telemus
Flummoxed - Can't connect to Air US based servers; Switzerland connect OK
Hello
I've been searching the boards for a solution, but am not really sure how to describe the issue so as to search.
Essentially the issue is that when I attempt to connect to an Air US based server, the connection proceeds until the IPv6 stage then the connection is terminated.
However, I can connect to the Switzerland based servers without any trouble.
I am using Ubuntu 16.04, Eddie 2.14.5. All up to date.
I'm sure there is a solution, but not sure how to find it.
Thank you for reading and any response.
Regards
T
I already reported this issue.
The problem is that some servers work and some don't.
I have an up to date driver and a working IPv6 connectivity.
For example adhara and erai are not working.
Rukbat is working fine.
The fact that it depends on the server clearly shows that this is not an issue with driver or ipv6 connectivity.
Hi mith_y2k - thanks for your reply. It was a specific server.
Hi hugomueller - thank you too for your reply.
I think I may have made it work by changing setting:
Layer IPv4 - Inside tunnel
Layer IPv6 - Block
IP Protocil used for connection: IPv4 only
Most obliged if I could have advice on whether this reduces my security and/or anonymity.
Hello
Regards
T
Please post a Logs -> Support Log (Lifebelt icon) here in a [ spoiler] tag, or open a ticket. Thanks.
Hello Clodo
Thank you for your reply.
I hope I have done as you asked - I'm a bit clueless in all of this.
2018.07.04 16:09:10 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
2018.07.04 16:09:10 - OpenVPN > OPTIONS IMPORT: route options modified
2018.07.04 16:09:10 - OpenVPN > OPTIONS IMPORT: route-related options modified
2018.07.04 16:09:10 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2018.07.04 16:09:10 - OpenVPN > OPTIONS IMPORT: peer-id set
2018.07.04 16:09:10 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561
2018.07.04 16:09:10 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=eno1 HWADDR=c0:3f:d5:64:a5:1d
2018.07.04 16:09:10 - OpenVPN > TUN/TAP device tun0 opened
2018.07.04 16:09:10 - OpenVPN > TUN/TAP TX queue length set to 100
2018.07.04 16:09:10 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
2018.07.04 16:09:10 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500
2018.07.04 16:09:10 - OpenVPN > /sbin/ip addr add dev tun0 10.22.64.227/24 broadcast 10.22.64.255
2018.07.04 16:09:15 - OpenVPN > /sbin/ip route add 199.241.146.162/32 via 192.168.0.1
2018.07.04 16:09:15 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.22.64.1
2018.07.04 16:09:15 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.22.64.1
2018.07.04 16:09:15 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup
2018.07.04 16:09:15 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
2018.07.04 16:09:15 - Routes, added a new route, 199.241.146.163 for gateway 10.22.64.1
2018.07.04 16:09:15 - Unable to compute route for 2605:8680:12:3:42e9:3f53:46f1:546d: IPv6 VPN gateway not available.
2018.07.04 16:09:15 - Flushing DNS
I 2018.07.04 16:09:16 - Checking route IPv4
I 2018.07.04 16:09:17 - Checking route IPv6
2018.07.04 16:09:17 - curl: (7) Couldn't connect to server
2018.07.04 16:09:17 - Checking route (2° try)
2018.07.04 16:09:18 - curl: (7) Couldn't connect to server
2018.07.04 16:09:18 - Checking route (3° try)
2018.07.04 16:09:20 - curl: (7) Couldn't connect to server
E 2018.07.04 16:09:20 - Checking route IPv6 failed.
2018.07.04 16:09:20 - OpenVPN > Initialization Sequence Completed
! 2018.07.04 16:09:20 - Disconnecting
Hello Clodo
Please post an entire Lifebelt report, otherwise i can't help you, thanks.
