avalanche
Mac Os X Maverick issue with applying firewall
Hi All,
I try to apply firewall rules for mac to prevent any leaks but I have issue with it. I am using this tutorial:
https://airvpn.org/topic/1713-win-mac-bsd-block-traffic-when-vpn-disconnects/page-2?do=findComment&comment=2532
I don't need any DNS services or such so I have remove them from file (I use resolve names in config generator). I also add servers IP that I want to use. This is my config file.
block drop out inet from 192.168.0.0/16 to any
#Luxemburg
pass out quick inet from 192.168.0.0/16 to 94.242.205.234 flags S/SA keep state
#Netherlands
pass out quick inet from 192.168.0.0/16 to 95.211.186.65 flags S/SA keep state
#Romania
pass out quick inet from 192.168.0.0/16 to 109.163.230.232  flags S/SA keep state
#Sweden
pass out quick inet from 192.168.0.0/16 to 178.248.30.131 flags S/SA keep state
# Local network
pass out quick inet from 192.168.0.0/16 to 192.168.0.0/16 flags S/SA keep state
# Allow all on lo0
pass out quick inet from 127.0.0.1 to any flags S/SA keep state
# Everything tunneled
pass out quick inet from 10.0.0.0/8 to any flags S/SA keep state
And now I try to load those rules.
sudo pfctl -f pf.conf
Password:
pfctl: Use of -f option, could result in flushing of rules
present in the main ruleset added by the system at startup.
See /etc/pf.conf for further details.
No ALTQ support in kernel
ALTQ related functions disabled
And still even I am not connected to VPN I have full internet access. Am I doing something wrong? This is etc/pf.conf
scrub-anchor "com.apple/*"
nat-anchor "com.apple/*"
rdr-anchor "com.apple/*"
dummynet-anchor "com.apple/*"
load anchor "com.apple" from "/etc/pf.anchors/com.apple"
Basicly what I need is a way to test rules, apply them and preferably to simple remove them when needed. My internal IP address is 192.168.1.X should I also change rules to that?
Thanks in advance for help.
Best Regards
P.S I have paste content of files not add as attachment but "I am not permitted to upload file of this kind"
Please make sure that your internal network is in 192.168.0.0/16, then try to add the following rules:
pass out quick inet from any to 255.255.255.255
The first rule allows communications within your local network, the second rule enables DHCP discovery and negotiation.
