psyberian
ANSWERED OpenVPN Compression VulnerabilitOpeny
I've recently read an article regarding a BlackHat presentation on a compression-related attack on some OpenVPN configurations.
Are the AirVPN generated OpenVPN configurations or the Eddie client potentially vulnerable to such an attack? Or is compression disabled by default?
Is there anything we should do as users to prevent any potential issues?
comp-lzo is in configs because some devices don't seem to work with "comp-lzo no" in the config.  But, AirVPN servers push a message that includes "comp-lzo no", which disables compression.
That's great, thanks for the information.
Once again AirVPN shines . The technical expertise of AirVPN is just extraordinary. I checked the configurations of five other providers: all use compression and are thus vulnerable.
I download the ovpn files via the config generator, at present all have "comp-lzo no" in them when choosing the linux versions.
Yeah, I see that now.   But, I know I've seen Staff comment on this topic in the past and I'm just repeating what they said to the best my memory serves me.  Shrug.  I'll look for the past discussion.
https://airvpn.org/topic/26051-config-generator-using-deprecated-openvpn-commands/?hl=comp-lzo&do=findComment&comment=70698
That's one of the threads I was thinking of.  Looks like I remembered wrong. comp-lzo no must be specified or else there might be connection failure on some devices.
Just to be clear, when OpenVPN puts "LZO compression initialized" in the log, that doesn't mean compression is enabled? I have comp-lzo no in my config file and also pushed from the server so compression should be off but that message makes me wonder.
I don't see that message in my OpenVPN logs.
