Not connected, Your IP: 216.73.216.170
allshinesun
Eddie portable no mono on Ubuntu 16 stopped working suddenly after hard reboot will not initiate now
So a couple of hours ago my client crashed after I had a freeze(to many windows open) and was forced to hard reboot. The client normally runs phenomenally, I have crappy graphics card so 16 crashes from time to time if I'm working on a lot and I've never had issue reconnecting. This time, however, after logging into my computer and starting up the client it gives the following error in terminal and the icon does its little dance and disappears, signifying it does not want to play
Unhandled Exception: System.TypeInitializationException: An exception was thrown by the type initializer for Mono.Unix.Native.Syscall ---> System.DllNotFoundException: $mono_libdir/libMonoPosixHelper.so
  at (wrapper managed-to-native) Mono.Unix.Native.Syscall:_L_ctermid ()
  at Mono.Unix.Native.Syscall..cctor () [0x00000] in <filename unknown>:0
  --- End of inner exception stack trace ---
  at AirVPN.Platforms.Linux.GetExecutablePath () [0x00000] in <filename unknown>:0
  at AirVPN.Core.Platform.GetProgramFolder () [0x00000] in <filename unknown>:0
  at AirVPN.Core.Engine.Initialization () [0x00000] in <filename unknown>:0
  at AirVPN.UI.Linux.Program.Main () [0x00000] in <filename unknown>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: An exception was thrown by the type initializer for Mono.Unix.Native.Syscall ---> System.DllNotFoundException: $mono_libdir/libMonoPosixHelper.so
I've only been on ubuntu a few months and have come leaps and bounds, but this is chinese to me. Can anyone translate?
Somehow your system cannot find a critical file called llibMonoPosixHelper.so.
Are you using the portable version or the installation package?
You should try to reinstall the client (in case of installation package) or extract it again in case of the portable.
This should recheck the mono dependencies as well.
It is the portable. I deleted and redownloaded/extracted and ran for the same errors. I was using the portable because the libmono dependency issues where I have a newer version than is required to install the deb file. I couldn't ever find an answer to solve that issue and after hours of looping between install -f and attempting to manually install deps, then dpkg still reads the same errors. I wish i could wrap my head around building from source. I have mono-devel installed but cannot follow directions as I don't see the menu that it talks about to insert the github clone address within monodevel. Like I said I'm real new to linux and I love it, but only because it is such a challenge to learn. Such challenges are frustrating, and a little troubling as I was running portable client for 4 or 5 days uninterrupted  until I started blogging about this rigged US election. then it crashed. Sure thats paranoia speaking, but I feel uncomfortable without service at this point.
I can open the windows client with wine, but it wont connect either
The error I get when trying to connect through the exe on wine says driver not installed. any idea what driver I need?
Now trying to compile on monodevelop
Folowing https://airvpn.org/topic/12760-how-can-i-compile-the-source-code/
I imported the git, but cannot find a file called AirVPN.sln in the src directory. There are two different eddie....sln's.
Which if any should I debug?
It seems like when i open the vs2015 eddie I get the following error
Error while trying to load the project '/home/willynilly/Projects/AirVPN/airvpn-client.git/src/UI.WpfWeb.Windows/UI.WpfWeb.Windows.csproj': Could not find a part of the path "/home/willynilly/Projects/AirVPN/airvpn-client.git/src/UI.WpfWeb.Windows/UI.WpfWeb.Windows.csproj".
