Tech Jedi Alex 1518 Posted ... Let me introduce you to PortQuiz. It's an outgoing port tester with which you can find out if ports are opened for connection or not. Very helpful if you find the network you are connected to being restrictive so you'll always know which ports you can use to connect to AirVPN without trying to establish a connection. You can use it on many ways. The easiest is to just connect with your browser to a port you want to check, for AirVPN's ports for example the URLs will behttp://portquiz.net:53 (Firefox may block this one. Use IE or a command line app like telnet)http://portquiz.net:80http://portquiz.net:443http://portquiz.net:2018If you can reach the website the port is open. Fast and easy. The site also supports a variety of services started via command line (FTP, SSH,..). Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Staff 10402 Posted ... Remember that the tool tells you nothing about UDP ports, that test is only for TCP. Kind regards 2 Tech Jedi Alex and n8091977 reacted to this Quote Share this post Link to post
