Not connected, Your IP: 216.73.216.205
My ISP does not support IPv6, and was hoping that using Castor with AirVPN would give me an IPv6 address and let me use IPv6-only sites.
However, when I try to connect with Eddie, it puts in the Windows 10 notifications "netsh failed: error code 1"
Is this to be expected if your ISP does not support IPv6, or is there something else I have to do to get it to work?
Thank you!
Hope correct.
Please check in Windows "Open Network & Internet settings" > "Change adapter options" > right click on EACH interface > "Properties" > check if TCP/IPv6 is checked. If not, check it.
Hope correct.
Don't have ipv6 either and checked and ipv6 is enabled in the adapters and resetted eddie settings but i keep getting the error below every time i try to connect to the experimental server. Any ideas?
curl: (7) Failed to connect to castor_exit.airservers.org port 89: Bad access
