bigtop 0 Posted ... Hi guys, Like I mentioned in a previous post of mine, I've just started using airVPN and VPN's in general and need a bit of guidance. With my setup, I've made sure to turn on the network lock in order to make sure I have no data leaks. What I have found though is that if I restart my machine while the VPN is connected, on restart my machine will connect to the VPN but it will deactivate the network lock before doing so. I've attached some of the text from my logs: 2015.04.14 09:56:32 - Operating System: Microsoft Windows NT 6.2.9200.0I 2015.04.14 09:56:33 - OpenVPN Driver - TAP-Windows Adapter V9I 2015.04.14 09:56:33 - OpenVPN - Version: OpenVPN 2.3.6 (C:\Program Files\AirVPN\openvpn.exe)I 2015.04.14 09:56:33 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)I 2015.04.14 09:56:33 - SSL - Version: stunnel 5.09 (C:\Program Files\AirVPN\stunnel.exe)I 2015.04.14 09:56:33 - IPV6: AvailableW 2015.04.14 09:56:33 - Recovery. Unexpected crash?I 2015.04.14 09:56:34 - DNS of a network adapter restored to original settings (NVIDIA nForce Networking Controller)! 2015.04.14 09:56:34 - Deactivation of Network LockI 2015.04.14 09:56:43 - Session starting.I 2015.04.14 09:56:43 - Installing tunnel driver My machine is running windows 8.1 if that matters. Does anyone have any ideas how keep the network lock on even after it restarts while the VPN is connected? Thanks again in advanced for the help.. Quote Share this post Link to post
Staff 10336 Posted ... Hello! Please see here:W 2015.04.14 09:56:33 - Recovery. Unexpected crash? When Eddie 2.8.8 and older versions (up to 2.5, where Network Lock was implemented for the first time) are killed without grace they will de-activate Network Lock at the next startup. This behavior has been modified in Eddie 2.9 Experimental. Currently the latest experimental version is 2.9.2:https://airvpn.org/topic/13957-eddie-29-experimental-available Kind regards Quote Share this post Link to post
bigtop 0 Posted ... Hello! Please see here:W 2015.04.14 09:56:33 - Recovery. Unexpected crash? When Eddie 2.8.8 and older versions (up to 2.5, where Network Lock was implemented for the first time) are killed without grace they will de-activate Network Lock at the next startup. This behavior has been modified in Eddie 2.9 Experimental. Currently the latest experimental version is 2.9.2:https://airvpn.org/topic/13957-eddie-29-experimental-available Kind regards Thank you! Quote Share this post Link to post
