lancelot48
Taking very long to connect
Here's my logs:
I 2015.05.19 05:48:22 - AirVPN client version: 2.8.8, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1, Architecture: x64
. 2015.05.19 05:48:22 - Reading options from C:\Users\Clever\AppData\Local\AirVPN\AirVPN.xml
. 2015.05.19 05:48:22 - Data Path: C:\Users\Clever\AppData\Local\AirVPN
. 2015.05.19 05:48:22 - App Path: C:\Program Files\AirVPN
. 2015.05.19 05:48:22 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2015.05.19 05:48:22 - Command line arguments (1): path="home"
. 2015.05.19 05:48:22 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
. 2015.05.19 05:48:22 - Updating systems & servers data ...
. 2015.05.19 05:48:25 - Systems & servers data update completed
I 2015.05.19 05:48:25 - OpenVPN Driver - TAP-Windows Adapter V9 #2
I 2015.05.19 05:48:25 - OpenVPN - Version: OpenVPN 2.3.6 (C:\Program Files\AirVPN\openvpn.exe)
I 2015.05.19 05:48:25 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2015.05.19 05:48:25 - SSL - Version: stunnel 5.09 (C:\Program Files\AirVPN\stunnel.exe)
I 2015.05.19 05:48:25 - IPV6: Available
! 2015.05.19 05:48:25 - Ready
I 2015.05.19 05:49:05 - Session starting.
I 2015.05.19 05:49:05 - Installing tunnel driver
I 2015.05.19 05:49:05 - Checking authorization ...
! 2015.05.19 05:49:06 - Connecting to Heze (United States, Fremont, California)
. 2015.05.19 05:49:06 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.05.19 05:49:06 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.05.19 05:49:06 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.05.19 05:49:06 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.05.19 05:49:06 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.05.19 05:49:06 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.05.19 05:49:06 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.05.19 05:49:06 - OpenVPN > UDPv4 link local: [undef]
. 2015.05.19 05:49:06 - OpenVPN > UDPv4 link remote: [AF_INET]46.21.151.106:443
. 2015.05.19 05:49:06 - OpenVPN > TLS: Initial packet from [AF_INET]46.21.151.106:443, sid=4fbaeea0 1c793d8e
. 2015.05.19 05:49:07 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.05.19 05:49:07 - OpenVPN > Validating certificate key usage
. 2015.05.19 05:49:07 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.05.19 05:49:07 - OpenVPN > VERIFY KU OK
. 2015.05.19 05:49:07 - OpenVPN > Validating certificate extended key usage
. 2015.05.19 05:49:07 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.05.19 05:49:07 - OpenVPN > VERIFY EKU OK
. 2015.05.19 05:49:07 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.05.19 05:49:10 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.05.19 05:49:10 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.05.19 05:49:10 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.05.19 05:49:10 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.05.19 05:49:10 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.05.19 05:49:10 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.21.151.106:443
. 2015.05.19 05:49:12 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.05.19 05:49:12 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.3.137 255.255.0.0'
. 2015.05.19 05:49:12 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.05.19 05:49:12 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.05.19 05:49:12 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.05.19 05:49:12 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.05.19 05:49:12 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.05.19 05:49:12 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.05.19 05:49:12 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.05.19 05:49:12 - OpenVPN > open_tun, tt->ipv6=0
. 2015.05.19 05:49:12 - OpenVPN > TAP-WIN32 device [Local Area Connection 3] opened: \\.\Global\{D188CF23-DA6D-4A76-9835-B08F8BF495AA}.tap
. 2015.05.19 05:49:12 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.05.19 05:49:12 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.3.137/255.255.0.0 [sUCCEEDED]
. 2015.05.19 05:49:12 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.3.137/255.255.0.0 on interface {D188CF23-DA6D-4A76-9835-B08F8BF495AA} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.05.19 05:49:12 - OpenVPN > Successful ARP Flush on interface [29] {D188CF23-DA6D-4A76-9835-B08F8BF495AA}
. 2015.05.19 05:49:17 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:17 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:17 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:22 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:22 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:22 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:24 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:24 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:24 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:25 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:25 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:25 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:26 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:26 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:26 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:27 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:27 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:27 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:28 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:28 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:28 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:29 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:29 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:30 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:31 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:31 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:31 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:32 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:32 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:32 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:33 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:33 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:33 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:34 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:34 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:34 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:35 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:36 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:37 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:38 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:38 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:38 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:40 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:40 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:40 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:41 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:41 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:42 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:42 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:42 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:43 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:43 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:43 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:44 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:44 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:49:46 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:49:47 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:49:47 - OpenVPN > C:\Windows\system32\route.exe ADD 46.21.151.106 MASK 255.255.255.255 192.168.1.1
. 2015.05.19 05:49:47 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=100 and dwForwardType=4
. 2015.05.19 05:49:47 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.05.19 05:49:47 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 10
. 2015.05.19 05:49:47 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.05.19 05:49:47 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1
. 2015.05.19 05:49:47 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.05.19 05:49:47 - OpenVPN > Route addition fallback to route.exe
. 2015.05.19 05:49:47 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.05.19 05:49:47 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.05.19 05:49:47 - OpenVPN > SYSTEM ROUTING TABLE
. 2015.05.19 05:49:47 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.1.1 p=0 i=10 t=4 pr=3 a=1833 h=0 m=200/0/0/0/0
. 2015.05.19 05:49:47 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=101/0/0/0/0
. 2015.05.19 05:49:47 - OpenVPN > 46.21.151.106 255.255.255.255 192.168.1.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=100/0/0/0/0
. 2015.05.19 05:49:47 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=3 a=1867 h=0 m=306/0/0/0/0
. 2015.05.19 05:49:47 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=1867 h=0 m=306/0/0/0/0
. 2015.05.19 05:49:47 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=1867 h=0 m=306/0/0/0/0
. 2015.05.19 05:49:47 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=101/0/0/0/0
. 2015.05.19 05:49:47 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.93.39 p=0 i=29 t=3 pr=3 a=1841 h=0 m=286/0/0/0/0
. 2015.05.19 05:49:47 - OpenVPN > 169.254.93.39 255.255.255.255 169.254.93.39 p=0 i=29 t=3 pr=3 a=1841 h=0 m=286/0/0/0/0
. 2015.05.19 05:49:47 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.93.39 p=0 i=29 t=3 pr=3 a=1841 h=0 m=286/0/0/0/0
. 2015.05.19 05:49:47 - OpenVPN > 192.168.1.0 255.255.255.0 192.168.1.102 p=0 i=10 t=3 pr=3 a=1833 h=0 m=356/0/0/0/0
. 2015.05.19 05:49:47 - OpenVPN > 192.168.1.1 255.255.255.255 192.168.1.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=100/0/0/0/0
. 2015.05.19 05:49:47 - OpenVPN > 192.168.1.102 255.255.255.255 192.168.1.102 p=0 i=10 t=3 pr=3 a=1833 h=0 m=356/0/0/0/0
. 2015.05.19 05:49:47 - OpenVPN > 192.168.1.255 255.255.255.255 192.168.1.102 p=0 i=10 t=3 pr=3 a=1833 h=0 m=356/0/0/0/0
. 2015.05.19 05:49:47 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=3 a=1867 h=0 m=306/0/0/0/0
. 2015.05.19 05:49:47 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.1.102 p=0 i=10 t=3 pr=3 a=1852 h=0 m=356/0/0/0/0
. 2015.05.19 05:49:47 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.93.39 p=0 i=29 t=3 pr=3 a=1851 h=0 m=286/0/0/0/0
. 2015.05.19 05:49:47 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=1867 h=0 m=306/0/0/0/0
. 2015.05.19 05:49:47 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.1.102 p=0 i=10 t=3 pr=3 a=1852 h=0 m=356/0/0/0/0
. 2015.05.19 05:49:47 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.93.39 p=0 i=29 t=3 pr=3 a=1851 h=0 m=286/0/0/0/0
. 2015.05.19 05:49:47 - OpenVPN > SYSTEM ADAPTER LIST
. 2015.05.19 05:49:47 - OpenVPN > TAP-Windows Adapter V9 #2
. 2015.05.19 05:49:47 - OpenVPN >   Index = 29
. 2015.05.19 05:49:47 - OpenVPN >   GUID = {D188CF23-DA6D-4A76-9835-B08F8BF495AA}
. 2015.05.19 05:49:47 - OpenVPN >   IP = 169.254.93.39/255.255.0.0
. 2015.05.19 05:49:47 - OpenVPN >   MAC = 00:ff:d1:88:cf:23
. 2015.05.19 05:49:47 - OpenVPN >   GATEWAY = 0.0.0.0/255.255.255.255
. 2015.05.19 05:49:47 - OpenVPN >   DHCP SERV = 0.0.0.0/255.255.255.255
. 2015.05.19 05:49:47 - OpenVPN >   DHCP LEASE OBTAINED = Tue May 19 05:49:47 2015
. 2015.05.19 05:49:47 - OpenVPN >   DHCP LEASE EXPIRES  = Tue May 19 05:49:47 2015
. 2015.05.19 05:49:47 - OpenVPN >   DNS SERV =
. 2015.05.19 05:49:47 - OpenVPN > Realtek PCIe GBE Family Controller
. 2015.05.19 05:49:47 - OpenVPN >   Index = 10
. 2015.05.19 05:49:47 - OpenVPN >   GUID = {01E514ED-EE53-4808-9C5C-8C2C9F2A0663}
. 2015.05.19 05:49:47 - OpenVPN >   IP = 192.168.1.102/255.255.255.0
. 2015.05.19 05:49:47 - OpenVPN >   MAC = 00:1f:bc:08:1f:11
. 2015.05.19 05:49:47 - OpenVPN >   GATEWAY = 192.168.1.1/255.255.255.255
. 2015.05.19 05:49:47 - OpenVPN >   DHCP SERV = 192.168.1.1/255.255.255.255
. 2015.05.19 05:49:47 - OpenVPN >   DHCP LEASE OBTAINED = Tue May 19 05:19:14 2015
. 2015.05.19 05:49:47 - OpenVPN >   DHCP LEASE EXPIRES  = Wed May 20 05:19:14 2015
. 2015.05.19 05:49:47 - OpenVPN >   DNS SERV = 192.168.1.1/255.255.255.255 64.59.144.90/255.255.255.255 64.59.150.136/255.255.255.255
. 2015.05.19 05:49:47 - Starting Management Interface
. 2015.05.19 05:49:47 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
I 2015.05.19 05:49:47 - Flushing DNS
. 2015.05.19 05:49:47 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2015.05.19 05:49:47 - Disconnecting
. 2015.05.19 05:49:47 - Management - Send 'signal SIGTERM'
. 2015.05.19 05:49:47 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.05.19 05:49:47 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.05.19 05:49:47 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.05.19 05:49:52 - OpenVPN > C:\Windows\system32\route.exe DELETE 46.21.151.106 MASK 255.255.255.255 192.168.1.1
. 2015.05.19 05:49:52 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.05.19 05:49:52 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.1.1 MASK 255.255.255.255 192.168.1.1
. 2015.05.19 05:49:52 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.05.19 05:49:52 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1
. 2015.05.19 05:49:52 - OpenVPN > Route deletion via IPAPI failed [adaptive]
. 2015.05.19 05:49:52 - OpenVPN > Route deletion fallback to route.exe
. 2015.05.19 05:49:52 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.05.19 05:49:52 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.05.19 05:49:52 - OpenVPN > Closing TUN/TAP interface
. 2015.05.19 05:49:52 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.05.19 05:49:52 - Connection terminated.
I 2015.05.19 05:49:52 - Cancel requested.
! 2015.05.19 05:49:52 - Session terminated.
I 2015.05.19 05:50:14 - Session starting.
I 2015.05.19 05:50:14 - Installing tunnel driver
I 2015.05.19 05:50:14 - Checking authorization ...
! 2015.05.19 05:50:15 - Connecting to Heze (United States, Fremont, California)
. 2015.05.19 05:50:15 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.05.19 05:50:15 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.05.19 05:50:15 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.05.19 05:50:15 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.05.19 05:50:15 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.05.19 05:50:15 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.05.19 05:50:15 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.05.19 05:50:15 - OpenVPN > UDPv4 link local: [undef]
. 2015.05.19 05:50:15 - OpenVPN > UDPv4 link remote: [AF_INET]46.21.151.106:443
. 2015.05.19 05:50:15 - OpenVPN > TLS: Initial packet from [AF_INET]46.21.151.106:443, sid=7f2bb8a7 92b5cb4e
. 2015.05.19 05:50:15 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.05.19 05:50:15 - OpenVPN > Validating certificate key usage
. 2015.05.19 05:50:15 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.05.19 05:50:15 - OpenVPN > VERIFY KU OK
. 2015.05.19 05:50:15 - OpenVPN > Validating certificate extended key usage
. 2015.05.19 05:50:15 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.05.19 05:50:15 - OpenVPN > VERIFY EKU OK
. 2015.05.19 05:50:15 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.05.19 05:50:19 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.05.19 05:50:19 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.05.19 05:50:19 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.05.19 05:50:19 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.05.19 05:50:19 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.05.19 05:50:19 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.21.151.106:443
. 2015.05.19 05:50:21 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.05.19 05:50:21 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.3.137 255.255.0.0'
. 2015.05.19 05:50:21 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.05.19 05:50:21 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.05.19 05:50:21 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.05.19 05:50:21 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.05.19 05:50:21 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.05.19 05:50:21 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.05.19 05:50:21 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.05.19 05:50:21 - OpenVPN > open_tun, tt->ipv6=0
. 2015.05.19 05:50:21 - OpenVPN > TAP-WIN32 device [Local Area Connection 3] opened: \\.\Global\{D188CF23-DA6D-4A76-9835-B08F8BF495AA}.tap
. 2015.05.19 05:50:21 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.05.19 05:50:21 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.3.137/255.255.0.0 [sUCCEEDED]
. 2015.05.19 05:50:21 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.3.137/255.255.0.0 on interface {D188CF23-DA6D-4A76-9835-B08F8BF495AA} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.05.19 05:50:21 - OpenVPN > Successful ARP Flush on interface [29] {D188CF23-DA6D-4A76-9835-B08F8BF495AA}
. 2015.05.19 05:50:26 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:26 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:26 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:31 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:31 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:31 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:33 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:33 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:33 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:34 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:34 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:34 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:35 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:36 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:37 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:39 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:39 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:40 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:40 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:40 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:41 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:41 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:42 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:42 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:42 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:43 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:43 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:43 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:44 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:44 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:45 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:45 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:45 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:46 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:47 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:47 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:47 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:49 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:49 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:49 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:50 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:50 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:50 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:51 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:51 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:52 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:52 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:52 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:53 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:53 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:53 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:54 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:54 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:54 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:55 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:55 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:50:55 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:50:56 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:50:56 - OpenVPN > C:\Windows\system32\route.exe ADD 46.21.151.106 MASK 255.255.255.255 192.168.1.1
. 2015.05.19 05:50:56 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=100 and dwForwardType=4
. 2015.05.19 05:50:56 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.05.19 05:50:56 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 10
. 2015.05.19 05:50:56 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.05.19 05:50:56 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1
. 2015.05.19 05:50:56 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.05.19 05:50:56 - OpenVPN > Route addition fallback to route.exe
. 2015.05.19 05:50:56 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.05.19 05:50:56 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.05.19 05:50:56 - OpenVPN > SYSTEM ROUTING TABLE
. 2015.05.19 05:50:56 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.1.1 p=0 i=10 t=4 pr=3 a=1902 h=0 m=200/0/0/0/0
. 2015.05.19 05:50:56 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=101/0/0/0/0
. 2015.05.19 05:50:56 - OpenVPN > 46.21.151.106 255.255.255.255 192.168.1.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=100/0/0/0/0
. 2015.05.19 05:50:56 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=3 a=1936 h=0 m=306/0/0/0/0
. 2015.05.19 05:50:56 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=1936 h=0 m=306/0/0/0/0
. 2015.05.19 05:50:56 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=1936 h=0 m=306/0/0/0/0
. 2015.05.19 05:50:56 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=101/0/0/0/0
. 2015.05.19 05:50:56 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.93.39 p=0 i=29 t=3 pr=3 a=1910 h=0 m=286/0/0/0/0
. 2015.05.19 05:50:56 - OpenVPN > 169.254.93.39 255.255.255.255 169.254.93.39 p=0 i=29 t=3 pr=3 a=1910 h=0 m=286/0/0/0/0
. 2015.05.19 05:50:56 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.93.39 p=0 i=29 t=3 pr=3 a=1910 h=0 m=286/0/0/0/0
. 2015.05.19 05:50:56 - OpenVPN > 192.168.1.0 255.255.255.0 192.168.1.102 p=0 i=10 t=3 pr=3 a=1902 h=0 m=356/0/0/0/0
. 2015.05.19 05:50:56 - OpenVPN > 192.168.1.1 255.255.255.255 192.168.1.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=100/0/0/0/0
. 2015.05.19 05:50:56 - OpenVPN > 192.168.1.102 255.255.255.255 192.168.1.102 p=0 i=10 t=3 pr=3 a=1902 h=0 m=356/0/0/0/0
. 2015.05.19 05:50:56 - OpenVPN > 192.168.1.255 255.255.255.255 192.168.1.102 p=0 i=10 t=3 pr=3 a=1902 h=0 m=356/0/0/0/0
. 2015.05.19 05:50:56 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=3 a=1936 h=0 m=306/0/0/0/0
. 2015.05.19 05:50:56 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.1.102 p=0 i=10 t=3 pr=3 a=1921 h=0 m=356/0/0/0/0
. 2015.05.19 05:50:56 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.93.39 p=0 i=29 t=3 pr=3 a=1920 h=0 m=286/0/0/0/0
. 2015.05.19 05:50:56 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=1936 h=0 m=306/0/0/0/0
. 2015.05.19 05:50:56 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.1.102 p=0 i=10 t=3 pr=3 a=1921 h=0 m=356/0/0/0/0
. 2015.05.19 05:50:56 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.93.39 p=0 i=29 t=3 pr=3 a=1920 h=0 m=286/0/0/0/0
. 2015.05.19 05:50:56 - OpenVPN > SYSTEM ADAPTER LIST
. 2015.05.19 05:50:56 - OpenVPN > TAP-Windows Adapter V9 #2
. 2015.05.19 05:50:56 - OpenVPN >   Index = 29
. 2015.05.19 05:50:56 - OpenVPN >   GUID = {D188CF23-DA6D-4A76-9835-B08F8BF495AA}
. 2015.05.19 05:50:56 - OpenVPN >   IP = 169.254.93.39/255.255.0.0
. 2015.05.19 05:50:56 - OpenVPN >   MAC = 00:ff:d1:88:cf:23
. 2015.05.19 05:50:56 - OpenVPN >   GATEWAY = 0.0.0.0/255.255.255.255
. 2015.05.19 05:50:56 - OpenVPN >   DHCP SERV = 0.0.0.0/255.255.255.255
. 2015.05.19 05:50:56 - OpenVPN >   DHCP LEASE OBTAINED = Tue May 19 05:50:56 2015
. 2015.05.19 05:50:56 - OpenVPN >   DHCP LEASE EXPIRES  = Tue May 19 05:50:56 2015
. 2015.05.19 05:50:56 - OpenVPN >   DNS SERV =
. 2015.05.19 05:50:56 - OpenVPN > Realtek PCIe GBE Family Controller
. 2015.05.19 05:50:56 - OpenVPN >   Index = 10
. 2015.05.19 05:50:56 - OpenVPN >   GUID = {01E514ED-EE53-4808-9C5C-8C2C9F2A0663}
. 2015.05.19 05:50:56 - OpenVPN >   IP = 192.168.1.102/255.255.255.0
. 2015.05.19 05:50:56 - OpenVPN >   MAC = 00:1f:bc:08:1f:11
. 2015.05.19 05:50:56 - OpenVPN >   GATEWAY = 192.168.1.1/255.255.255.255
. 2015.05.19 05:50:56 - OpenVPN >   DHCP SERV = 192.168.1.1/255.255.255.255
. 2015.05.19 05:50:56 - OpenVPN >   DHCP LEASE OBTAINED = Tue May 19 05:19:14 2015
. 2015.05.19 05:50:56 - OpenVPN >   DHCP LEASE EXPIRES  = Wed May 20 05:19:14 2015
. 2015.05.19 05:50:57 - OpenVPN >   DNS SERV = 192.168.1.1/255.255.255.255 64.59.144.90/255.255.255.255 64.59.150.136/255.255.255.255
. 2015.05.19 05:50:57 - Starting Management Interface
. 2015.05.19 05:50:57 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
I 2015.05.19 05:50:57 - Flushing DNS
. 2015.05.19 05:50:57 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2015.05.19 05:50:57 - Disconnecting
. 2015.05.19 05:50:57 - Management - Send 'signal SIGTERM'
. 2015.05.19 05:50:57 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.05.19 05:50:57 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.05.19 05:50:57 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.05.19 05:51:03 - OpenVPN > C:\Windows\system32\route.exe DELETE 46.21.151.106 MASK 255.255.255.255 192.168.1.1
. 2015.05.19 05:51:03 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.05.19 05:51:03 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.1.1 MASK 255.255.255.255 192.168.1.1
. 2015.05.19 05:51:03 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.05.19 05:51:03 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1
. 2015.05.19 05:51:03 - OpenVPN > Route deletion via IPAPI failed [adaptive]
. 2015.05.19 05:51:03 - OpenVPN > Route deletion fallback to route.exe
. 2015.05.19 05:51:03 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.05.19 05:51:03 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.05.19 05:51:03 - OpenVPN > Closing TUN/TAP interface
. 2015.05.19 05:51:03 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.05.19 05:51:03 - Connection terminated.
I 2015.05.19 05:51:03 - Cancel requested.
! 2015.05.19 05:51:03 - Session terminated.
I 2015.05.19 05:51:55 - Session starting.
I 2015.05.19 05:51:55 - Installing tunnel driver
I 2015.05.19 05:51:55 - Checking authorization ...
! 2015.05.19 05:51:56 - Connecting to Phaet (Netherlands, Amsterdam)
. 2015.05.19 05:51:56 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.05.19 05:51:56 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.05.19 05:51:56 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.05.19 05:51:56 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.05.19 05:51:56 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.05.19 05:51:56 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.05.19 05:51:56 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.05.19 05:51:56 - OpenVPN > UDPv4 link local: [undef]
. 2015.05.19 05:51:56 - OpenVPN > UDPv4 link remote: [AF_INET]109.232.227.148:443
. 2015.05.19 05:51:56 - OpenVPN > TLS: Initial packet from [AF_INET]109.232.227.148:443, sid=b98a88f0 04151433
. 2015.05.19 05:51:57 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.05.19 05:51:57 - OpenVPN > Validating certificate key usage
. 2015.05.19 05:51:57 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.05.19 05:51:57 - OpenVPN > VERIFY KU OK
. 2015.05.19 05:51:57 - OpenVPN > Validating certificate extended key usage
. 2015.05.19 05:51:57 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.05.19 05:51:57 - OpenVPN > VERIFY EKU OK
. 2015.05.19 05:51:57 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.05.19 05:51:59 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.05.19 05:51:59 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.05.19 05:51:59 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.05.19 05:51:59 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.05.19 05:51:59 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.05.19 05:51:59 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.232.227.148:443
. 2015.05.19 05:52:02 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.05.19 05:52:02 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.16.53 255.255.0.0'
. 2015.05.19 05:52:02 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.05.19 05:52:02 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.05.19 05:52:02 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.05.19 05:52:02 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.05.19 05:52:02 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.05.19 05:52:02 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.05.19 05:52:02 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.05.19 05:52:02 - OpenVPN > open_tun, tt->ipv6=0
. 2015.05.19 05:52:02 - OpenVPN > TAP-WIN32 device [Local Area Connection 3] opened: \\.\Global\{D188CF23-DA6D-4A76-9835-B08F8BF495AA}.tap
. 2015.05.19 05:52:02 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.05.19 05:52:02 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.16.53/255.255.0.0 [sUCCEEDED]
. 2015.05.19 05:52:02 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.16.53/255.255.0.0 on interface {D188CF23-DA6D-4A76-9835-B08F8BF495AA} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.05.19 05:52:02 - OpenVPN > Successful ARP Flush on interface [29] {D188CF23-DA6D-4A76-9835-B08F8BF495AA}
. 2015.05.19 05:52:07 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:07 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:07 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:12 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:12 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:12 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:14 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:14 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:14 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:15 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:15 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:15 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:16 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:16 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:16 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:17 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:17 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:17 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:18 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:18 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:18 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:20 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:20 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:20 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:21 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:21 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:21 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:22 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:22 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:22 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:23 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:23 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:23 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:24 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:24 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:24 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:25 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:25 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:25 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:26 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:26 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:26 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:28 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:28 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:28 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:29 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:29 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:29 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:30 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:31 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:31 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:31 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:32 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:32 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:32 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:33 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:33 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:33 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:35 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:52:36 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:52:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:52:37 - OpenVPN > C:\Windows\system32\route.exe ADD 109.232.227.148 MASK 255.255.255.255 192.168.1.1
. 2015.05.19 05:52:37 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=100 and dwForwardType=4
. 2015.05.19 05:52:37 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.05.19 05:52:37 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 10
. 2015.05.19 05:52:37 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.05.19 05:52:37 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1
. 2015.05.19 05:52:37 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.05.19 05:52:37 - OpenVPN > Route addition fallback to route.exe
. 2015.05.19 05:52:37 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.05.19 05:52:37 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.05.19 05:52:37 - OpenVPN > SYSTEM ROUTING TABLE
. 2015.05.19 05:52:37 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.1.1 p=0 i=10 t=4 pr=3 a=2003 h=0 m=200/0/0/0/0
. 2015.05.19 05:52:37 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=101/0/0/0/0
. 2015.05.19 05:52:37 - OpenVPN > 109.232.227.148 255.255.255.255 192.168.1.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=100/0/0/0/0
. 2015.05.19 05:52:37 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=3 a=2037 h=0 m=306/0/0/0/0
. 2015.05.19 05:52:37 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=2037 h=0 m=306/0/0/0/0
. 2015.05.19 05:52:37 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=2037 h=0 m=306/0/0/0/0
. 2015.05.19 05:52:37 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=101/0/0/0/0
. 2015.05.19 05:52:37 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.93.39 p=0 i=29 t=3 pr=3 a=2011 h=0 m=286/0/0/0/0
. 2015.05.19 05:52:37 - OpenVPN > 169.254.93.39 255.255.255.255 169.254.93.39 p=0 i=29 t=3 pr=3 a=2011 h=0 m=286/0/0/0/0
. 2015.05.19 05:52:37 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.93.39 p=0 i=29 t=3 pr=3 a=2011 h=0 m=286/0/0/0/0
. 2015.05.19 05:52:37 - OpenVPN > 192.168.1.0 255.255.255.0 192.168.1.102 p=0 i=10 t=3 pr=3 a=2003 h=0 m=356/0/0/0/0
. 2015.05.19 05:52:37 - OpenVPN > 192.168.1.1 255.255.255.255 192.168.1.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=100/0/0/0/0
. 2015.05.19 05:52:37 - OpenVPN > 192.168.1.102 255.255.255.255 192.168.1.102 p=0 i=10 t=3 pr=3 a=2003 h=0 m=356/0/0/0/0
. 2015.05.19 05:52:37 - OpenVPN > 192.168.1.255 255.255.255.255 192.168.1.102 p=0 i=10 t=3 pr=3 a=2003 h=0 m=356/0/0/0/0
. 2015.05.19 05:52:37 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=3 a=2037 h=0 m=306/0/0/0/0
. 2015.05.19 05:52:37 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.1.102 p=0 i=10 t=3 pr=3 a=2022 h=0 m=356/0/0/0/0
. 2015.05.19 05:52:37 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.93.39 p=0 i=29 t=3 pr=3 a=2021 h=0 m=286/0/0/0/0
. 2015.05.19 05:52:37 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=2037 h=0 m=306/0/0/0/0
. 2015.05.19 05:52:37 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.1.102 p=0 i=10 t=3 pr=3 a=2022 h=0 m=356/0/0/0/0
. 2015.05.19 05:52:37 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.93.39 p=0 i=29 t=3 pr=3 a=2021 h=0 m=286/0/0/0/0
. 2015.05.19 05:52:37 - OpenVPN > SYSTEM ADAPTER LIST
. 2015.05.19 05:52:37 - OpenVPN > TAP-Windows Adapter V9 #2
. 2015.05.19 05:52:37 - OpenVPN >   Index = 29
. 2015.05.19 05:52:37 - OpenVPN >   GUID = {D188CF23-DA6D-4A76-9835-B08F8BF495AA}
. 2015.05.19 05:52:37 - OpenVPN >   IP = 169.254.93.39/255.255.0.0
. 2015.05.19 05:52:37 - OpenVPN >   MAC = 00:ff:d1:88:cf:23
. 2015.05.19 05:52:37 - OpenVPN >   GATEWAY = 0.0.0.0/255.255.255.255
. 2015.05.19 05:52:37 - OpenVPN >   DHCP SERV = 0.0.0.0/255.255.255.255
. 2015.05.19 05:52:37 - OpenVPN >   DHCP LEASE OBTAINED = Tue May 19 05:52:37 2015
. 2015.05.19 05:52:37 - OpenVPN >   DHCP LEASE EXPIRES  = Tue May 19 05:52:37 2015
. 2015.05.19 05:52:37 - OpenVPN >   DNS SERV =
. 2015.05.19 05:52:37 - OpenVPN > Realtek PCIe GBE Family Controller
. 2015.05.19 05:52:37 - OpenVPN >   Index = 10
. 2015.05.19 05:52:37 - OpenVPN >   GUID = {01E514ED-EE53-4808-9C5C-8C2C9F2A0663}
. 2015.05.19 05:52:37 - OpenVPN >   IP = 192.168.1.102/255.255.255.0
. 2015.05.19 05:52:37 - OpenVPN >   MAC = 00:1f:bc:08:1f:11
. 2015.05.19 05:52:37 - OpenVPN >   GATEWAY = 192.168.1.1/255.255.255.255
. 2015.05.19 05:52:37 - OpenVPN >   DHCP SERV = 192.168.1.1/255.255.255.255
. 2015.05.19 05:52:37 - OpenVPN >   DHCP LEASE OBTAINED = Tue May 19 05:19:14 2015
. 2015.05.19 05:52:37 - OpenVPN >   DHCP LEASE EXPIRES  = Wed May 20 05:19:14 2015
. 2015.05.19 05:52:37 - OpenVPN >   DNS SERV = 192.168.1.1/255.255.255.255 64.59.144.90/255.255.255.255 64.59.150.136/255.255.255.255
. 2015.05.19 05:52:37 - Starting Management Interface
. 2015.05.19 05:52:37 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
I 2015.05.19 05:52:37 - Flushing DNS
! 2015.05.19 05:52:37 - Disconnecting
. 2015.05.19 05:52:37 - Management - Send 'signal SIGTERM'
. 2015.05.19 05:52:37 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.05.19 05:52:37 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.05.19 05:52:37 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.05.19 05:52:37 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.05.19 05:52:42 - OpenVPN > C:\Windows\system32\route.exe DELETE 109.232.227.148 MASK 255.255.255.255 192.168.1.1
. 2015.05.19 05:52:42 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.05.19 05:52:42 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.1.1 MASK 255.255.255.255 192.168.1.1
. 2015.05.19 05:52:42 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.05.19 05:52:42 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1
. 2015.05.19 05:52:42 - OpenVPN > Route deletion via IPAPI failed [adaptive]
. 2015.05.19 05:52:42 - OpenVPN > Route deletion fallback to route.exe
. 2015.05.19 05:52:42 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.05.19 05:52:42 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.05.19 05:52:42 - OpenVPN > Closing TUN/TAP interface
. 2015.05.19 05:52:42 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.05.19 05:52:42 - Connection terminated.
I 2015.05.19 05:52:42 - Cancel requested.
! 2015.05.19 05:52:42 - Session terminated.
I 2015.05.19 05:53:52 - Session starting.
I 2015.05.19 05:53:52 - Installing tunnel driver
I 2015.05.19 05:53:52 - Checking authorization ...
! 2015.05.19 05:53:53 - Connecting to Grumium (Canada, Toronto, Ontario)
. 2015.05.19 05:53:53 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.05.19 05:53:53 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.05.19 05:53:53 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.05.19 05:53:53 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.05.19 05:53:53 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.05.19 05:53:53 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.05.19 05:53:53 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.05.19 05:53:53 - OpenVPN > UDPv4 link local: [undef]
. 2015.05.19 05:53:53 - OpenVPN > UDPv4 link remote: [AF_INET]199.19.95.187:443
. 2015.05.19 05:53:53 - OpenVPN > TLS: Initial packet from [AF_INET]199.19.95.187:443, sid=b92d8e03 3c726a70
. 2015.05.19 05:53:54 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.05.19 05:53:54 - OpenVPN > Validating certificate key usage
. 2015.05.19 05:53:54 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.05.19 05:53:54 - OpenVPN > VERIFY KU OK
. 2015.05.19 05:53:54 - OpenVPN > Validating certificate extended key usage
. 2015.05.19 05:53:54 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.05.19 05:53:54 - OpenVPN > VERIFY EKU OK
. 2015.05.19 05:53:54 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.05.19 05:54:00 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.05.19 05:54:00 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.05.19 05:54:00 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.05.19 05:54:00 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.05.19 05:54:00 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.05.19 05:54:00 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.19.95.187:443
. 2015.05.19 05:54:03 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.05.19 05:54:03 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.7.154 255.255.0.0'
. 2015.05.19 05:54:03 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.05.19 05:54:03 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.05.19 05:54:03 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.05.19 05:54:03 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.05.19 05:54:03 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.05.19 05:54:03 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.05.19 05:54:03 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.05.19 05:54:03 - OpenVPN > open_tun, tt->ipv6=0
. 2015.05.19 05:54:03 - OpenVPN > TAP-WIN32 device [Local Area Connection 3] opened: \\.\Global\{D188CF23-DA6D-4A76-9835-B08F8BF495AA}.tap
. 2015.05.19 05:54:03 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.05.19 05:54:03 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.7.154/255.255.0.0 [sUCCEEDED]
. 2015.05.19 05:54:03 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.7.154/255.255.0.0 on interface {D188CF23-DA6D-4A76-9835-B08F8BF495AA} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.05.19 05:54:03 - OpenVPN > Successful ARP Flush on interface [29] {D188CF23-DA6D-4A76-9835-B08F8BF495AA}
. 2015.05.19 05:54:08 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:08 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:08 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:54:13 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:13 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:13 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:54:14 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:14 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:14 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:54:15 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:15 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:15 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:54:17 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:17 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:17 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:54:18 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:18 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:18 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:54:19 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:19 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:19 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:54:20 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:20 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:20 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:54:21 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:21 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:21 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:54:22 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:22 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:22 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:54:23 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:23 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:23 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:54:24 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:24 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:24 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:54:25 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:25 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:26 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:54:27 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:27 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:27 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:54:28 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:28 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:28 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:54:29 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:29 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:29 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:54:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:30 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:54:31 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:31 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:31 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:54:32 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:32 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:32 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:54:33 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:33 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:34 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:54:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:35 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
. 2015.05.19 05:54:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.05.19 05:54:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.05.19 05:54:36 - AirVPN Windows Interface Hack executed (Local Area Connection 3)
This morning it took 3 minutes. Its the shortest in a long time.
I'm walking out the door atm didn't have time to look at the entire log. But you could try disabling the option that tests the routes.
The tun/tap interface (virtual network interface used by OpenVPN) does not come up... please try this: https://airvpn.org/topic/8320-solved-connects-but-ip-doesnt-change-on-windows-server-essentials-2012/?do=findComment&comment=8321
Also, upgrading to Eddie 2.9.2 might help with Windows Vista/7/8, because it will use a new driver for the interface which fixes various problems in Windows Vista/7/8.
Can't solve the problem. Use to be really automatic before with no hassle. Plus I'm really not familiar with messing around with settings.
I wonder if uninstalling AirVPN and reinstalling will solve the problem. If not then I guess its a pity that I'll have to look elsewhere for another VPN. Hate to do that after so long.
As the Staff said the tun/tap interface isn't coming up.
Definitely try reinstalling the client.
After the uninstall just make sure the Tun/Tap interface is gone/uninstalled as well.
-GL
