Roxxas96 0 Posted ... Hello ! I have a question concerning Network lock. Context I have a Wireguard interface connected to AirVPN with: PostUp = powershell -command "$ii = (Get-NetAdapter -Name %WIREGUARD_TUNNEL_NAME%).ifIndex; route add 0.0.0.0 mask 0.0.0.0 0.0.0.0 IF $ii metric 9999" PreDown = powershell -command "$ii = (Get-NetAdapter -Name %WIREGUARD_TUNNEL_NAME%).ifIndex; route delete 0.0.0.0 IF $ii" Table = off That way I can leave this interface enabled at any time, nothing from my computer traffic go through this tunnel. I've configured my torrent client to only use this specific interface, that way I am sure my torrent traffic goes only through the VPN tunnel and if interface goes down, my torrent simply stop working (no IP leak). My problem I would like to be able to keep using Eddie as a normal user. But, I have a problem with the network lock, it blocks every connection on the computer, therefore blocking the traffic going through my torrent interface as well. In the network lock settings you can only add bypass rules for outgoing/incoming IPs, I don't think you can allow traffic for an entire interface. Does any one have an idea how to solve my problem ? Best solution would be to have network lock allow traffic through my interface. Thanks for reading. Quote Share this post Link to post
