annovpn 3 Posted ... Hello, I have been using AirVPN for about 4 months. Working fine. I had to recently format my main computer (due to graphics issue which is not relevant to this but the reason for wiping system). On the new build I have installed Bullguard Internet Security with firewall disabled. AirVPN connects automatically on start-up to windows and seems to be fine for 20/30 mins. then all of a sudden the speed will go to 0 up /0 down. It will be like this for a minute or two and then finally disconnect. It will also fail to reconnect which is a second problem. Most times I will need to restart the computer. Useful Info AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64 Log when error occurs . 2016.04.04 17:18:56 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting . 2016.04.04 17:18:56 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting . 2016.04.04 17:18:56 - OpenVPN > Restart pause, 2 second(s) ! 2016.04.04 17:18:56 - Disconnecting . 2016.04.04 17:18:56 - Management - Send 'signal SIGTERM' . 2016.04.04 17:18:56 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2016.04.04 17:18:56 - OpenVPN > MANAGEMENT: Client disconnected . 2016.04.04 17:18:56 - OpenVPN > Assertion failed at misc.c:779 . 2016.04.04 17:18:56 - OpenVPN > Exiting due to fatal error . 2016.04.04 17:18:56 - Connection terminated. I 2016.04.04 17:19:45 - Checking authorization ... W 2016.04.04 17:20:25 - Authorization check failed, continue anyway ({1]) ! 2016.04.04 17:20:25 - Connecting to Zibal (Netherlands, Alblasserdam) ! 2016.04.04 17:21:03 - Disconnecting . 2016.04.04 17:21:03 - Connection terminated. I 2016.04.04 17:21:06 - Checking authorization .. Thank you,Anon Quote Share this post Link to post
annovpn 3 Posted ... Its still doing this. I have set the log type to full so you see everything that is happening. . 2016.04.07 18:35:18 - Updating systems & servers data ..., 1° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:35:27 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting . 2016.04.07 18:35:27 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting . 2016.04.07 18:35:27 - OpenVPN > Restart pause, 2 second(s) ! 2016.04.07 18:35:27 - Disconnecting . 2016.04.07 18:35:27 - Management - Send 'signal SIGTERM' . 2016.04.07 18:35:27 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2016.04.07 18:35:27 - OpenVPN > MANAGEMENT: Client disconnected . 2016.04.07 18:35:27 - OpenVPN > Assertion failed at misc.c:779 . 2016.04.07 18:35:27 - OpenVPN > Exiting due to fatal error . 2016.04.07 18:35:27 - Connection terminated. . 2016.04.07 18:35:28 - Updating systems & servers data ..., 2° try failed (The request was aborted: The operation has timed out.) I 2016.04.07 18:35:30 - Checking authorization ... . 2016.04.07 18:35:38 - Updating systems & servers data ..., 3° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:35:40 - Checking authorization ..., 1° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:35:48 - Updating systems & servers data ..., 4° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:35:48 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (The request was aborted: The operation has timed out.) . 2016.04.07 18:35:50 - Checking authorization ..., 2° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:36:00 - Checking authorization ..., 3° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:36:10 - Checking authorization ..., 4° try failed (The request was aborted: The operation has timed out.) W 2016.04.07 18:36:10 - Authorization check failed, continue anyway ({1]) ! 2016.04.07 18:36:10 - Connecting to Mirach (Netherlands, Alblasserdam) . 2016.04.07 18:36:10 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015 . 2016.04.07 18:36:10 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08 . 2016.04.07 18:36:10 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.04.07 18:36:10 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.04.07 18:36:10 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:36:10 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:36:10 - OpenVPN > Socket Buffers: R=[65536->524288] S=[65536->524288] . 2016.04.07 18:36:10 - OpenVPN > UDPv4 link local: [undef] . 2016.04.07 18:36:10 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.68:443 . 2016.04.07 18:36:10 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.68:443, sid=2a2377d4 1fb36096 . 2016.04.07 18:36:10 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.04.07 18:36:10 - OpenVPN > Validating certificate key usage . 2016.04.07 18:36:10 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.04.07 18:36:10 - OpenVPN > VERIFY KU OK . 2016.04.07 18:36:10 - OpenVPN > Validating certificate extended key usage . 2016.04.07 18:36:10 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.04.07 18:36:10 - OpenVPN > VERIFY EKU OK . 2016.04.07 18:36:10 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2016.04.07 18:36:12 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.04.07 18:36:12 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:36:12 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.04.07 18:36:12 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:36:12 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.04.07 18:36:12 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.68:443 . 2016.04.07 18:36:14 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2016.04.07 18:36:14 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.26.250 255.255.0.0' . 2016.04.07 18:36:14 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.04.07 18:36:14 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2016.04.07 18:36:14 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.04.07 18:36:14 - OpenVPN > OPTIONS IMPORT: route options modified . 2016.04.07 18:36:14 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.04.07 18:36:14 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.04.07 18:36:14 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2016.04.07 18:36:14 - OpenVPN > open_tun, tt->ipv6=0 . 2016.04.07 18:36:14 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{AA8BFF70-36C5-4C18-AEF7-2ED8A3ABCC77}.tap . 2016.04.07 18:36:14 - OpenVPN > All TAP-Windows adapters on this system are currently in use. . 2016.04.07 18:36:14 - OpenVPN > Exiting due to fatal error ! 2016.04.07 18:36:14 - Disconnecting . 2016.04.07 18:36:14 - Connection terminated. I 2016.04.07 18:36:17 - Checking authorization ... . 2016.04.07 18:36:27 - Checking authorization ..., 1° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:36:37 - Checking authorization ..., 2° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:36:47 - Checking authorization ..., 3° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:36:48 - Updating systems & servers data ... . 2016.04.07 18:36:57 - Checking authorization ..., 4° try failed (The request was aborted: The operation has timed out.) W 2016.04.07 18:36:57 - Authorization check failed, continue anyway ({1]) ! 2016.04.07 18:36:57 - Connecting to Mirach (Netherlands, Alblasserdam) . 2016.04.07 18:36:57 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015 . 2016.04.07 18:36:57 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08 . 2016.04.07 18:36:57 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.04.07 18:36:57 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.04.07 18:36:57 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:36:57 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:36:57 - OpenVPN > Socket Buffers: R=[65536->524288] S=[65536->524288] . 2016.04.07 18:36:57 - OpenVPN > UDPv4 link local: [undef] . 2016.04.07 18:36:57 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.68:443 . 2016.04.07 18:36:58 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.68:443, sid=293501e9 8d780b41 . 2016.04.07 18:36:58 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.04.07 18:36:58 - OpenVPN > Validating certificate key usage . 2016.04.07 18:36:58 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.04.07 18:36:58 - OpenVPN > VERIFY KU OK . 2016.04.07 18:36:58 - OpenVPN > Validating certificate extended key usage . 2016.04.07 18:36:58 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.04.07 18:36:58 - OpenVPN > VERIFY EKU OK . 2016.04.07 18:36:58 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2016.04.07 18:36:58 - Updating systems & servers data ..., 1° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:37:00 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.04.07 18:37:00 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:37:00 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.04.07 18:37:00 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:37:00 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.04.07 18:37:00 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.68:443 . 2016.04.07 18:37:02 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2016.04.07 18:37:02 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.26.250 255.255.0.0' . 2016.04.07 18:37:02 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.04.07 18:37:02 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2016.04.07 18:37:02 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.04.07 18:37:02 - OpenVPN > OPTIONS IMPORT: route options modified . 2016.04.07 18:37:02 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.04.07 18:37:02 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.04.07 18:37:02 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2016.04.07 18:37:02 - OpenVPN > open_tun, tt->ipv6=0 . 2016.04.07 18:37:02 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{AA8BFF70-36C5-4C18-AEF7-2ED8A3ABCC77}.tap . 2016.04.07 18:37:02 - OpenVPN > All TAP-Windows adapters on this system are currently in use. . 2016.04.07 18:37:02 - OpenVPN > Exiting due to fatal error ! 2016.04.07 18:37:03 - Disconnecting . 2016.04.07 18:37:03 - Connection terminated. I 2016.04.07 18:37:06 - Checking authorization ... . 2016.04.07 18:37:08 - Updating systems & servers data ..., 2° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:37:16 - Checking authorization ..., 1° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:37:18 - Updating systems & servers data ..., 3° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:37:26 - Checking authorization ..., 2° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:37:28 - Updating systems & servers data ..., 4° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:37:28 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (The request was aborted: The operation has timed out.) . 2016.04.07 18:37:36 - Checking authorization ..., 3° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:37:46 - Checking authorization ..., 4° try failed (The request was aborted: The operation has timed out.) W 2016.04.07 18:37:46 - Authorization check failed, continue anyway ({1]) ! 2016.04.07 18:37:46 - Connecting to Mirach (Netherlands, Alblasserdam) . 2016.04.07 18:37:46 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015 . 2016.04.07 18:37:46 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08 . 2016.04.07 18:37:46 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.04.07 18:37:46 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.04.07 18:37:46 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:37:46 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:37:46 - OpenVPN > Socket Buffers: R=[65536->524288] S=[65536->524288] . 2016.04.07 18:37:46 - OpenVPN > UDPv4 link local: [undef] . 2016.04.07 18:37:46 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.68:443 . 2016.04.07 18:37:46 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.68:443, sid=d3ef5526 9de3464d . 2016.04.07 18:37:46 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.04.07 18:37:46 - OpenVPN > Validating certificate key usage . 2016.04.07 18:37:46 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.04.07 18:37:46 - OpenVPN > VERIFY KU OK . 2016.04.07 18:37:46 - OpenVPN > Validating certificate extended key usage . 2016.04.07 18:37:46 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.04.07 18:37:46 - OpenVPN > VERIFY EKU OK . 2016.04.07 18:37:46 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2016.04.07 18:37:46 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.04.07 18:37:46 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:37:46 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.04.07 18:37:46 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:37:46 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.04.07 18:37:46 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.68:443 . 2016.04.07 18:37:48 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2016.04.07 18:37:48 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.26.250 255.255.0.0' . 2016.04.07 18:37:48 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.04.07 18:37:48 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2016.04.07 18:37:48 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.04.07 18:37:48 - OpenVPN > OPTIONS IMPORT: route options modified . 2016.04.07 18:37:48 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.04.07 18:37:48 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.04.07 18:37:48 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2016.04.07 18:37:48 - OpenVPN > open_tun, tt->ipv6=0 . 2016.04.07 18:37:48 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{AA8BFF70-36C5-4C18-AEF7-2ED8A3ABCC77}.tap . 2016.04.07 18:37:48 - OpenVPN > All TAP-Windows adapters on this system are currently in use. . 2016.04.07 18:37:48 - OpenVPN > Exiting due to fatal error ! 2016.04.07 18:37:48 - Disconnecting . 2016.04.07 18:37:48 - Connection terminated. I 2016.04.07 18:37:51 - Checking authorization ... . 2016.04.07 18:38:01 - Checking authorization ..., 1° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:38:11 - Checking authorization ..., 2° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:38:21 - Checking authorization ..., 3° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:38:29 - Updating systems & servers data ... . 2016.04.07 18:38:31 - Checking authorization ..., 4° try failed (The request was aborted: The operation has timed out.) W 2016.04.07 18:38:31 - Authorization check failed, continue anyway ({1]) ! 2016.04.07 18:38:31 - Connecting to Mirach (Netherlands, Alblasserdam) . 2016.04.07 18:38:31 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015 . 2016.04.07 18:38:31 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08 . 2016.04.07 18:38:31 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.04.07 18:38:32 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.04.07 18:38:32 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:38:32 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:38:32 - OpenVPN > Socket Buffers: R=[65536->524288] S=[65536->524288] . 2016.04.07 18:38:32 - OpenVPN > UDPv4 link local: [undef] . 2016.04.07 18:38:32 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.68:443 . 2016.04.07 18:38:32 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.68:443, sid=928badc8 c9b06e38 . 2016.04.07 18:38:32 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.04.07 18:38:32 - OpenVPN > Validating certificate key usage . 2016.04.07 18:38:32 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.04.07 18:38:32 - OpenVPN > VERIFY KU OK . 2016.04.07 18:38:32 - OpenVPN > Validating certificate extended key usage . 2016.04.07 18:38:32 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.04.07 18:38:32 - OpenVPN > VERIFY EKU OK . 2016.04.07 18:38:32 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2016.04.07 18:38:37 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.04.07 18:38:37 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:38:37 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.04.07 18:38:37 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:38:37 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.04.07 18:38:37 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.68:443 . 2016.04.07 18:38:39 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2016.04.07 18:38:39 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.26.250 255.255.0.0' . 2016.04.07 18:38:39 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.04.07 18:38:39 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2016.04.07 18:38:39 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.04.07 18:38:39 - OpenVPN > OPTIONS IMPORT: route options modified . 2016.04.07 18:38:39 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.04.07 18:38:39 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.04.07 18:38:39 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2016.04.07 18:38:39 - OpenVPN > open_tun, tt->ipv6=0 . 2016.04.07 18:38:39 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{AA8BFF70-36C5-4C18-AEF7-2ED8A3ABCC77}.tap . 2016.04.07 18:38:39 - OpenVPN > All TAP-Windows adapters on this system are currently in use. . 2016.04.07 18:38:39 - OpenVPN > Exiting due to fatal error . 2016.04.07 18:38:39 - Updating systems & servers data ..., 1° try failed (The request was aborted: The operation has timed out.) ! 2016.04.07 18:38:39 - Disconnecting . 2016.04.07 18:38:39 - Connection terminated. I 2016.04.07 18:38:42 - Checking authorization ... . 2016.04.07 18:38:49 - Updating systems & servers data ..., 2° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:38:52 - Checking authorization ..., 1° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:38:59 - Updating systems & servers data ..., 3° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:39:02 - Checking authorization ..., 2° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:39:09 - Updating systems & servers data ..., 4° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:39:09 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (The request was aborted: The operation has timed out.) . 2016.04.07 18:39:12 - Checking authorization ..., 3° try failed (The request was aborted: The operation has timed out.) . 2016.04.07 18:39:22 - Checking authorization ..., 4° try failed (The request was aborted: The operation has timed out.) W 2016.04.07 18:39:22 - Authorization check failed, continue anyway ({1]) ! 2016.04.07 18:39:22 - Connecting to Mirach (Netherlands, Alblasserdam) . 2016.04.07 18:39:22 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015 . 2016.04.07 18:39:22 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08 . 2016.04.07 18:39:22 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.04.07 18:39:22 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.04.07 18:39:22 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:39:22 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:39:22 - OpenVPN > Socket Buffers: R=[65536->524288] S=[65536->524288] . 2016.04.07 18:39:22 - OpenVPN > UDPv4 link local: [undef] . 2016.04.07 18:39:22 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.68:443 . 2016.04.07 18:39:22 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.68:443, sid=7a8d0ec8 334b6b29 . 2016.04.07 18:39:22 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.04.07 18:39:22 - OpenVPN > Validating certificate key usage . 2016.04.07 18:39:22 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.04.07 18:39:22 - OpenVPN > VERIFY KU OK . 2016.04.07 18:39:22 - OpenVPN > Validating certificate extended key usage . 2016.04.07 18:39:22 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.04.07 18:39:22 - OpenVPN > VERIFY EKU OK . 2016.04.07 18:39:22 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2016.04.07 18:39:25 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.04.07 18:39:25 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:39:25 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.04.07 18:39:25 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:39:25 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.04.07 18:39:25 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.68:443 . 2016.04.07 18:39:27 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2016.04.07 18:39:27 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.26.250 255.255.0.0' . 2016.04.07 18:39:27 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.04.07 18:39:27 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2016.04.07 18:39:27 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.04.07 18:39:27 - OpenVPN > OPTIONS IMPORT: route options modified . 2016.04.07 18:39:27 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.04.07 18:39:27 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.04.07 18:39:27 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2016.04.07 18:39:27 - OpenVPN > open_tun, tt->ipv6=0 . 2016.04.07 18:39:27 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{AA8BFF70-36C5-4C18-AEF7-2ED8A3ABCC77}.tap . 2016.04.07 18:39:27 - OpenVPN > All TAP-Windows adapters on this system are currently in use. . 2016.04.07 18:39:27 - OpenVPN > Exiting due to fatal error ! 2016.04.07 18:39:27 - Disconnecting . 2016.04.07 18:39:27 - Connection terminated. I 2016.04.07 18:39:30 - Checking authorization ... . 2016.04.07 18:39:40 - Checking authorization ..., 1° try failed (The request was aborted: The operation has timed out.) ! 2016.04.07 18:39:43 - Connecting to Mirach (Netherlands, Alblasserdam) . 2016.04.07 18:39:43 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015 . 2016.04.07 18:39:43 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08 . 2016.04.07 18:39:43 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.04.07 18:39:43 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.04.07 18:39:43 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:39:43 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:39:43 - OpenVPN > Socket Buffers: R=[65536->524288] S=[65536->524288] . 2016.04.07 18:39:43 - OpenVPN > UDPv4 link local: [undef] . 2016.04.07 18:39:43 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.68:443 . 2016.04.07 18:39:43 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.68:443, sid=5278b9cf 1278b670 . 2016.04.07 18:39:43 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.04.07 18:39:43 - OpenVPN > Validating certificate key usage . 2016.04.07 18:39:43 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.04.07 18:39:43 - OpenVPN > VERIFY KU OK . 2016.04.07 18:39:43 - OpenVPN > Validating certificate extended key usage . 2016.04.07 18:39:43 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.04.07 18:39:43 - OpenVPN > VERIFY EKU OK . 2016.04.07 18:39:43 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2016.04.07 18:39:49 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.04.07 18:39:49 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:39:49 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.04.07 18:39:49 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.04.07 18:39:49 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.04.07 18:39:49 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.68:443 . 2016.04.07 18:39:51 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2016.04.07 18:39:51 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.26.250 255.255.0.0' . 2016.04.07 18:39:51 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.04.07 18:39:51 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2016.04.07 18:39:51 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.04.07 18:39:51 - OpenVPN > OPTIONS IMPORT: route options modified . 2016.04.07 18:39:51 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.04.07 18:39:51 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.04.07 18:39:51 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2016.04.07 18:39:51 - OpenVPN > open_tun, tt->ipv6=0 . 2016.04.07 18:39:51 - OpenVPN > TAP-WIN32 device [Ethernet] opened: \\.\Global\{AA8BFF70-36C5-4C18-AEF7-2ED8A3ABCC77}.tap . 2016.04.07 18:39:51 - OpenVPN > TAP-Windows Driver Version 9.21 . 2016.04.07 18:39:51 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.26.250/255.255.0.0 [SUCCEEDED] . 2016.04.07 18:39:51 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.26.250/255.255.0.0 on interface {AA8BFF70-36C5-4C18-AEF7-2ED8A3ABCC77} [DHCP-serv: 10.4.255.254, lease-time: 31536000] . 2016.04.07 18:39:51 - OpenVPN > Successful ARP Flush on interface [8] {AA8BFF70-36C5-4C18-AEF7-2ED8A3ABCC77} . 2016.04.07 18:39:56 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2016.04.07 18:39:56 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.162.68 MASK 255.255.255.255 192.168.0.1 . 2016.04.07 18:39:56 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=7] . 2016.04.07 18:39:56 - OpenVPN > Route addition via IPAPI failed [adaptive] . 2016.04.07 18:39:56 - OpenVPN > Route addition fallback to route.exe . 2016.04.07 18:39:56 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2016.04.07 18:39:56 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.04.07 18:39:56 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=8] . 2016.04.07 18:39:56 - OpenVPN > Route addition via IPAPI failed [adaptive] . 2016.04.07 18:39:56 - OpenVPN > Route addition fallback to route.exe . 2016.04.07 18:39:56 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2016.04.07 18:39:56 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.04.07 18:39:56 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists. [status=5010 if_index=8] . 2016.04.07 18:39:56 - OpenVPN > Route addition via IPAPI failed [adaptive] . 2016.04.07 18:39:56 - OpenVPN > Route addition fallback to route.exe . 2016.04.07 18:39:56 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2016.04.07 18:39:56 - Starting Management Interface . 2016.04.07 18:39:56 - OpenVPN > Initialization Sequence Completed I 2016.04.07 18:39:56 - Flushing DNS . 2016.04.07 18:39:56 - Shell of 'cmd.exe','/c ipconfig /flushdns' done sync in 31 ms I 2016.04.07 18:39:56 - Checking route I 2016.04.07 18:39:57 - Checking DNS ! 2016.04.07 18:40:05 - Connected. Quote Share this post Link to post
zhang888 1067 Posted ... Seems like you have connection timeouts to all servers, even to the authorization one.Do you have another device on the same network? This would be easier to isolate if it's an ISP issue or a software issue on your side.Try to ping airvpn.org for a period of 1 hour and see if you have any packet loss. Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
annovpn 3 Posted ... Try to ping airvpn.org for a period of 1 hour and see if you have any packet loss. Here are the ping results Ping statistics for 213.152.180.16: Packets: Sent = 4211, Received = 4192, Lost = 19 (0% loss), Approximate round trip times in milli-seconds: Minimum = 31ms, Maximum = 78ms, Average = 38ms Quote Share this post Link to post
zhang888 1067 Posted ... Does your other issue still persist? Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
Tech Jedi Alex 1531 Posted ... . 2016.04.07 18:39:51 - OpenVPN > TAP-Windows Driver Version 9.21 zhang, I'm surprised you don't suggest a TAP driver downgrade. You don't have to wait for me, you know. Mr. annovpn, you are describing a problem that would occur with TAP 9.21. After some minutes something breaks the TAP driver, then it's allegedly in use. See my signature for a How-To. 1 quindecim reacted to this Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
annovpn 3 Posted ... Does your other issue still persist? Yes it has still been disconnecting. Mr. annovpn, you are describing a problem that would occur with TAP 9.21. I have downgraded the TAP driver. I will give it a try over the weekend and update this thread with my findings. Thank you, Quote Share this post Link to post
annovpn 3 Posted ... UPDATE: Looks like the the downgrade TAP driver has solved this issue 2 quindecim and Tech Jedi Alex reacted to this Quote Share this post Link to post
