thepiwo
Skype is not connecting since three Days from Dorsum
As the title says: Skype is not connecting since three Days from Dorsum.
Some help or fix would be appreciated!
(Dorsum is slower to for the last week or so)
Today I noticed that Skype is no more connecting through ANY AirVPN Server
Can anyone confirm ? Or something wrong with my config ? I checked and ext IPs always from AirVPN
Check your DNS. Can you load sites fine?
Yes of course. I run skype on tablet and its online. When I connect vpn, it disconnects after some time and only come on again when I switch off vpn.
DNS is not the problem. Your skype work through AirVPN ?
Hello All,
Skype is working on my Macbook Pro running Mavericks 10.9.2 and OpenVpn. What type of system are you running win or linux?  Check your firewall setting. Also have you recently updated Skype?
Hope this helps,
       Solex1
Yes, its working fine for me. Not sure how to help you
What servers have you tried so far.
I use CM 10 on my Tab2 Galaxy. Ok thank you for information. I ll search for my problem. If skype is not blocking, it must be config problem anywhere
We have tested Skype on most Europe servers, including Dorsum and several NL servers, and we could not find any problem at all.
