Silverspring 0 Posted ... Hi, I'm using a Asus rt-n66u router for a while with OpenVPN on port 433. Since speeds are not good, I played with settings / multiple configs to get better speeds but so far those efforts failed. I have a Ziggo ISP account that allows a max speed of 150 Mbps down.On my laptop (Wifi) without vpn I get speeds around 50 to 65 Mbps.When I use AirVPN via the Asus rt-n66u router, I get speeds around < 10 Mbps down and equal up. I've used the https://airvpn.org/asuswrt/ howto page, so uploading the .ovpn file into the router. Currently I run latest Merlin 380.65 firmware. I also used lower versions of Merlins firmware, which did not cause change in behaviour. I've puzzled a lot to get the config on higher speeds but it does not matter if I use UDP or TCP and / or change ports. Tried them all. I used the AirVPN generator set to router, country set to Netherlands and as described using either UDP or TCP trying multiple ports. I can understand that vpn causes overhead in traffic but dropping down to 10 Mbps is a bit too much. What can I do to speed things up? Quote Share this post Link to post
Tech Jedi Alex 1527 Posted ... What can I do to speed things up? Don't use a router.This topic has been discussed thoroughly in several threads. It's the global consensus that consumer-grade router's CPUs are not able to handle much of AES encryption/decryption, effectively decreasing the throughput. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
