z3r0on3
AirVPN 0.24 connection-loop
I can't connect to any server. It always terminate the connection
Log:
I 2014.08.25 23:21:33 - AirVPN client version: 2.4, System: OSX, Architecture: x64
. 2014.08.25 23:21:33 - Reading options from /Users/xxxxx/.airvpn/AirVPN.xml
. 2014.08.25 23:21:33 - Data Path: /Users/xxxxx/.airvpn
. 2014.08.25 23:21:33 - App Path: /Applications/AirVPN.app/Contents/MacOS
. 2014.08.25 23:21:33 - Executable Path: /Applications/AirVPN.app/Contents/MacOS/AirVPN
. 2014.08.25 23:21:33 - Command line arguments:
. 2014.08.25 23:21:34 - Operating System: Unix 12.5.0.0 - Darwin localhost 12.5.0 Darwin Kernel Version 12.5.0: Sun Sep 29 13:33:47 PDT 2013; root:xnu-2050.48.12~1/RELEASE_X86_64 x86_64
I 2014.08.25 23:21:34 - OpenVPN Driver - Expected
I 2014.08.25 23:21:34 - OpenVPN - Version: OpenVPN 2.3.4 (/Applications/AirVPN.app/Contents/MacOS/openvpn)
I 2014.08.25 23:21:34 - SSH - Version: OpenSSH_5.9p1, OpenSSL 0.9.8y 5 Feb 2013 (/usr/bin/ssh)
I 2014.08.25 23:21:34 - SSL - Version: stunnel 4.56 (/Applications/AirVPN.app/Contents/MacOS/stunnel)
I 2014.08.25 23:21:34 - IPV6: Available
! 2014.08.25 23:21:34 - Ready
I 2014.08.25 23:24:07 - Session starting.
! 2014.08.25 23:24:07 - Checking environment
! 2014.08.25 23:24:07 - Checking authorization
! 2014.08.25 23:24:08 - Connecting to Castor (Netherlands, Amsterdam)
. 2014.08.25 23:24:08 - OpenVPN > OpenVPN 2.3.4 x86_64-apple-darwin13.2.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 18 2014
. 2014.08.25 23:24:08 - OpenVPN > library versions: OpenSSL 1.0.1i 6 Aug 2014, LZO 2.05
. 2014.08.25 23:24:08 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2014.08.25 23:24:08 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2014.08.25 23:24:08 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.25 23:24:08 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.25 23:24:08 - OpenVPN > Socket Buffers: R=[196724->65536] S=[9216->65536]
. 2014.08.25 23:24:08 - OpenVPN > UDPv4 link local: [undef]
. 2014.08.25 23:24:08 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.169.3:443
. 2014.08.25 23:24:08 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.169.3:443, sid=56b7a1c6 4a56fe8f
. 2014.08.25 23:24:08 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2014.08.25 23:24:08 - OpenVPN > Validating certificate key usage
. 2014.08.25 23:24:08 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2014.08.25 23:24:08 - OpenVPN > VERIFY KU OK
. 2014.08.25 23:24:08 - OpenVPN > Validating certificate extended key usage
. 2014.08.25 23:24:08 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2014.08.25 23:24:08 - OpenVPN > VERIFY EKU OK
. 2014.08.25 23:24:08 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2014.08.25 23:24:10 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.08.25 23:24:10 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.25 23:24:10 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.08.25 23:24:10 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.25 23:24:10 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2014.08.25 23:24:10 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.169.3:443
. 2014.08.25 23:24:12 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2014.08.25 23:24:12 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.38.54 10.4.38.53'
. 2014.08.25 23:24:12 - OpenVPN > dyld: lazy symbol binding failed: Symbol not found: ___strlcpy_chk
. 2014.08.25 23:24:12 - OpenVPN >   Referenced from: /Applications/AirVPN.app/Contents/MacOS/openvpn
. 2014.08.25 23:24:12 - OpenVPN >   Expected in: /usr/lib/libSystem.B.dylib
. 2014.08.25 23:24:12 - OpenVPN > dyld: Symbol not found: ___strlcpy_chk
. 2014.08.25 23:24:12 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2014.08.25 23:24:12 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2014.08.25 23:24:12 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2014.08.25 23:24:12 - OpenVPN > OPTIONS IMPORT: route options modified
. 2014.08.25 23:24:12 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
! 2014.08.25 23:24:13 - Disconnecting
. 2014.08.25 23:24:13 - Connection terminated.
! 2014.08.25 23:24:16 - Checking authorization
! 2014.08.25 23:24:16 - Connecting to Castor (Netherlands, Amsterdam)
. 2014.08.25 23:24:16 - OpenVPN > OpenVPN 2.3.4 x86_64-apple-darwin13.2.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Aug 18 2014
. 2014.08.25 23:24:16 - OpenVPN > library versions: OpenSSL 1.0.1i 6 Aug 2014, LZO 2.05
. 2014.08.25 23:24:16 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2014.08.25 23:24:16 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2014.08.25 23:24:16 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.25 23:24:16 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.25 23:24:16 - OpenVPN > Socket Buffers: R=[196724->65536] S=[9216->65536]
. 2014.08.25 23:24:16 - OpenVPN > UDPv4 link local: [undef]
. 2014.08.25 23:24:16 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.169.3:443
. 2014.08.25 23:24:16 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.169.3:443, sid=b1af049a e18fd26c
. 2014.08.25 23:24:17 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2014.08.25 23:24:17 - OpenVPN > Validating certificate key usage
. 2014.08.25 23:24:17 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2014.08.25 23:24:17 - OpenVPN > VERIFY KU OK
. 2014.08.25 23:24:17 - OpenVPN > Validating certificate extended key usage
. 2014.08.25 23:24:17 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2014.08.25 23:24:17 - OpenVPN > VERIFY EKU OK
. 2014.08.25 23:24:17 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2014.08.25 23:24:19 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.08.25 23:24:19 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.25 23:24:19 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.08.25 23:24:19 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.25 23:24:19 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2014.08.25 23:24:19 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.169.3:443
. 2014.08.25 23:24:21 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2014.08.25 23:24:21 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.38.54 10.4.38.53'
. 2014.08.25 23:24:21 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2014.08.25 23:24:21 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2014.08.25 23:24:21 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2014.08.25 23:24:21 - OpenVPN > OPTIONS IMPORT: route options modified
. 2014.08.25 23:24:21 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2014.08.25 23:24:21 - OpenVPN > dyld: lazy symbol binding failed: Symbol not found: ___strlcpy_chk
. 2014.08.25 23:24:21 - OpenVPN >   Referenced from: /Applications/AirVPN.app/Contents/MacOS/openvpn
. 2014.08.25 23:24:21 - OpenVPN >   Expected in: /usr/lib/libSystem.B.dylib
. 2014.08.25 23:24:21 - OpenVPN > dyld: Symbol not found: ___strlcpy_chk
! 2014.08.25 23:24:22 - Disconnecting
. 2014.08.25 23:24:22 - Connection terminated.
I 2014.08.25 23:24:22 - Cancel requested.
I 2014.08.25 23:24:22 - Session terminated.
It appears that you're running Eddie 2.4 on a OS X older than 10.9.x (Mavericks). Eddie is developed for Mavericks. Upgrade to Mavericks is free. If you don't want to upgrade, anyway, you can run Tunnelblick. Please see instructions here: https://airvpn.org/macosx
I'm running Eddie 2.4 on Mac OSX 10.9.4 and I'm going through the same loop.
do you get this as well from OpenVPN?
