Not connected, Your IP: 18.191.171.235
I have been running Air VPN faultlessly for months , and yesterday the message 'Curl is required' appears and cannot connect?
Please would someone be able to help, and yes I re installed curl through chocolary and still the same problem
Many Thanks
John
I have the same problem - I have placed the path to curl.exe in the exclusions of Avast and Malwarebytes but the problem persists.  Eddie says curl is not available.
I had the same issue too, googled it, youtubed it, removed my antivirus SW, was gonna format my PC and start fresh, but I uninsalled AIRVPN and restarted pc, downloaded the AirVPN and YES it works now ! ITS CONNECTING AGAIN, no more curl BS crap popping up !
