spika 0 Posted ... Hi All, My AirVPN client has not been able to connect for the last couple of days. I have tried several different servers in different countries and uninstalled and reinstalled the software but nothing has changed. I am using AirVPN on a windows 7 64-bit and have not previously encountered any problems. Any suggestions? I 2015.02.19 12:14:33 - Session starting.I 2015.02.19 12:14:33 - Installing tunnel driverI 2015.02.19 12:14:33 - Checking authorization ...! 2015.02.19 12:14:34 - Connecting to Erakis (Netherlands, Amsterdam). 2015.02.19 12:14:34 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015. 2015.02.19 12:14:34 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08. 2015.02.19 12:14:34 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2015.02.19 12:14:34 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2015.02.19 12:14:34 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2015.02.19 12:14:34 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2015.02.19 12:14:34 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]. 2015.02.19 12:14:34 - OpenVPN > UDPv4 link local: [undef]. 2015.02.19 12:14:34 - OpenVPN > UDPv4 link remote: [AF_INET]62.212.72.162:443. 2015.02.19 12:15:06 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting. 2015.02.19 12:15:06 - OpenVPN > SIGTERM received, sending exit notification to peer. 2015.02.19 12:15:11 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2015.02.19 12:15:11 - Disconnecting. 2015.02.19 12:15:11 - Connection terminated.I 2015.02.19 12:15:14 - Checking authorization ...! 2015.02.19 12:15:14 - Connecting to Erakis (Netherlands, Amsterdam). 2015.02.19 12:15:14 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015. 2015.02.19 12:15:14 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08. 2015.02.19 12:15:14 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2015.02.19 12:15:15 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2015.02.19 12:15:15 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2015.02.19 12:15:15 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2015.02.19 12:15:15 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]. 2015.02.19 12:15:15 - OpenVPN > UDPv4 link local: [undef]. 2015.02.19 12:15:15 - OpenVPN > UDPv4 link remote: [AF_INET]62.212.72.162:443. 2015.02.19 12:15:47 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting. 2015.02.19 12:15:47 - OpenVPN > SIGTERM received, sending exit notification to peer. 2015.02.19 12:15:52 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2015.02.19 12:15:52 - Disconnecting. 2015.02.19 12:15:52 - Connection terminated. Quote Share this post Link to post
Staff 10304 Posted ... Hello! The problem:. 2015.02.19 12:15:47 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting Please make sure that no firewall (either on your computer or router) blocks UDP packets and/or OpenVPN packets. In case that your ISP has started blocking UDP, please try a connection in TCP. You can change connection mode in our client Eddie menu "AirVPN" -> "Preferences" -> "Protocols". Please try TCP port 443, but also UDP port 53. Kind regards Quote Share this post Link to post
spika 0 Posted ... Cheers for this. Please make sure that no firewall (either on your computer or router) blocks UDP packets and/or OpenVPN packets. Could you clarify what I should look for on my computers firewall side? Quote Share this post Link to post
