] [eurephia] built on Jan 8 2012
2012-02-08 19:57:49 MANAGEMENT: TCP Socket listening on 127.0.0.1:1337
2012-02-08 19:57:49 Need hold release from management interface, waiting...
2012-02-08 19:57:49 MANAGEMENT: Client connected from 127.0.0.1:1337
2012-02-08 19:57:49 MANAGEMENT: CMD 'pid'
2012-02-08 19:57:49 MANAGEMENT: CMD 'state on'
2012-02-08 19:57:49 MANAGEMENT: CMD 'state'
2012-02-08 19:57:49 MANAGEMENT: CMD 'hold release'
2012-02-08 19:57:49 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2012-02-08 19:57:49 WARNING: file 'user.key' is group or others accessible
2012-02-08 19:57:49 LZO compression initialized
2012-02-08 19:57:49 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2012-02-08 19:57:49 Socket Buffers: R=[42080->65536] S=[9216->65536]
2012-02-08 19:57:49 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2012-02-08 19:57:49 Local Options hash (VER=V4): '22188c5b'
2012-02-08 19:57:49 Expected Remote Options hash (VER=V4): 'a8f55717'
2012-02-08 19:57:49 UDPv4 link local: [undef]
2012-02-08 19:57:49 UDPv4 link remote: 69.163.36.66:443
2012-02-08 19:57:49 MANAGEMENT: >STATE:1328749069,WAIT,,,
2012-02-08 19:57:49 MANAGEMENT: >STATE:1328749069,AUTH,,,
2012-02-08 19:57:49 TLS: Initial packet from 69.163.36.66:443, sid=ff2917ef 7befcf4b
2012-02-08 19:57:49 *Tunnelblick: openvpnstart: /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.2.1/openvpn --cd /Users/guillaumelheureux/Library/Application Support/Tunnelblick/Configurations --daemon --management 127.0.0.1 1337 --config /Users/guillaumelheureux/Library/Application Support/Tunnelblick/Configurations/air.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SUsers-Sguillaumelheureux-SLibrary-SApplication Support-STunnelblick-SConfigurations-Sair.ovpn.9_0_0_0_51.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Tunnelblick.app/Contents/Resources/client.2.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw --down /Applications/Tunnelblick.app/Contents/Resources/client.2.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw --up-restart
2012-02-08 19:57:50 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2012-02-08 19:57:50 VERIFY OK: nsCertType=SERVER
2012-02-08 19:57:50 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2012-02-08 19:57:56 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2012-02-08 19:57:56 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2012-02-08 19:57:56 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2012-02-08 19:57:56 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2012-02-08 19:57:56 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2012-02-08 19:57:56 [server] Peer Connection Initiated with 69.163.36.66:443
2012-02-08 19:57:58 MANAGEMENT: >STATE:1328749078,GET_CONFIG,,,
2012-02-08 19:57:59 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2012-02-08 19:57:59 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.4.5.74 10.4.5.73'
2012-02-08 19:57:59 OPTIONS IMPORT: timers and/or timeouts modified
2012-02-08 19:57:59 OPTIONS IMPORT: LZO parms modified
2012-02-08 19:57:59 OPTIONS IMPORT: --ifconfig/up options modified
2012-02-08 19:57:59 OPTIONS IMPORT: route options modified
2012-02-08 19:57:59 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2012-02-08 19:57:59 ROUTE default_gateway=192.168.64.253
2012-02-08 19:57:59 TUN/TAP device /dev/tun0 opened
2012-02-08 19:57:59 MANAGEMENT: >STATE:1328749079,ASSIGN_IP,,10.4.5.74,
2012-02-08 19:57:59 /sbin/ifconfig tun0 delete
ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
2012-02-08 19:57:59 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
2012-02-08 19:57:59 /sbin/ifconfig tun0 10.4.5.74 10.4.5.73 mtu 1500 netmask 255.255.255.255 up
2012-02-08 19:57:59 /Applications/Tunnelblick.app/Contents/Resources/client.2.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.5.74 10.4.5.73 init
2012-02-08 19:57:59 *Tunnelblick: Flushed the DNS cache
2012-02-08 19:57:59 /sbin/route add -net 69.163.36.66 192.168.64.253 255.255.255.255
add net 69.163.36.66: gateway 192.168.64.253
2012-02-08 19:57:59 /sbin/route add -net 0.0.0.0 10.4.5.73 128.0.0.0
add net 0.0.0.0: gateway 10.4.5.73
2012-02-08 19:57:59 /sbin/route add -net 128.0.0.0 10.4.5.73 128.0.0.0
add net 128.0.0.0: gateway 10.4.5.73
2012-02-08 19:57:59 MANAGEMENT: >STATE:1328749079,ADD_ROUTES,,,
2012-02-08 19:57:59 /sbin/route add -net 10.4.0.1 10.4.5.73 255.255.255.255
add net 10.4.0.1: gateway 10.4.5.73
2012-02-08 19:57:59 Initialization Sequence Completed
2012-02-08 19:57:59 MANAGEMENT: >STATE:1328749079,CONNECTED,SUCCESS,10.4.5.74,69.163.36.66
Your logs look ok. Since everywhere else the connection is fine, it is possible that there's something in your home line which is the issue.
First of all, try to connect to a different server and to a TCP port (for example 80 TCP) in order to ascertain whether it's a line (quality, latency...) issue with Vega. Also, check your browser settings. Test also some other protocol (for example FTP, bittorrent) to determine if the issue lies in the browser.
We're looking forward to hearing from you.
Bitttorrent was working with each configuration that I tried. I didn't try ftp.
With vegas on port 80 tcp it everything work perfectly!
Thank's
Thank's
Very well! Probably you will be able to establish successfully a connection on any server just using port 80 TCP.
