Thaw 0 Posted ... Hi, I'm trying to get the vpn set up with my android phone i've done everything that is said here https://airvpn.org/index.php?option=com_content&view=article&id=63&Itemid=126 and everything shows as it should ..except for when i tick the box for open vpn it all starts setting up and then says checking for username and password at which point it fails and air.ovpn unticks itself, how and where do i put the username and password ? Regards Quote Share this post Link to post
Thaw 0 Posted ... im now getting Linux ifconfig failed: could not execute external program Absolutely no idea what that means Quote Share this post Link to post
Staff 10483 Posted ... Hi, I'm trying to get the vpn set up with my android phone i've done everything that is said here https://airvpn.org/index.php?option=com_content&view=article&id=63&Itemid=126 and everything shows as it should ..except for when i tick the box for open vpn it all starts setting up and then says checking for username and password at which point it fails and air.ovpn unticks itself, how and where do i put the username and password ?RegardsHello! Check your inbox for our support in reply to your previous e-mail.Kind regards Quote Share this post Link to post
leyonchung 0 Posted ... Try these settings. It will help you for sure. 1-Tap the ‘Menu’ button on your smartphone to open the resulting window. 2-Open the ‘Wireless and Network Settings’ window as you enter the new window and tap the concerned icon. 3-You will notice the option for ‘VPN Settings‘ along with many other options depending on the interface of the respective Android phone. 4-After tapping the VPN settings option, you will get the choice to connect to one of the many protocols available. From these, choose ‘Add PPTP VPN’. 5-In the next window, you will be asked to set VPN Name, VPN Server, Enable encryption, and DNS search domains, depending on your handheld devices. 6-Provide VPN Name and other information accordingly, click OK to complete the VPN configuration. 7-Navigate back to the VPN listings window and tap the VPN network that you have created just now to establish the connection. 8-The connection will be notified by a key icon in the notification area of the smartphone. 9-To disconnect the VPN, all you need is to move to the location of the connection and tap the current VPN connection. Hope this will help you Source: edited Quote Share this post Link to post
