cblmbxz 0 Posted ... Having difficulty connecting to airvpn using Lion. tried vega, sirius, and lyra and no luck 2012-02-07 21:00:26 *Tunnelblick: OS X 10.7.2; Tunnelblick 3.2.3 (build 2891.2932) 2012-02-07 21:00:32 *Tunnelblick: Attempting connection with air; Set nameserver = 1; monitoring connection 2012-02-07 21:00:32 *Tunnelblick: /Applications/Tunnelblick.app/Contents/Resources/openvpnstart start air.ovpn 1337 1 0 0 0 49 -atDASNGWrdasngw 2012-02-07 21:00:32 OpenVPN 2.2.1 i386-apple-darwin10.8.0 [sSL] [LZO2] [PKCS11] [eurephia] built on Jan 8 2012 2012-02-07 21:00:32 MANAGEMENT: TCP Socket listening on 127.0.0.1:1337 2012-02-07 21:00:32 Need hold release from management interface, waiting... 2012-02-07 21:00:32 *Tunnelblick: openvpnstart: /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.2.1/openvpn --cd /Users/wjnkdfg/Library/Application Support/Tunnelblick/Configurations --daemon --management 127.0.0.1 1337 --config /Users/wjnkdfg/Library/Application Support/Tunnelblick/Configurations/air.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SUsers-Smwin-SLibrary-SApplication Support-STunnelblick-SConfigurations-Sair.ovpn.1_0_0_0_49.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw --down /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw --up-restart 2012-02-07 21:00:33 *Tunnelblick: openvpnstart message: Loading tun.kext 2012-02-07 21:00:33 *Tunnelblick: Established communication with OpenVPN 2012-02-07 21:00:33 MANAGEMENT: Client connected from 127.0.0.1:1337 2012-02-07 21:00:33 MANAGEMENT: CMD 'pid' 2012-02-07 21:00:33 MANAGEMENT: CMD 'state on' 2012-02-07 21:00:33 MANAGEMENT: CMD 'state' 2012-02-07 21:00:33 MANAGEMENT: CMD 'hold release' 2012-02-07 21:00:33 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts 2012-02-07 21:00:33 WARNING: file 'user.key' is group or others accessible 2012-02-07 21:00:33 LZO compression initialized 2012-02-07 21:00:33 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ] 2012-02-07 21:00:33 Socket Buffers: R=[65536->65536] S=[65536->65536] 2012-02-07 21:00:33 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ] 2012-02-07 21:00:33 Local Options hash (VER=V4): '958c5492' 2012-02-07 21:00:33 Expected Remote Options hash (VER=V4): '79ef4284' 2012-02-07 21:00:33 Attempting to establish TCP connection with 127.0.0.1:8080 [nonblock] 2012-02-07 21:00:33 MANAGEMENT: >STATE:1328666433,TCP_CONNECT,,, 2012-02-07 21:00:34 TCP: connect to 127.0.0.1:8080 failed, will try again in 5 seconds: Connection refused 2012-02-07 21:00:39 MANAGEMENT: >STATE:1328666439,TCP_CONNECT,,, 2012-02-07 21:00:40 TCP: connect to 127.0.0.1:8080 failed, will try again in 5 seconds: Connection refused 2012-02-07 21:00:44 *Tunnelblick: Flushed the DNS cache 2012-02-07 21:00:44 SIGTERM[hard,init_instance] received, process exiting 2012-02-07 21:00:44 MANAGEMENT: >STATE:1328666444,EXITING,init_instance,, Quote Share this post Link to post
Staff 10208 Posted ... @climbxz Hello! From the logs it appears that the problem is on your local proxy 127.0.0.1:8080 which refuses connections. What proxy is it? Can you please check that it is running and accepting connections? Did you configure properly OpenVPN to connect over a proxy? Also, you might test a direct connection to our VPN servers without a proxy. Feel free to send us your air.ovpn configuration file. We're looking forward to hearing from you. Kind regards Quote Share this post Link to post
