As the aforementioned subject says, my torrents are downloading/uploading just fine. However, when I attempt to browse, the connection times out (torrents are downloading are optimum speeds even during this)
Not sure if it is AirVPN or my OS/Browser(s) (Win8, Firefox and Chrome tested)
Would really like to resolves this issue, and forgive my ignorance regarding these connections, but I will try to help and provide any other information necessary.
Thanks~
It might be a DNS issue. Your torrent client can work perfectly without resolving names.
Once your system is connected to a VPN server, can you please open a command line, issue the following commands and send us the output?
If on Linux or OS X:
traceroute google.com
ping 10.4.0.1
If on Windows, from a command prompt with administrator privileges:
ipconfig /flushdns
tracert google.com
ping 10.4.0.1
C:\Users\Shin> ipconfig /flushdns
Windows IP Configuration
Successfully flushed the DNS Resolver Cache
C:\Users\Shin> tracert google.com
Unable to resolve target system name google.com.
C:\Users\Shin> ping 10.4.0.1
Pinging 10.4.0.1 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping Statistics for 10.4.0.1"
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\Users\Shin>
Above is what I received after following your instructions...
If I was not clear enough, I apologize, but I am currently running Windows 8 on an Alienware m17x R4.
Just another note, while running the tests, AirVPN disconnected (the message that came up eludes me at the moment, but I believe it was something about resolving the host)
Thanks for your time...
ok, it's something 'worse' than a DNS issue, it seems that your system is not tunneling traffic or is not connected to the VPN at all.
Please send us at your convenience the OpenVPN logs of an alleged connection. If you run the Air client for Win8, after you have tried a connection to a VPN server, please right-click on the Air dock icon, select "Logs", click "Copy to clipboard" and paste into your message.
10/8/2013 - 2:45 PM AirVPN client version: 1.8
10/8/2013 - 2:45 PM Reading options from C:\Users\Shin\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml
10/8/2013 - 2:45 PM OpenVPN bundle version: OpenVPN 2.3.0
10/8/2013 - 2:45 PM OpenVPN current version: OpenVPN 2.3.0
10/8/2013 - 2:45 PM Login...
10/8/2013 - 2:45 PM Login success.
10/8/2013 - 2:45 PM Contacting service...
10/8/2013 - 2:45 PM Connecting...
10/8/2013 - 2:45 PM OpenVPN 2.3.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan  8 2013
Here you go~
10/8/2013 - 2:45 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
10/8/2013 - 2:45 PM Socket Buffers: R=[65536->65536] S=[65536->65536]
10/8/2013 - 2:45 PM UDPv4 link local: [undef]
10/8/2013 - 2:45 PM UDPv4 link remote: [AF_INET]84.39.116.179:443
10/8/2013 - 2:45 PM TLS: Initial packet from [AF_INET]84.39.116.179:443, sid=2bd1898e 7c1aca94
10/8/2013 - 2:45 PM VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
10/8/2013 - 2:45 PM VERIFY OK: nsCertType=SERVER
10/8/2013 - 2:45 PM VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
10/8/2013 - 2:45 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
10/8/2013 - 2:45 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
10/8/2013 - 2:45 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
10/8/2013 - 2:45 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
10/8/2013 - 2:45 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
10/8/2013 - 2:45 PM [server] Peer Connection Initiated with [AF_INET]84.39.116.179:443
10/8/2013 - 2:45 PM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
10/8/2013 - 2:45 PM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.13.118 10.4.13.117'
10/8/2013 - 2:45 PM OPTIONS IMPORT: timers and/or timeouts modified
10/8/2013 - 2:45 PM OPTIONS IMPORT: LZO parms modified
10/8/2013 - 2:45 PM OPTIONS IMPORT: --ifconfig/up options modified
10/8/2013 - 2:45 PM OPTIONS IMPORT: route options modified
10/8/2013 - 2:45 PM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
10/8/2013 - 2:45 PM do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
10/8/2013 - 2:45 PM open_tun, tt->ipv6=0
10/8/2013 - 2:45 PM TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{DD841D63-A6D8-473C-992D-13D3086775A9}.tap
10/8/2013 - 2:45 PM TAP-Windows Driver Version 9.9
10/8/2013 - 2:45 PM Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.13.118/255.255.255.252 on interface {DD841D63-A6D8-473C-992D-13D3086775A9} [DHCP-serv: 10.4.13.117, lease-time: 31536000]
10/8/2013 - 2:45 PM Successful ARP Flush on interface [20] {DD841D63-A6D8-473C-992D-13D3086775A9}
10/8/2013 - 2:45 PM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
10/8/2013 - 2:45 PM C:\windows\system32\route.exe ADD 84.39.116.179 MASK 255.255.255.255 192.168.1.1
10/8/2013 - 2:45 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
10/8/2013 - 2:45 PM Route addition via IPAPI succeeded [adaptive]
10/8/2013 - 2:45 PM C:\windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.13.117
10/8/2013 - 2:45 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
10/8/2013 - 2:45 PM C:\windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.13.117
10/8/2013 - 2:45 PM C:\windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.13.117
10/8/2013 - 2:45 PM Initialization Sequence Completed
10/8/2013 - 2:45 PM Starting Management Interface...
10/8/2013 - 2:45 PM Checking...
10/8/2013 - 2:45 PM Retrieve statistics...
10/8/2013 - 2:45 PM Connected.
10/8/2013 - 2:48 PM [server] Inactivity timeout (--ping-restart), restarting
10/8/2013 - 2:48 PM C:\windows\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.13.117
10/8/2013 - 2:48 PM Route deletion via IPAPI succeeded [adaptive]
10/8/2013 - 2:48 PM C:\windows\system32\route.exe DELETE 84.39.116.179 MASK 255.255.255.255 192.168.1.1
10/8/2013 - 2:48 PM C:\windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.13.117
10/8/2013 - 2:48 PM C:\windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.13.117
10/8/2013 - 2:48 PM Closing TUN/TAP interface
10/8/2013 - 2:48 PM SIGUSR1[soft,ping-restart] received, process restarting
10/8/2013 - 2:48 PM Restart pause, 2 second(s)
10/8/2013 - 2:48 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
10/8/2013 - 2:48 PM Socket Buffers: R=[65536->65536] S=[65536->65536]
10/8/2013 - 2:48 PM UDPv4 link local: [undef]
10/8/2013 - 2:48 PM UDPv4 link remote: [AF_INET]84.39.116.179:443
10/8/2013 - 2:48 PM TLS: Initial packet from [AF_INET]84.39.116.179:443, sid=724885ce f1e1d5b8
10/8/2013 - 2:48 PM VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
10/8/2013 - 2:48 PM VERIFY OK: nsCertType=SERVER
10/8/2013 - 2:48 PM VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
10/8/2013 - 2:48 PM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
10/8/2013 - 2:48 PM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
10/8/2013 - 2:48 PM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
10/8/2013 - 2:48 PM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
10/8/2013 - 2:48 PM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
10/8/2013 - 2:48 PM [server] Peer Connection Initiated with [AF_INET]84.39.116.179:443
10/8/2013 - 2:48 PM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
10/8/2013 - 2:48 PM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.13.118 10.4.13.117'
10/8/2013 - 2:48 PM OPTIONS IMPORT: timers and/or timeouts modified
10/8/2013 - 2:48 PM OPTIONS IMPORT: LZO parms modified
10/8/2013 - 2:48 PM OPTIONS IMPORT: --ifconfig/up options modified
10/8/2013 - 2:48 PM OPTIONS IMPORT: route options modified
10/8/2013 - 2:48 PM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
10/8/2013 - 2:48 PM do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
10/8/2013 - 2:48 PM open_tun, tt->ipv6=0
10/8/2013 - 2:48 PM TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{DD841D63-A6D8-473C-992D-13D3086775A9}.tap
10/8/2013 - 2:48 PM TAP-Windows Driver Version 9.9
10/8/2013 - 2:48 PM Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.13.118/255.255.255.252 on interface {DD841D63-A6D8-473C-992D-13D3086775A9} [DHCP-serv: 10.4.13.117, lease-time: 31536000]
10/8/2013 - 2:48 PM Successful ARP Flush on interface [20] {DD841D63-A6D8-473C-992D-13D3086775A9}
10/8/2013 - 2:48 PM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
10/8/2013 - 2:48 PM C:\windows\system32\route.exe ADD 84.39.116.179 MASK 255.255.255.255 192.168.1.1
10/8/2013 - 2:48 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
10/8/2013 - 2:48 PM Route addition via IPAPI succeeded [adaptive]
10/8/2013 - 2:48 PM C:\windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.13.117
10/8/2013 - 2:48 PM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
10/8/2013 - 2:48 PM C:\windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.13.117
10/8/2013 - 2:48 PM C:\windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.13.117
10/8/2013 - 2:48 PM Initialization Sequence Completed
10/8/2013 - 2:48 PM Starting Management Interface...
10/8/2013 - 2:48 PM Checking...
10/8/2013 - 2:49 PM The remote name could not be resolved: 'airvpn.org'
10/8/2013 - 2:49 PM SIGTERM received, sending exit notification to peer
10/8/2013 - 2:49 PM C:\windows\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.13.117
10/8/2013 - 2:49 PM Route deletion via IPAPI succeeded [adaptive]
10/8/2013 - 2:49 PM C:\windows\system32\route.exe DELETE 84.39.116.179 MASK 255.255.255.255 192.168.1.1
10/8/2013 - 2:49 PM C:\windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.13.117
10/8/2013 - 2:49 PM C:\windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.13.117
10/8/2013 - 2:49 PM Closing TUN/TAP interface
10/8/2013 - 2:49 PM SIGTERM[hard,] received, process exiting
10/8/2013 - 2:49 PM Disconnected.
The connection to the VPN server is very unstable:
Can you please try different servers and different ports? In particular, test port 53 UDP and 80 TCP. In order to change connection port from the Air client, please click the "Modes" tab after you have picked a server, select a port/protocol and click "Enter".
Check that tunneling works properly by browsing to airvpn.org and checking the central bottom box (it must be green).
Also, please upgrade at your convenience to OpenVPN 2.3.2 (you can find the new package with client 1.9 and OpenVPN 2.3.2 here: https://airvpn.org/windows).
Ok...
I have tried that and still nothing.
Also, when I disconnect from AirVPN and try to reconnect to try another server.
I always get the "Already Connected" Message for a few minutes before being able to try again...
10/10/2013 - 5:49 AM AirVPN client version: 1.9
10/10/2013 - 5:49 AM Reading options from C:\Users\Shin\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml
10/10/2013 - 5:49 AM OpenVPN bundle version: OpenVPN 2.3.2
10/10/2013 - 5:49 AM OpenVPN current version: OpenVPN 2.3.2
10/10/2013 - 5:49 AM Login...
10/10/2013 - 5:49 AM Login success.
10/10/2013 - 5:49 AM Contacting service...
10/10/2013 - 5:49 AM Connecting...
10/10/2013 - 5:49 AM OpenVPN 2.3.2 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Aug 22 2013
10/10/2013 - 5:49 AM Socket Buffers: R=[65536->65536] S=[65536->65536]
10/10/2013 - 5:49 AM UDPv4 link local: [undef]
10/10/2013 - 5:49 AM UDPv4 link remote: [AF_INET]95.211.149.200:443
10/10/2013 - 5:49 AM TLS: Initial packet from [AF_INET]95.211.149.200:443, sid=1c1f1b1b b58aa15a
10/10/2013 - 5:49 AM VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
10/10/2013 - 5:49 AM VERIFY OK: nsCertType=SERVER
10/10/2013 - 5:49 AM VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
10/10/2013 - 5:49 AM Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
10/10/2013 - 5:49 AM Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
10/10/2013 - 5:49 AM Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
10/10/2013 - 5:49 AM Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
10/10/2013 - 5:49 AM Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
10/10/2013 - 5:49 AM [server] Peer Connection Initiated with [AF_INET]95.211.149.200:443
10/10/2013 - 5:49 AM SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
10/10/2013 - 5:49 AM PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.38.118 10.4.38.117'
10/10/2013 - 5:49 AM OPTIONS IMPORT: timers and/or timeouts modified
10/10/2013 - 5:49 AM OPTIONS IMPORT: LZO parms modified
10/10/2013 - 5:49 AM OPTIONS IMPORT: --ifconfig/up options modified
10/10/2013 - 5:49 AM OPTIONS IMPORT: route options modified
10/10/2013 - 5:49 AM OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
10/10/2013 - 5:49 AM do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
10/10/2013 - 5:49 AM open_tun, tt->ipv6=0
10/10/2013 - 5:49 AM TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{DD841D63-A6D8-473C-992D-13D3086775A9}.tap
10/10/2013 - 5:49 AM TAP-Windows Driver Version 9.9
10/10/2013 - 5:49 AM Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.38.118/255.255.255.252 on interface {DD841D63-A6D8-473C-992D-13D3086775A9} [DHCP-serv: 10.4.38.117, lease-time: 31536000]
10/10/2013 - 5:49 AM Successful ARP Flush on interface [20] {DD841D63-A6D8-473C-992D-13D3086775A9}
10/10/2013 - 5:49 AM TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
10/10/2013 - 5:49 AM C:\windows\system32\route.exe ADD 95.211.149.200 MASK 255.255.255.255 192.168.1.1
10/10/2013 - 5:49 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
10/10/2013 - 5:49 AM Route addition via IPAPI succeeded [adaptive]
10/10/2013 - 5:49 AM C:\windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.38.117
10/10/2013 - 5:49 AM ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
10/10/2013 - 5:49 AM C:\windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.38.117
10/10/2013 - 5:49 AM C:\windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.38.117
10/10/2013 - 5:49 AM Initialization Sequence Completed
10/10/2013 - 5:49 AM Starting Management Interface...
10/10/2013 - 5:49 AM Checking...
10/10/2013 - 5:49 AM Retrieve statistics...
10/10/2013 - 5:49 AM Connected.
10/10/2013 - 5:50 AM Disconnecting...
10/10/2013 - 5:50 AM SIGTERM received, sending exit notification to peer
10/10/2013 - 5:50 AM C:\windows\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.38.117
10/10/2013 - 5:50 AM Route deletion via IPAPI succeeded [adaptive]
10/10/2013 - 5:50 AM C:\windows\system32\route.exe DELETE 95.211.149.200 MASK 255.255.255.255 192.168.1.1
10/10/2013 - 5:50 AM C:\windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.38.117
10/10/2013 - 5:50 AM C:\windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.38.117
10/10/2013 - 5:50 AM Closing TUN/TAP interface
10/10/2013 - 5:50 AM SIGTERM[hard,] received, process exiting
10/10/2013 - 5:50 AM Disconnected.
10/10/2013 - 5:50 AM Login...
10/10/2013 - 5:50 AM Already connected.
it has been 4 days since I last updated you guys on this issue....
I would like to use the service I am still paying for... so even an update would be nice to know that something is being worked on. Thank you.
from your last logs:
OpenVPN receives a signal to terminate. It does not seem a RST packet (which would be logged with SIGTERM hard), it looks like a system break, can you please make sure that you do not shut down OpenVPN and/or that no program such as antivirus is interfering? We're quite sure that it's not  a problem on our side.
Found the issue.
Had to disable then reenable the TAP 9 Connection since a Windows Update somehow tweaked it.
Should share this with anyone running Windows 8 basic =x
Seems like Microsoft is doing a bit of interfering with VPN users.
Thanks for your patience (and sorry for the slight anger, a bit of the impatient type...hehe >>)
