Not connected, Your IP: 216.73.217.173
Stolen Compass
Fedora network nftables netlock problems,
I'm having a problem with Eddie 2.26.2 on Fedora 44.
Network Lock fails with:
Exception: nft issue: exit:1; path:/usr/bin/nft; arg:-f; arg:/var/lib/eddie-vpn/state/netlock_nftables_backup.nft
I've already set NftablesTableOwner=no in firewalld.
When the error occurs, Eddie removes the firewalld nftables table but then fails to restore/apply the rules. sudo nft list tables is empty afterwards. Reloading firewalld restores it.
SELinux is Enforcing. There were some SELinux denials initially, which have been addressed, but there are no new AVC denials when this particular error occurs.
System:
  • Fedora 44 Workstation
  • Eddie 2.26.2
  • firewalld
  • SELinux Enforcing
  • Network Lock: Linux nftables
Has anyone encountered this on recent Fedora versions, or is there a known fix?
Thanks!
[Been trying to resolve this with AI but it's been going in circles for days trying to put in new permissions and nothing is working...]
Exact same error on Ludora 44, using either Eddie 2.26.2 or 2.27.2 (experimental).
Reverting to 2.24.6 is the only fix I've found.
