ezd 2 Posted ... I'm using Arch and connect on startup to Airvpn. This works well if I leave my computer running all the time. Now I think it might come handy to suspend or hibernate or whatever it is you call it when your computer goes into some kind of sleep mode. If I do that and wake it up again I am obviously disconnected. So is there some smart setting that lets me automagically reconnect to my previous vpn service after I got disconnected? Quote Share this post Link to post
Staff 10386 Posted ... Hello! OpenVPN will try to do that by default, assuming that reconnection to the Internet is successful at the wake-up. You should check what happens to Internet connectivity when you wake up your computer. Kind regards Quote Share this post Link to post
ezd 2 Posted ... Ok, I think I see where the problem is. I use the resolv.conf script as found here: https://raw.githubusercontent.com/masterkorp/openvpn-update-resolv-conf/master/update-resolv-conf.sh However, I found that it adds my router to the list of ips and therefore fails dnsleaktest.org which will show my ISP. I resolved the DNS leak by removing my router's ip from the resolv.conf list. So once I disconnect I won't have an active connection. I get it. Is there a way to solve this painless in some way? Is there a chance to only allow a reconnect to airvpn ips? Quote Share this post Link to post
