Not connected, Your IP: 216.73.216.85
ronswanson
ANSWERED Airvpn client and skype
why is it that if i use the airvpn client my skype wont connect but when i use the openvpn client skype does connect? is this the way you want it to function?
The Air client is an OpenVPN wrapper so there should be no differences for applications. Actually we can't reproduce the issue, can you give us more information?
well if i connect to the airvpn servers using the openvpn client, skype works properly. if i use the airvpn client to connect to the vpn skype keeps trying to connect until it fails to do so after a couple of minuts.
i am using a dlink dir 655 router and updated the firmware to the most current one. it apears to be working now. also with the airvpn client
