sjg 0 Posted ... Hello, I am staying in a hotel at the moment and the VPN connection is dropped every 50 seconds. Without the VPN the connections seems to work OK. The attached log shows one example of this at 09:06:25. I have tried ssh, ssl and various ports but they all show the same behaviour: it connects for a short time, the connection drops and is reestablished etc. I'll be leaving the hotel in a couple of hours so this isn't a critical issue, but I wonder if you can suggest any reason for this behaviour and any way to get around it if I should encounter it in the future? Thanks. Quote Share this post Link to post
Staff 10640 Posted ... Hello! It's probable that it's the hotel line that regularly drops. When you're not connected to a VPN this causes short black outs which might be more or less tolerable, but when tunneling these drops will cause a longer data flow interruption. Kind regards Quote Share this post Link to post
