gr8d8m8
Will I always have the same IP4 exit-IP address when using a given server?
I found a post that seems to imply the answer is yes (linked below), but I wanted to confirm/clarify.  Also, for a given user, do exit addresses I am most likely to use on a given server change very often?
I'd like to use this for access to another service that requires I specify an IP address (or limited set of addresses) which I could set from my most-likely-to-be-connected-to airvpn servers, assuming it is a manageable set.
Less important, mostly curiosity for now, but are IP6 addresses handled the same way?  Seems to me the answer would be not necessarily the same, but as an IP6 newbie, that's just a guess!
The other post I referred to is at: Many Thanks and Best Regards!
The infrastructure for handling port forwarding changed two years ago which has an effect on exit IP addresses:
  • Every server has got multiple exit IP addresses, v4 and v6.
  • Every account is linked to one of the v4 and v6 exit IP addresses. (I think every pool has a v4/v6 combo, and you can't change one and leave the other; if the pool is changed, both exits are changed.)
  • The exit IP pool can be expanded with less effort than before in case the forwarded ports range in a pool is exhausted.
I believe I remember single cases of Support switching the pool an account belongs to due to some problem or other, but it's not something a user can do at will, e.g. by use of the API to "rotate" one's exit address. So you can check the exit IPs of your connections and specify them, they won't change.
