Not connected, Your IP: 216.73.216.221
joantherevelator
Still getting DNS leaks with Network Lock and renaming mode (Linux)
I'm using the GUI on my ubuntu linux machine. I've got the Network Lock on, and I've tried both "renaming" and "resolveconf" DNS modes, and I'm still getting DNS leaks.
When I run a test at https://www.dnsleaktest.com I get at least one of my ISP's servers showing up, under the AirVPN one.
Do I got no alternative but to sort it out in my firewall settings?
ta
If you use AirVPN from terminal or Networkmanager, you could add this to your .ovpn files:
First, verify if resolvconf is installed
Add:
script-security 2\nup /etc/openvpn/update-resolv-conf\ndown /etc/openvpn/update-resolv-conf
or do
for filename in *.ovpn; do  echo -e "script-security 2\nup /etc/openvpn/update-resolv-conf\ndown /etc/openvpn/update-resolv-conf" >> $filename; done
in the folder you have .ovpn files
There are no DNS leaks on Linux. Even if your system queries your ISP DNS, the queries are tunneled and ISP nameservers see them coming from our VPN servers... assuming that the VPN connection is really working, though.
Complete client logs and content of /etc/resolv.conf while the system is in the VPN could provide clues.
