JavaJoeUK
ANSWERED eddie -cli not executing script on vpn.up
Hi I have eddie installed on a headless Ubuntu 14.04 server and I cant get it to start my script, I dont know if its the script which is wrong or the the way I am calling it. I am new to all this.
The session starts ok but the service does not start. The service starts and stops ok outside of the script.
Thanks for the help in advance
sudo airvpn -cli login=XXXX password=xxx remember=true server=alrai connect=true event.vpn.up.filename = home/mylaptop/.airvpn/start-deluged event.vpn.down.filename = home/mylaptop/.airvpn/stop-deluged
The start/stop scripts are owned by root and are executable
#!/bin/sh
#start deluged whith vpn up
service deluged start
!/bin/bash
#stop deluged when vpn goes down
service deluged stop
that's a known bug affecting Eddie 2.8.8 and older versions, fixed in 2.9.2 and 2.10.1 Experimental, therefore you probably need to upgrade.
https://airvpn.org/services/changelog.php?software=client&format=html
You also need to fix the syntax of your command invoking the Air client, all the options start with a "-" symbol.
https://airvpn.org/topic/11541-command-line-edition-and-syntax
Hi I changed the command line to include '-' and upgraded to 2.9.2 for ubuntu but the scripts are still not running.
I could not get eddie to run my scripts at all but did mange using openvpn. It would not work if it was in the '.conf' file.
I also had problems updating resolvconf which the script fixed.
This is advice for anyone else that might find the same problem.
openvpn --script-security 2 --up /etc/openvpn/up.sh --down /etc/openvpn/down.sh  --config AirVPN_NL-Alblasserdam_Alrai_UDP-443.conf
the up.sh
#! /bin/bash
case "$(pidof deluged | wc -w)" in
0)  echo "VPN up deluged started"
    /usr/bin/mail -s "Deluge UP" a@b.com <<< "vpn up deluged starting"
    /etc/openvpn/update-resolv-conf
    echo "rolv-conf-updated"
1)  # all ok
esac
if anyone is still searching / looking for this
it seems that it only executes scripts in the same directory as the eddie executable, in fact it 'edits' the default.xml file where I put those and removes the path to anywhere else
in that folder it works fine...
