Royee 11 Posted ... Hi I am giving pfsense a try, but struggling getting the right settings under openvpn client under pfsense. I have a windows 7 Pc, vbox > pfsense running with ethernet 1-NAT and ethernet 2-internal settings (network name: test1) I can access pfsense web gui from another vbox > linux running which is linked to test1 internal network just fine. However am confused as to the settings to enter. I entered opennic dns servers, which I think is ok, added my 2 certs and 1 key via copy and paste into cert manager. Am stuck on OpenVPN Client settings below: Server node : peer to peer (SSL/TLS or shared key) protocol : udp or tcpdevice mode: tun or tapinterface : wan/lan/local host/anylocal port: ?server host : I entered AirVPN entry ip serverServer port : AirVPN port numberproxy host: left blankproxy port: left blankproxy authentication type:ntlm or basicusername:password:infinitely resolve server: tick or unchecktls authentication:tick or uncheckpeer certificate authority: Airvpnclient certificate: webconfig in useencryption algorithm: AES-256-CBChardware crypto: no hardware selected/BSD/RSAXIPv4 Tunnel network: left blankIPv6 Tunner network:IPv4 Remote networks:IPv6 Remote networks:Limit outgoing bandwith:compression:/compress tunel packets with LZO: Left untickedtype of service:set TOS IP header value of tunnel packets to match encapsulated packet value : Left unticked I managed to get the server & port settings and UDP/Tun/AES 256-CBC settings from the airvpn config files, I searched for pfsense guide on here but none Any ideas with the other settings? Perhaps someone can copy n paste my settings above and bolded the right setting? Cheers Quote Share this post Link to post
Staff 10717 Posted ... Hi I am giving pfsense a try, but struggling getting the right settings under openvpn client under pfsense. I have a windows 7 Pc, vbox > pfsense running with ethernet 1-NAT and ethernet 2-internal settings (network name: test1) I can access pfsense web gui from another vbox > linux running which is linked to test1 internal network just fine. However am confused as to the settings to enter. I entered opennic dns servers, which I think is ok, added my 2 certs and 1 key via copy and paste into cert manager. Am stuck on OpenVPN Client settings below: Server node : peer to peer (SSL/TLS or shared key) SSL/TLS protocol : udp or tcp UDP or TCP according to your choice. device mode: tun or tap TUN interface : wan/lan/local host/any It depends on your router setup. Surely not local host. local port: ?server host : I entered AirVPN entry ip server Ok. Server port : AirVPN port number 53, 80 or 443. tls authentication:tick or uncheck Uncheck. peer certificate authority: Airvpn The ca.crt file that you must download from the configuration generator. client certificate: webconfig in use The user.crt file that you must download form the configuration generator. encryption algorithm: AES-256-CBC Ok. Kind regards 1 Royee reacted to this Quote Share this post Link to post
Royee 11 Posted ... Hi thanks for the settings, but those settings I had all entered already. The interface : I tried Wan but it then complained about an tunnel network address ? So tried internal and seemed to pass it. Proxy authentication : set to none for now, if I choose anything else it ask for username/passwordServer host name resolution: unchecked as Airstaff mentionedTLS authentication : unchecked - Not sure if Airvpn servers require TLS authentication or not but it asked for a static key otherwiseTunnel settings : all left blank since no idea I tried following the guides from a few other vpn providers but there settings are different. Any other pfsense air users out there that could do a print screen of there openvpn settings or help ? thx Quote Share this post Link to post
knicker 11 Posted ... Watch this viedeo... http://vimeo.com/61070499 knicker 2 Staff and scotty reacted to this Quote Share this post Link to post
