tb4244 0 Posted ... I'm on a new CachyOS install for a couple of weeks now. I've tried installing Eddie-ui three times, two of the AUR packages and now downloading directly from the website and installing with pacman -U following a post I saw here. The same thing keeps happening: After installing and using the GUI once or a few times, the GUI disappears while I'm connected to the VPN. There is no icon in the system tray (I remember it from using Eddie in Mint, it's a small cloud icon). There is then no way to disconnect from the VPN. I'm locked out of my local network. Trying "my ip" in a browser shows that I'm still connected to the VPN in Europe. I tried starting a new instance of Eddie, and the GUI comes up and says the VPN is disconnected since I haven't clicked the connect button yet for that instance, but the VPN is actually still connected and I'm still locked out of my local network. Closing that new GUI also does not disconnect the VPN. The only way to get it to really disconnect is to reboot (logging out isn't sufficient). I've paid for over a year of AirVPN. If this cannot be solved, I'll unfortunately need to ask for a refund and use another VPN. Quote Share this post Link to post
