Not connected, Your IP: 216.73.216.47
computerpc
Problem using software
I just purchased the service, and downloaded the software, however when I try to open it I get the following message:
"The version of this file is not compatible with the version of Windows that you are running. Check your computers system information to see whether you need a x86 (32-bit) or x64 (64 bit) version of the program, and then contact the software publisher."
I am using Windows 7 Home Premium, version 6.1 (32-bit Operating System)
Will AirVPN work for me?
Any help would be greatly appreciated.
@computerpc
you're probably trying to run the 64 bit version. Make sure to download the 32 bit version for Windows 7.
