iDontByte 0 Posted ... I'm trying to forward some ports. I use the portforwarding option on the Vpn, and it says that it forwards them, but after when i go to canyouseeme.org and see if it is open, it says "I can't find you on port xxx" Am i doing something wrong? or would it be a problem with my security settings or something on my computer? I tried forwarding thru the router first to see if that would work but i end up getting the same results. I have a feeling I'm doing something wrong, but i'm not sure what. Any help would be appreciated Quote Share this post Link to post
Staff 10386 Posted ... Hello! The very first things to check are:- that the running service is listening to the correct port when the test is performed- that no firewall is blocking packets to and/or from the service- that the running service expects TPC packets. Most tests are only in TCP, not in UDP Kind regards Quote Share this post Link to post
