gajanq1
ANSWERED Remembering whitelisted/blacklisted servers.
Is it possible for the client to remember my choice of whitelisted and blacklisted servers ?
Thanks.
Do the changes and then exit the client. When you start it again it should be as you left it. Issue is when you don't shutdown eddie manual and let the windows shutdown process to do it nothing gets saved because eddie "crashed".
In Eddie 2.8.8 the settings are saved soon after each change, so the problem of losing them for an ungraceful kill should no more occur. Eddie 2.8.8 rolls back white lists and black lists if you click the "Refresh servers" button. This is a bug which has been fixed in 2.9 Experimental (see also here https://airvpn.org/topic/13957-eddie-29-experimental-available ).
