Not connected, Your IP: 216.73.217.36
guppy
Port forwarding troubles [Tomato]
I'm having a bit of trouble getting port forwarding to work.
I run the VPN tunnel on my router ( Tomato firmware )
It's set up per the guide - with a few extras;
Firewall
iptables -I FORWARD -i br0 -o tun11 -j ACCEPT
iptables -I FORWARD -i tun11 -o br0 -j ACCEPT
iptables -I FORWARD ! -o tun11 -s 192.168.1.203 -j DROP
iptables -I FORWARD ! -o tun11 -s 192.168.1.204 -j DROP
iptables -I FORWARD ! -o tun11 -s 192.168.1.200 -j DROP
iptables -I INPUT -i tun11 -j REJECT
iptables -t nat -A POSTROUTING -o tun11 -j MASQUERADE
associated up/down scripts;
root@unknown:/jffs# cat vpn1_up.sh
#!/bin/sh
ip route flush table 200
ip route flush cache
ip rule add from 192.168.1.203 lookup 200
ip rule add from 192.168.1.204 lookup 200
ip rule add from 192.168.1.200 lookup 200
VPN_GW=`ifconfig tun11 | awk '/inet addr/ {split ($2,A,":"); print A[2]}'`
ip route add table 200 default via $VPN_GW dev tun11
root@unknown:/jffs# cat vpn1_down.sh
#!/bin/sh
ip rule del from 192.168.1.203 lookup 200
ip rule del from 192.168.1.204 lookup 200
ip rule del from 192.168.1.200 lookup 200
Basically everything from 192.168.1.[200|203|204] is being forcefully redirected though vpn tunnel 1 and when the tunnel is down they are being denied access to the net.
This part works perfectly and has for quite some time - how ever I now want to forward a port to 204
I've gotten a port in the client area and set up port forwarding in the router like so;
  • PROTO: UDP+TCP
  • src addr: (blank = no limit)
  • external port: 12345  ( made up port, I obviously used the real one given in the client area )
  • internal port: 8088
  • internal addr: 192.168.1.204
The service ( a webserver ) is bound to 0.0.0.0:8088
When I ;
  1. locally connect to 192.168.1.204:8088 it works
  2. connect to my external non vpn ip :12345 it doesn't work
  3. connect to air vpn 'Mapped to public IP' : 12345 it doesn't work
2. is not surprising since the service can't reply outside of the tunnel
3. is the problem - it should work as far as I can tell, unless there is something in my "extras" that prevents it from working.
Sadly I'm not nearly as good at ip tables as I would like so that's entirely possible.
Any help solving this would be greatly appreciated.
Thanks I guess I'll have to dig into iptables documentations again to figure out how to forward to a different internal port
There's not much that hasn't been talked about at some point in these forums.  Just search for it as I know mapping to a different internal port has been discussed.
apparently you can optionally add a port like so;
iptables -t nat -I PREROUTING -i tun1 -p tcp --dport port -j DNAT --to-destination destIP:destPort
would be good if the guide could be edited to include that.
