themystical
Client is connected but my IP is the same
Having this issues for the past 4 hours, the client connects as usual, shows the server's IP with activity at 0 kB/sec (download/upload) and if i check the IP with one of the many what's my IP websites I see I'm not actually connected to the VPN, even the status at airvpn.com says not connected, I tried different servers, same thing.
Any idea? Thanks
Please post the logs taken just after a connection has been allegedly established. Please right-click on the Air tray icon, select "Logs", click "Copy to clibpoard" and paste into your message.
04-26-2014 - 11:09 PM    ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
04-26-2014 - 11:09 PM    VERIFY EKU OK
04-26-2014 - 11:09 PM    VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
04-26-2014 - 11:09 PM    Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
04-26-2014 - 11:09 PM    Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
04-26-2014 - 11:09 PM    Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
04-26-2014 - 11:09 PM    Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
04-26-2014 - 11:09 PM    Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
04-26-2014 - 11:09 PM    [server] Peer Connection Initiated with [AF_INET]46.165.208.70:443
04-26-2014 - 11:09 PM    SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
04-26-2014 - 11:09 PM    PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.56.178 10.4.56.177'
04-26-2014 - 11:09 PM    OPTIONS IMPORT: timers and/or timeouts modified
04-26-2014 - 11:09 PM    OPTIONS IMPORT: LZO parms modified
04-26-2014 - 11:09 PM    OPTIONS IMPORT: --ifconfig/up options modified
04-26-2014 - 11:09 PM    OPTIONS IMPORT: route options modified
04-26-2014 - 11:09 PM    OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
04-26-2014 - 11:09 PM    do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
04-26-2014 - 11:09 PM    open_tun, tt->ipv6=0
04-26-2014 - 11:09 PM    TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{43F5D578-C4D5-41CC-BA68-FE56DD20EECF}.tap
04-26-2014 - 11:09 PM    TAP-Windows Driver Version 9.9
04-26-2014 - 11:09 PM    Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.56.178/255.255.255.252 on interface {43F5D578-C4D5-41CC-BA68-FE56DD20EECF} [DHCP-serv: 10.4.56.177, lease-time: 31536000]
04-26-2014 - 11:09 PM    NOTE: FlushIpNetTable failed on interface [19] {43F5D578-C4D5-41CC-BA68-FE56DD20EECF} (status=1168) : Element not found.
04-26-2014 - 11:09 PM    TEST ROUTES: 0/2 succeeded len=1 ret=0 a=0 u/d=up
04-26-2014 - 11:09 PM    Route: Waiting for TUN/TAP interface to come up...
04-26-2014 - 11:09 PM    C:\WINDOWS\system32\route.exe ADD 46.165.208.70 MASK 255.255.255.255 192.168.1.1
04-26-2014 - 11:09 PM    ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
04-26-2014 - 11:09 PM    Route addition via IPAPI succeeded [adaptive]
04-26-2014 - 11:09 PM    C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.56.177
04-26-2014 - 11:09 PM    Warning: route gateway is not reachable on any active network adapters: 10.4.56.177
04-26-2014 - 11:09 PM    Route addition via IPAPI failed [adaptive]
04-26-2014 - 11:09 PM    Route addition fallback to route.exe
04-26-2014 - 11:09 PM    env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
04-26-2014 - 11:09 PM    C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.56.177
04-26-2014 - 11:09 PM    C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.56.177
04-26-2014 - 11:09 PM    SYSTEM ROUTING TABLE
04-26-2014 - 11:09 PM    .1 p=0 i=3 t=4 pr=3 a=30206 h=0 m=25/0/0/0/0
04-26-2014 - 11:09 PM    .177 p=0 i=3 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
04-26-2014 - 11:09 PM    10.4.56.177 p=0 i=3 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
04-26-2014 - 11:09 PM    .255 192.168.1.1 p=0 i=3 t=4 pr=3 a=0 h=0 m=25/0/0/0/0
04-26-2014 - 11:09 PM    .0.1 p=0 i=1 t=3 pr=2 a=39799 h=0 m=306/0/0/0/0
04-26-2014 - 11:09 PM     127.0.0.1 p=0 i=1 t=3 pr=2 a=39799 h=0 m=306/0/0/0/0
04-26-2014 - 11:09 PM    55.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=39799 h=0 m=306/0/0/0/0
04-26-2014 - 11:09 PM    56.177 p=0 i=3 t=4 pr=3 a=0 h=0 m=26/0/0/0/0
04-26-2014 - 11:09 PM     192.168.1.2 p=0 i=3 t=3 pr=2 a=30206 h=0 m=281/0/0/0/0
04-26-2014 - 11:09 PM    55 192.168.1.2 p=0 i=3 t=3 pr=2 a=30206 h=0 m=281/0/0/0/0
04-26-2014 - 11:09 PM    .255 192.168.1.2 p=0 i=3 t=3 pr=2 a=30206 h=0 m=281/0/0/0/0
04-26-2014 - 11:09 PM    0 192.168.11.1 p=0 i=12 t=3 pr=2 a=30204 h=0 m=276/0/0/0/0
04-26-2014 - 11:09 PM    255 192.168.11.1 p=0 i=12 t=3 pr=2 a=30204 h=0 m=276/0/0/0/0
04-26-2014 - 11:09 PM    5.255 192.168.11.1 p=0 i=12 t=3 pr=2 a=30204 h=0 m=276/0/0/0/0
04-26-2014 - 11:09 PM    0 192.168.35.1 p=0 i=11 t=3 pr=2 a=30204 h=0 m=276/0/0/0/0
04-26-2014 - 11:09 PM    255 192.168.35.1 p=0 i=11 t=3 pr=2 a=30204 h=0 m=276/0/0/0/0
04-26-2014 - 11:09 PM    5.255 192.168.35.1 p=0 i=11 t=3 pr=2 a=30204 h=0 m=276/0/0/0/0
04-26-2014 - 11:09 PM    0 192.168.56.1 p=0 i=17 t=3 pr=2 a=39791 h=0 m=276/0/0/0/0
04-26-2014 - 11:09 PM    255 192.168.56.1 p=0 i=17 t=3 pr=2 a=39791 h=0 m=276/0/0/0/0
04-26-2014 - 11:09 PM    5.255 192.168.56.1 p=0 i=17 t=3 pr=2 a=39791 h=0 m=276/0/0/0/0
04-26-2014 - 11:09 PM    68.56.1 p=0 i=17 t=3 pr=2 a=39794 h=0 m=276/0/0/0/0
04-26-2014 - 11:09 PM    68.35.1 p=0 i=11 t=3 pr=2 a=30207 h=0 m=276/0/0/0/0
04-26-2014 - 11:09 PM    68.11.1 p=0 i=12 t=3 pr=2 a=30207 h=0 m=276/0/0/0/0
04-26-2014 - 11:09 PM    68.1.2 p=0 i=3 t=3 pr=2 a=30207 h=0 m=281/0/0/0/0
04-26-2014 - 11:09 PM    55.255 192.168.56.1 p=0 i=17 t=3 pr=2 a=39794 h=0 m=276/0/0/0/0
04-26-2014 - 11:09 PM    55.255 192.168.35.1 p=0 i=11 t=3 pr=2 a=30207 h=0 m=276/0/0/0/0
04-26-2014 - 11:09 PM    55.255 192.168.11.1 p=0 i=12 t=3 pr=2 a=30207 h=0 m=276/0/0/0/0
04-26-2014 - 11:09 PM    55.255 192.168.1.2 p=0 i=3 t=3 pr=2 a=30207 h=0 m=281/0/0/0/0
04-26-2014 - 11:09 PM    SYSTEM ADAPTER LIST
04-26-2014 - 11:09 PM    l Area Network) #2
04-26-2014 - 11:09 PM      Index = 10
04-26-2014 - 11:09 PM    DD9-8F2B-00466D776539}
04-26-2014 - 11:09 PM      IP = 0.0.0.0/0.0.0.0
04-26-2014 - 11:09 PM      MAC = c8:f7:33:e1:85:ec
04-26-2014 - 11:09 PM    55.255.255
04-26-2014 - 11:09 PM      DHCP SERV =
04-26-2014 - 11:09 PM    at Apr 26 23:09:52 2014
04-26-2014 - 11:09 PM      DNS SERV =
04-26-2014 - 11:09 PM    Virtual Adapter
04-26-2014 - 11:09 PM      Index = 7
04-26-2014 - 11:09 PM    F5E-A133-68DA3413977E}
04-26-2014 - 11:09 PM      MAC = ca:f7:33:e1:85:e8
04-26-2014 - 11:09 PM    rtual Adapter
04-26-2014 - 11:09 PM      Index = 6
04-26-2014 - 11:09 PM    FC8-B661-E31928DF2A79}
04-26-2014 - 11:09 PM      MAC = c8:f7:33:e1:85:e9
04-26-2014 - 11:09 PM    ontroller
04-26-2014 - 11:09 PM      Index = 4
04-26-2014 - 11:09 PM    5FD-88EE-D5D8BD609D89}
04-26-2014 - 11:09 PM      MAC = 50:b7:c3:0b:e7:fa
04-26-2014 - 11:09 PM    nced-N 6235
04-26-2014 - 11:09 PM      Index = 3
04-26-2014 - 11:09 PM    637-8584-7CC13090F8C3}
04-26-2014 - 11:09 PM    5.255.0
04-26-2014 - 11:09 PM      MAC = c8:f7:33:e1:85:e8
04-26-2014 - 11:09 PM    55.255.255.255
04-26-2014 - 11:09 PM    /255.255.255.255
04-26-2014 - 11:09 PM    at Apr 26 14:46:27 2014
04-26-2014 - 11:09 PM    un Apr 27 14:46:27 2014
04-26-2014 - 11:09 PM    255.255.255.255
04-26-2014 - 11:09 PM    dapter for VMnet1
04-26-2014 - 11:09 PM      Index = 11
04-26-2014 - 11:09 PM    3F7-9B9B-9ACE8B67C29F}
04-26-2014 - 11:09 PM    55.255.0
04-26-2014 - 11:09 PM      MAC = 00:50:56:c0:00:01
04-26-2014 - 11:09 PM    dapter for VMnet8
04-26-2014 - 11:09 PM      Index = 12
04-26-2014 - 11:09 PM    351-A034-627F5CFACE52}
04-26-2014 - 11:09 PM      MAC = 00:50:56:c0:00:08
04-26-2014 - 11:09 PM    rnet Adapter
04-26-2014 - 11:09 PM      Index = 17
04-26-2014 - 11:09 PM    FE6-9537-CA341187FB5C}
04-26-2014 - 11:09 PM      MAC = 08:00:27:00:28:bc
04-26-2014 - 11:09 PM    Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
04-26-2014 - 11:09 PM    Starting Management Interface...
04-26-2014 - 11:09 PM    Checking...
04-26-2014 - 11:09 PM    Retrieve statistics...
04-26-2014 - 11:09 PM    Connected.
