MnM
PfSense keeps disconnecting: TLS: tls_process: killed expiring key
I have configured PFSense and it works as I need it to.
However, every hour the VPN session disconnects and then it reconnects again:
How can I make this stop and actually hold the session for more than one hour?
It's not a disconnection, it's a TLS re-keying through DHE. See also Perfect Forward Secrecy: https://en.wikipedia.org/wiki/Forward_secrec
The re-keying occurs with overlapping windows: until the re-keying has not completed, the old key pair is used to encrypt the Data Channel, so no interruption of the throughput occurs and there's no time pressure.
You can't disable this feature, otherwise you would suffer a disconnection every hour. You can lower the key expiration time, although we believe that one hour already provides a fair security.
