MarkEHansen
Problems with eddie-ui on AlmaLinux9 with iptables
I am new to AirVPN and VPNs in general. I've installed AirVPN eddie-ui 2.24.6 x64 Linux Fedora on my AlmaLinux9 system.
The only graphical display I have is my Cygwin X server on my Windows desktop, and there the eddie UI is very slow. It takes more than 30 seconds for it to react to any actions, like button clicks, etc.
I would like to try the CLI, but I can't find any documentation for either the UI or CLI other than the FAQs. Does such documentation exist?
I'm running eddie-ui as root, so I believe I should not have any permission issue. Watching the console output from the terminal where I launched the application, I see what look like reasonable logs, except for these:
I 2026.08.22 10:54:33 - SSL - Not available
(eddie-tray:32692): libayatana-appindicator-WARNING **: 10:54:34.491: libayatana-appindicator is deprecated. Please use libayatana-appindicator-glib in newly written code.
I was able to log in using the UI and when it asks me to connect to a recommended server, I click on that and after a long wait, I get the following pop-up message:
  There is no available or enabled Network Lock mode, sorry.
I see the following logs:
eddie-system-report-20260822.txt
Based on my searching, I think my problem has to do with the Network Lock feature, so I went into the settings and on the Network Lock tab, changed Mode from Automatic to None and unset "Ensure in session".
Now, it seems to at least be attempting to connect to the servers. I see it updating the routes and working with DNS, etc. (watching the console output). However, when it get to where I think it's connected to the server and want to confirm the connection, I see this log:
E 2026.08.23 10:25:12 - Checking route IPv4 failed, last reason: Fetch url error:Timeout was reached
! 2026.08.23 10:25:12 - Disconnecting
I wonder if the problem is my name server. I see (in the logs) the application is trying to do a systemctl operation on named, but I used named-chroot. I looked through the settings in the application to see if there was a way for me to specific where the application can get at my name server, but don't see anything.
Could this be the problem?
Here are the logs, up to the point of the disconnect:
. 2026.08.23 10:46:26 - Above log line repeated 1024 times more
I 2026.08.23 10:46:26 - Session starting.
I 2026.08.23 10:46:26 - Checking authorization ...
. 2026.08.23 10:46:26 - Elevated: Command:ipv6-block
! 2026.08.23 10:46:26 - Connecting to Maia (United States of America, Los Angeles)
. 2026.08.23 10:46:26 - Elevated: Command:route-list
. 2026.08.23 10:46:26 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'show', exit:0, out:'default via 64.30.105.254 dev enp5s0 proto static metric 101
. 2026.08.23 10:46:26 -     10.1.1.0/24 dev enp2s0 proto kernel scope link src 10.1.1.1 metric 100
. 2026.08.23 10:46:26 -     64.30.105.0/24 dev enp5s0 proto kernel scope link src 64.30.105.143 metric 101'
. 2026.08.23 10:46:26 - Elevated: Exec, path:'/sbin/ip', arg:'-6', arg:'route', arg:'show', exit:0
. 2026.08.23 10:46:26 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'add', arg:'198.54.129.54/32', arg:'via', arg:'64.30.105.254', arg:'dev', arg:'enp5s0', arg:'metric', arg:'0', exit:0
. 2026.08.23 10:46:26 - Routes, add 198.54.129.54/32 for interface "enp5s0".
. 2026.08.23 10:46:26 - Elevated: Command:wireguard
. 2026.08.23 10:46:26 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'address', arg:'add', arg:'10.138.82.129/32', arg:'dev', arg:'Eddie', exit:0
. 2026.08.23 10:46:26 - Elevated: Exec, path:'/sbin/ip', arg:'link', arg:'set', arg:'mtu', arg:'1320', arg:'dev', arg:'Eddie', exit:0
. 2026.08.23 10:46:26 - Elevated: Exec, path:'/sbin/ip', arg:'link', arg:'set', arg:'Eddie', arg:'up', exit:0
. 2026.08.23 10:46:27 - WireGuard > Setup start
. 2026.08.23 10:46:27 - WireGuard > Setup complete
. 2026.08.23 10:46:27 - WireGuard > Setup interface
. 2026.08.23 10:46:28 - WireGuard > Received first handshake
. 2026.08.23 10:46:28 - Elevated: Command:dns-switch-do
. 2026.08.23 10:46:28 - DNS of the system switched to VPN DNS - via /etc/resolv.conf)
. 2026.08.23 10:46:28 - Elevated: Command:route-list
. 2026.08.23 10:46:28 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'show', exit:0, out:'default via 64.30.105.254 dev enp5s0 proto static metric 101
. 2026.08.23 10:46:28 -     10.1.1.0/24 dev enp2s0 proto kernel scope link src 10.1.1.1 metric 100
. 2026.08.23 10:46:28 -     64.30.105.0/24 dev enp5s0 proto kernel scope link src 64.30.105.143 metric 101
. 2026.08.23 10:46:28 -     198.54.129.54 via 64.30.105.254 dev enp5s0'
. 2026.08.23 10:46:28 - Elevated: Exec, path:'/sbin/ip', arg:'-6', arg:'route', arg:'show', exit:0
. 2026.08.23 10:46:28 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'add', arg:'0.0.0.0/1', arg:'dev', arg:'Eddie', arg:'metric', arg:'0', exit:0
. 2026.08.23 10:46:28 - Routes, add 0.0.0.0/1 for interface "Eddie".
. 2026.08.23 10:46:28 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'show', exit:0, out:'0.0.0.0/1 dev Eddie scope link
. 2026.08.23 10:46:28 -     default via 64.30.105.254 dev enp5s0 proto static metric 101
. 2026.08.23 10:46:28 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'add', arg:'128.0.0.0/1', arg:'dev', arg:'Eddie', arg:'metric', arg:'0', exit:0
. 2026.08.23 10:46:28 - Routes, add 128.0.0.0/1 for interface "Eddie".
. 2026.08.23 10:46:28 -     128.0.0.0/1 dev Eddie scope link
. 2026.08.23 10:46:28 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'add', arg:'198.44.129.211/32', arg:'dev', arg:'Eddie', arg:'metric', arg:'0', exit:0
. 2026.08.23 10:46:28 - Routes, add 198.44.129.211/32 for interface "Eddie".
. 2026.08.23 10:46:28 - Routes, skipped for 2607:9000:3000:32:4d59:f15d:aa0b:e9e : IPv6 blocked.
. 2026.08.23 10:46:28 - Flushing DNS
. 2026.08.23 10:46:28 - Elevated: Command:dns-flush
. 2026.08.23 10:46:28 - Elevated: Exec, path:'pidof', arg:'systemd', exit:0, out:'1'
. 2026.08.23 10:46:28 - Elevated: Exec, path:'systemctl', arg:'is-active', arg:'--quiet', arg:'nscd', exit:3
. 2026.08.23 10:46:28 - Elevated: Exec, path:'systemctl', arg:'is-active', arg:'--quiet', arg:'dnsmasq', exit:3
. 2026.08.23 10:46:28 - Elevated: Exec, path:'systemctl', arg:'is-active', arg:'--quiet', arg:'named', exit:3
. 2026.08.23 10:46:28 - Elevated: Exec, path:'systemctl', arg:'is-active', arg:'--quiet', arg:'bind9', exit:3
I 2026.08.23 10:46:28 - Checking DNS
. 2026.08.23 10:46:31 - Elevated: Command:dns-switch-do
. 2026.08.23 10:46:41 - Elevated: Command:dns-switch-do
. 2026.08.23 10:46:51 - Elevated: Command:dns-switch-do
. 2026.08.23 10:47:04 - Above log line repeated 1 times more
. 2026.08.23 10:47:04 - Checking DNS (4° try)
. 2026.08.23 10:47:11 - Elevated: Command:dns-switch-do
. 2026.08.23 10:47:18 - Checking DNS (5° try)
. 2026.08.23 10:47:21 - Elevated: Command:dns-switch-do
E 2026.08.23 10:47:28 - Checking DNS failed, last reason: Fetch url error:Timeout was reached
! 2026.08.23 10:47:28 - Disconnecting
Following along the thought that it was the named-chroot as the issue, I added the AirVPN DNS IP to my resolver list and set the AirVPN configuration for the DNS to manual, but it's still failing. Here are the logs from this attempt. It appears to be failing differently now:
I 2026.08.23 15:12:58 - Session starting.
I 2026.08.23 15:12:58 - Checking authorization ...
. 2026.08.23 15:12:58 - Elevated: Command:ipv6-block
! 2026.08.23 15:12:58 - Connecting to Maia (United States of America, Los Angeles)
. 2026.08.23 15:12:58 - Elevated: Command:route-list
. 2026.08.23 15:12:58 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'show', exit:0, out:'default via 64.30.105.254 dev enp5s0 proto static metric 101
. 2026.08.23 15:12:58 -     10.1.1.0/24 dev enp2s0 proto kernel scope link src 10.1.1.1 metric 100
. 2026.08.23 15:12:58 -     64.30.105.0/24 dev enp5s0 proto kernel scope link src 64.30.105.143 metric 101'
. 2026.08.23 15:12:58 - Elevated: Exec, path:'/sbin/ip', arg:'-6', arg:'route', arg:'show', exit:0
. 2026.08.23 15:12:58 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'add', arg:'198.54.129.54/32', arg:'via', arg:'64.30.105.254', arg:'dev', arg:'enp5s0', arg:'metric', arg:'0', exit:0
. 2026.08.23 15:12:58 - Routes, add 198.54.129.54/32 for interface "enp5s0".
. 2026.08.23 15:12:58 - Elevated: Command:wireguard
. 2026.08.23 15:12:58 - Elevated: Exec, path:'/bin/nmcli', arg:'device', arg:'set', arg:'Eddie', arg:'managed', arg:'no', exit:0
. 2026.08.23 15:12:58 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'address', arg:'add', arg:'10.138.82.129/32', arg:'dev', arg:'Eddie', exit:0
. 2026.08.23 15:12:58 - Elevated: Exec, path:'/sbin/ip', arg:'link', arg:'set', arg:'mtu', arg:'1320', arg:'dev', arg:'Eddie', exit:0
. 2026.08.23 15:12:58 - Elevated: Exec, path:'/sbin/ip', arg:'link', arg:'set', arg:'Eddie', arg:'up', exit:0
. 2026.08.23 15:12:59 - WireGuard > Setup start
. 2026.08.23 15:12:59 - WireGuard > Setup complete
. 2026.08.23 15:12:59 - WireGuard > Setup interface
. 2026.08.23 15:13:00 - WireGuard > Received first handshake
. 2026.08.23 15:13:00 - Elevated: Command:route-list
. 2026.08.23 15:13:00 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'show', exit:0, out:'default via 64.30.105.254 dev enp5s0 proto static metric 101
. 2026.08.23 15:13:00 -     10.1.1.0/24 dev enp2s0 proto kernel scope link src 10.1.1.1 metric 100
. 2026.08.23 15:13:00 -     64.30.105.0/24 dev enp5s0 proto kernel scope link src 64.30.105.143 metric 101
. 2026.08.23 15:13:00 -     198.54.129.54 via 64.30.105.254 dev enp5s0'
. 2026.08.23 15:13:00 - Elevated: Exec, path:'/sbin/ip', arg:'-6', arg:'route', arg:'show', exit:0
. 2026.08.23 15:13:00 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'add', arg:'0.0.0.0/1', arg:'dev', arg:'Eddie', arg:'metric', arg:'0', exit:0
. 2026.08.23 15:13:00 - Routes, add 0.0.0.0/1 for interface "Eddie".
. 2026.08.23 15:13:00 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'show', exit:0, out:'0.0.0.0/1 dev Eddie scope link
. 2026.08.23 15:13:00 -     default via 64.30.105.254 dev enp5s0 proto static metric 101
. 2026.08.23 15:13:00 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'add', arg:'128.0.0.0/1', arg:'dev', arg:'Eddie', arg:'metric', arg:'0', exit:0
. 2026.08.23 15:13:00 - Routes, add 128.0.0.0/1 for interface "Eddie".
. 2026.08.23 15:13:00 -     128.0.0.0/1 dev Eddie scope link
. 2026.08.23 15:13:00 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'add', arg:'198.44.129.211/32', arg:'dev', arg:'Eddie', arg:'metric', arg:'0', exit:0
. 2026.08.23 15:13:00 - Routes, add 198.44.129.211/32 for interface "Eddie".
. 2026.08.23 15:13:00 - Routes, skipped for 2607:9000:3000:32:4d59:f15d:aa0b:e9e : IPv6 blocked.
. 2026.08.23 15:13:00 - Flushing DNS
. 2026.08.23 15:13:00 - Elevated: Command:dns-flush
. 2026.08.23 15:13:00 - Elevated: Exec, path:'/sbin/pidof', arg:'systemd', exit:0, out:'1'
. 2026.08.23 15:13:00 - Elevated: Exec, path:'/bin/systemctl', arg:'is-active', arg:'--quiet', arg:'nscd', exit:3
. 2026.08.23 15:13:00 - Elevated: Exec, path:'/bin/systemctl', arg:'is-active', arg:'--quiet', arg:'dnsmasq', exit:3
. 2026.08.23 15:13:00 - Elevated: Exec, path:'/bin/systemctl', arg:'is-active', arg:'--quiet', arg:'named', exit:3
. 2026.08.23 15:13:00 - Elevated: Exec, path:'/bin/systemctl', arg:'is-active', arg:'--quiet', arg:'bind9', exit:3
I 2026.08.23 15:13:00 - Checking route IPv4
. 2026.08.23 15:13:36 - Checking route (4° try)
. 2026.08.23 15:13:50 - Checking route (5° try)
E 2026.08.23 15:14:00 - Checking route IPv4 failed, last reason: Fetch url error:Timeout was reached
! 2026.08.23 15:14:00 - Disconnecting
. 2026.08.23 15:14:00 - Elevated: Command:wireguard
. 2026.08.23 15:14:00 - WireGuard > Stop request received
. 2026.08.23 15:14:00 - WireGuard > Stopping
. 2026.08.23 15:14:01 - WireGuard > Completed
. 2026.08.23 15:14:01 - Elevated: Command:route-list
. 2026.08.23 15:14:01 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'show', exit:0, out:'default via 64.30.105.254 dev enp5s0 proto static metric 101
. 2026.08.23 15:14:01 -     10.1.1.0/24 dev enp2s0 proto kernel scope link src 10.1.1.1 metric 100
. 2026.08.23 15:14:01 -     64.30.105.0/24 dev enp5s0 proto kernel scope link src 64.30.105.143 metric 101
. 2026.08.23 15:14:01 -     198.54.129.54 via 64.30.105.254 dev enp5s0'
. 2026.08.23 15:14:01 - Elevated: Exec, path:'/sbin/ip', arg:'-6', arg:'route', arg:'show', exit:0
. 2026.08.23 15:14:01 - Routes, delete 0.0.0.0/1 for interface "Eddie", not present.
. 2026.08.23 15:14:01 - Routes, delete 128.0.0.0/1 for interface "Eddie", not present.
. 2026.08.23 15:14:01 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'delete', arg:'198.54.129.54/32', arg:'via', arg:'64.30.105.254', arg:'dev', arg:'enp5s0', arg:'metric', arg:'0', exit:0
. 2026.08.23 15:14:01 - Routes, delete 198.54.129.54/32 for interface "enp5s0".
. 2026.08.23 15:14:01 -     64.30.105.0/24 dev enp5s0 proto kernel scope link src 64.30.105.143 metric 101'
. 2026.08.23 15:14:01 - Routes, delete 198.44.129.211/32 for interface "Eddie", not present.
. 2026.08.23 15:14:01 - Routes, skipped for 2607:9000:3000:32:4d59:f15d:aa0b:e9e : IPv6 blocked.
. 2026.08.23 15:14:01 - Elevated: Command:dns-switch-restore
. 2026.08.23 15:14:01 - Elevated: Exec, path:'/bin/systemctl', arg:'is-active', arg:'--quiet', arg:'systemd-resolved', exit:3
. 2026.08.23 15:14:01 - Collect network information
. 2026.08.23 15:14:01 - Connection terminated.
I 2026.08.23 15:14:04 - Checking authorization ...
. 2026.08.23 15:14:04 - Elevated: Command:ipv6-block
! 2026.08.23 15:14:04 - Connecting to Flegetonte (United States of America, Los Angeles)
. 2026.08.23 15:14:04 - Elevated: Command:route-list
. 2026.08.23 15:14:04 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'show', exit:0, out:'default via 64.30.105.254 dev enp5s0 proto static metric 101
. 2026.08.23 15:14:04 -     10.1.1.0/24 dev enp2s0 proto kernel scope link src 10.1.1.1 metric 100
. 2026.08.23 15:14:04 -     64.30.105.0/24 dev enp5s0 proto kernel scope link src 64.30.105.143 metric 101'
. 2026.08.23 15:14:04 - Elevated: Exec, path:'/sbin/ip', arg:'-6', arg:'route', arg:'show', exit:0
. 2026.08.23 15:14:04 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'add', arg:'198.54.129.117/32', arg:'via', arg:'64.30.105.254', arg:'dev', arg:'enp5s0', arg:'metric', arg:'0', exit:0
. 2026.08.23 15:14:04 - Routes, add 198.54.129.117/32 for interface "enp5s0".
. 2026.08.23 15:14:04 - Elevated: Command:wireguard
. 2026.08.23 15:14:04 - Elevated: Exec, path:'/bin/nmcli', arg:'device', arg:'set', arg:'Eddie', arg:'managed', arg:'no', exit:0
. 2026.08.23 15:14:04 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'address', arg:'add', arg:'10.138.82.129/32', arg:'dev', arg:'Eddie', exit:0
. 2026.08.23 15:14:04 - Elevated: Exec, path:'/sbin/ip', arg:'link', arg:'set', arg:'mtu', arg:'1320', arg:'dev', arg:'Eddie', exit:0
. 2026.08.23 15:14:04 - Elevated: Exec, path:'/sbin/ip', arg:'link', arg:'set', arg:'Eddie', arg:'up', exit:0
. 2026.08.23 15:14:04 - WireGuard > Setup start
. 2026.08.23 15:14:04 - WireGuard > Setup complete
. 2026.08.23 15:14:04 - WireGuard > Setup interface
. 2026.08.23 15:14:05 - WireGuard > Received first handshake
. 2026.08.23 15:14:05 - Elevated: Command:route-list
. 2026.08.23 15:14:05 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'show', exit:0, out:'default via 64.30.105.254 dev enp5s0 proto static metric 101
. 2026.08.23 15:14:05 -     10.1.1.0/24 dev enp2s0 proto kernel scope link src 10.1.1.1 metric 100
. 2026.08.23 15:14:05 -     64.30.105.0/24 dev enp5s0 proto kernel scope link src 64.30.105.143 metric 101
. 2026.08.23 15:14:05 -     198.54.129.117 via 64.30.105.254 dev enp5s0'
. 2026.08.23 15:14:05 - Elevated: Exec, path:'/sbin/ip', arg:'-6', arg:'route', arg:'show', exit:0
. 2026.08.23 15:14:05 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'add', arg:'0.0.0.0/1', arg:'dev', arg:'Eddie', arg:'metric', arg:'0', exit:0
. 2026.08.23 15:14:05 - Routes, add 0.0.0.0/1 for interface "Eddie".
. 2026.08.23 15:14:05 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'show', exit:0, out:'0.0.0.0/1 dev Eddie scope link
. 2026.08.23 15:14:05 -     default via 64.30.105.254 dev enp5s0 proto static metric 101
. 2026.08.23 15:14:05 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'add', arg:'128.0.0.0/1', arg:'dev', arg:'Eddie', arg:'metric', arg:'0', exit:0
. 2026.08.23 15:14:05 - Routes, add 128.0.0.0/1 for interface "Eddie".
. 2026.08.23 15:14:05 -     128.0.0.0/1 dev Eddie scope link
. 2026.08.23 15:14:05 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'add', arg:'198.44.129.3/32', arg:'dev', arg:'Eddie', arg:'metric', arg:'0', exit:0
. 2026.08.23 15:14:05 - Routes, add 198.44.129.3/32 for interface "Eddie".
. 2026.08.23 15:14:05 - Routes, skipped for 2607:9000:300:40:a601:8c52:4a02:f723 : IPv6 blocked.
. 2026.08.23 15:14:05 - Flushing DNS
. 2026.08.23 15:14:05 - Elevated: Command:dns-flush
. 2026.08.23 15:14:05 - Elevated: Exec, path:'/sbin/pidof', arg:'systemd', exit:0, out:'1'
. 2026.08.23 15:14:05 - Elevated: Exec, path:'/bin/systemctl', arg:'is-active', arg:'--quiet', arg:'nscd', exit:3
. 2026.08.23 15:14:05 - Elevated: Exec, path:'/bin/systemctl', arg:'is-active', arg:'--quiet', arg:'dnsmasq', exit:3
. 2026.08.23 15:14:05 - Elevated: Exec, path:'/bin/systemctl', arg:'is-active', arg:'--quiet', arg:'named', exit:3
. 2026.08.23 15:14:06 - Elevated: Exec, path:'/bin/systemctl', arg:'is-active', arg:'--quiet', arg:'bind9', exit:3
I 2026.08.23 15:14:06 - Checking route IPv4
. 2026.08.23 15:14:42 - Checking route (4° try)
. 2026.08.23 15:14:56 - Checking route (5° try)
E 2026.08.23 15:15:06 - Checking route IPv4 failed, last reason: Fetch url error:Timeout was reached
! 2026.08.23 15:15:06 - Disconnecting
. 2026.08.23 15:15:06 - Elevated: Command:wireguard
. 2026.08.23 15:15:06 - WireGuard > Stop request received
. 2026.08.23 15:15:06 - WireGuard > Stopping
. 2026.08.23 15:15:06 - WireGuard > Completed
. 2026.08.23 15:15:06 - Elevated: Command:route-list
. 2026.08.23 15:15:06 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'show', exit:0, out:'default via 64.30.105.254 dev enp5s0 proto static metric 101
. 2026.08.23 15:15:06 -     10.1.1.0/24 dev enp2s0 proto kernel scope link src 10.1.1.1 metric 100
. 2026.08.23 15:15:06 -     64.30.105.0/24 dev enp5s0 proto kernel scope link src 64.30.105.143 metric 101
. 2026.08.23 15:15:06 -     198.54.129.117 via 64.30.105.254 dev enp5s0'
. 2026.08.23 15:15:06 - Elevated: Exec, path:'/sbin/ip', arg:'-6', arg:'route', arg:'show', exit:0
. 2026.08.23 15:15:06 - Routes, delete 0.0.0.0/1 for interface "Eddie", not present.
. 2026.08.23 15:15:06 - Routes, delete 128.0.0.0/1 for interface "Eddie", not present.
. 2026.08.23 15:15:06 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'delete', arg:'198.54.129.117/32', arg:'via', arg:'64.30.105.254', arg:'dev', arg:'enp5s0', arg:'metric', arg:'0', exit:0
. 2026.08.23 15:15:06 - Routes, delete 198.54.129.117/32 for interface "enp5s0".
. 2026.08.23 15:15:06 -     64.30.105.0/24 dev enp5s0 proto kernel scope link src 64.30.105.143 metric 101'
. 2026.08.23 15:15:06 - Routes, delete 198.44.129.3/32 for interface "Eddie", not present.
. 2026.08.23 15:15:06 - Routes, skipped for 2607:9000:300:40:a601:8c52:4a02:f723 : IPv6 blocked.
. 2026.08.23 15:15:06 - Elevated: Command:dns-switch-restore
. 2026.08.23 15:15:07 - Elevated: Exec, path:'/bin/systemctl', arg:'is-active', arg:'--quiet', arg:'systemd-resolved', exit:3
. 2026.08.23 15:15:07 - Collect network information
. 2026.08.23 15:15:07 - Elevated: Command:route-list
. 2026.08.23 15:15:07 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'show', exit:0, out:'default via 64.30.105.254 dev enp5s0 proto static metric 101
. 2026.08.23 15:15:07 -     10.1.1.0/24 dev enp2s0 proto kernel scope link src 10.1.1.1 metric 100
. 2026.08.23 15:15:07 -     64.30.105.0/24 dev enp5s0 proto kernel scope link src 64.30.105.143 metric 101'
. 2026.08.23 15:15:07 - Elevated: Exec, path:'/sbin/ip', arg:'-6', arg:'route', arg:'show', exit:0
. 2026.08.23 15:15:07 - Connection terminated.
I 2026.08.23 15:15:10 - Checking authorization ...
. 2026.08.23 15:15:10 - Elevated: Command:ipv6-block
! 2026.08.23 15:15:10 - Connecting to Revati (United States of America, Los Angeles)
. 2026.08.23 15:15:10 - Elevated: Command:route-list
. 2026.08.23 15:15:10 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'show', exit:0, out:'default via 64.30.105.254 dev enp5s0 proto static metric 101
. 2026.08.23 15:15:10 -     10.1.1.0/24 dev enp2s0 proto kernel scope link src 10.1.1.1 metric 100
. 2026.08.23 15:15:10 -     64.30.105.0/24 dev enp5s0 proto kernel scope link src 64.30.105.143 metric 101'
. 2026.08.23 15:15:10 - Elevated: Exec, path:'/sbin/ip', arg:'-6', arg:'route', arg:'show', exit:0
. 2026.08.23 15:15:10 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'add', arg:'198.54.129.125/32', arg:'via', arg:'64.30.105.254', arg:'dev', arg:'enp5s0', arg:'metric', arg:'0', exit:0
. 2026.08.23 15:15:10 - Routes, add 198.54.129.125/32 for interface "enp5s0".
. 2026.08.23 15:15:10 - Elevated: Command:wireguard
. 2026.08.23 15:15:10 - Elevated: Exec, path:'/bin/nmcli', arg:'device', arg:'set', arg:'Eddie', arg:'managed', arg:'no', exit:0
. 2026.08.23 15:15:10 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'address', arg:'add', arg:'10.138.82.129/32', arg:'dev', arg:'Eddie', exit:0
. 2026.08.23 15:15:10 - Elevated: Exec, path:'/sbin/ip', arg:'link', arg:'set', arg:'mtu', arg:'1320', arg:'dev', arg:'Eddie', exit:0
. 2026.08.23 15:15:10 - Elevated: Exec, path:'/sbin/ip', arg:'link', arg:'set', arg:'Eddie', arg:'up', exit:0
. 2026.08.23 15:15:10 - WireGuard > Setup start
. 2026.08.23 15:15:10 - WireGuard > Setup complete
. 2026.08.23 15:15:10 - WireGuard > Setup interface
. 2026.08.23 15:15:11 - WireGuard > Received first handshake
. 2026.08.23 15:15:12 - Elevated: Command:route-list
. 2026.08.23 15:15:12 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'show', exit:0, out:'default via 64.30.105.254 dev enp5s0 proto static metric 101
. 2026.08.23 15:15:12 -     10.1.1.0/24 dev enp2s0 proto kernel scope link src 10.1.1.1 metric 100
. 2026.08.23 15:15:12 -     64.30.105.0/24 dev enp5s0 proto kernel scope link src 64.30.105.143 metric 101
. 2026.08.23 15:15:12 -     198.54.129.125 via 64.30.105.254 dev enp5s0'
. 2026.08.23 15:15:12 - Elevated: Exec, path:'/sbin/ip', arg:'-6', arg:'route', arg:'show', exit:0
. 2026.08.23 15:15:12 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'add', arg:'0.0.0.0/1', arg:'dev', arg:'Eddie', arg:'metric', arg:'0', exit:0
. 2026.08.23 15:15:13 - Routes, add 0.0.0.0/1 for interface "Eddie".
. 2026.08.23 15:15:13 - Elevated: Command:route-list
. 2026.08.23 15:15:13 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'show', exit:0, out:'0.0.0.0/1 dev Eddie scope link
. 2026.08.23 15:15:13 -     default via 64.30.105.254 dev enp5s0 proto static metric 101
. 2026.08.23 15:15:13 -     10.1.1.0/24 dev enp2s0 proto kernel scope link src 10.1.1.1 metric 100
. 2026.08.23 15:15:13 -     64.30.105.0/24 dev enp5s0 proto kernel scope link src 64.30.105.143 metric 101
. 2026.08.23 15:15:13 -     198.54.129.125 via 64.30.105.254 dev enp5s0'
. 2026.08.23 15:15:13 - Elevated: Exec, path:'/sbin/ip', arg:'-6', arg:'route', arg:'show', exit:0
. 2026.08.23 15:15:13 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'add', arg:'128.0.0.0/1', arg:'dev', arg:'Eddie', arg:'metric', arg:'0', exit:0
. 2026.08.23 15:15:13 - Routes, add 128.0.0.0/1 for interface "Eddie".
. 2026.08.23 15:15:13 -     128.0.0.0/1 dev Eddie scope link
. 2026.08.23 15:15:13 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'add', arg:'198.44.129.243/32', arg:'dev', arg:'Eddie', arg:'metric', arg:'0', exit:0
. 2026.08.23 15:15:13 - Routes, add 198.44.129.243/32 for interface "Eddie".
. 2026.08.23 15:15:13 - Routes, skipped for 2607:9000:3000:38:b26d:18f0:c661:ec18 : IPv6 blocked.
. 2026.08.23 15:15:13 - Flushing DNS
. 2026.08.23 15:15:13 - Elevated: Command:dns-flush
. 2026.08.23 15:15:13 - Elevated: Exec, path:'/sbin/pidof', arg:'systemd', exit:0, out:'1'
. 2026.08.23 15:15:13 - Elevated: Exec, path:'/bin/systemctl', arg:'is-active', arg:'--quiet', arg:'nscd', exit:3
. 2026.08.23 15:15:13 - Elevated: Exec, path:'/bin/systemctl', arg:'is-active', arg:'--quiet', arg:'dnsmasq', exit:3
. 2026.08.23 15:15:13 - Elevated: Exec, path:'/bin/systemctl', arg:'is-active', arg:'--quiet', arg:'named', exit:3
. 2026.08.23 15:15:13 - Elevated: Exec, path:'/bin/systemctl', arg:'is-active', arg:'--quiet', arg:'bind9', exit:3
I 2026.08.23 15:15:13 - Checking route IPv4
! 2026.08.23 15:15:23 - Disconnecting
. 2026.08.23 15:15:23 - Elevated: Command:wireguard
. 2026.08.23 15:15:24 - WireGuard > Stop request received
. 2026.08.23 15:15:24 - WireGuard > Stopping
. 2026.08.23 15:15:24 - WireGuard > Completed
. 2026.08.23 15:15:24 - Elevated: Command:route-list
. 2026.08.23 15:15:24 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'show', exit:0, out:'default via 64.30.105.254 dev enp5s0 proto static metric 101
. 2026.08.23 15:15:24 -     10.1.1.0/24 dev enp2s0 proto kernel scope link src 10.1.1.1 metric 100
. 2026.08.23 15:15:24 -     64.30.105.0/24 dev enp5s0 proto kernel scope link src 64.30.105.143 metric 101
. 2026.08.23 15:15:24 -     198.54.129.125 via 64.30.105.254 dev enp5s0'
. 2026.08.23 15:15:24 - Elevated: Exec, path:'/sbin/ip', arg:'-6', arg:'route', arg:'show', exit:0
. 2026.08.23 15:15:24 - Routes, delete 0.0.0.0/1 for interface "Eddie", not present.
. 2026.08.23 15:15:24 - Routes, delete 128.0.0.0/1 for interface "Eddie", not present.
. 2026.08.23 15:15:24 - Elevated: Exec, path:'/sbin/ip', arg:'-4', arg:'route', arg:'delete', arg:'198.54.129.125/32', arg:'via', arg:'64.30.105.254', arg:'dev', arg:'enp5s0', arg:'metric', arg:'0', exit:0
. 2026.08.23 15:15:24 - Routes, delete 198.54.129.125/32 for interface "enp5s0".
. 2026.08.23 15:15:24 -     64.30.105.0/24 dev enp5s0 proto kernel scope link src 64.30.105.143 metric 101'
. 2026.08.23 15:15:24 - Routes, delete 198.44.129.243/32 for interface "Eddie", not present.
. 2026.08.23 15:15:24 - Routes, skipped for 2607:9000:3000:38:b26d:18f0:c661:ec18 : IPv6 blocked.
. 2026.08.23 15:15:24 - Elevated: Command:dns-switch-restore
. 2026.08.23 15:15:24 - Elevated: Exec, path:'/bin/systemctl', arg:'is-active', arg:'--quiet', arg:'systemd-resolved', exit:3
. 2026.08.23 15:15:24 - Collect network information
. 2026.08.23 15:15:24 - Connection terminated.
I 2026.08.23 15:15:24 - Cancel requested.
! 2026.08.23 15:15:24 - Session terminated.
. 2026.08.23 15:15:24 - Elevated: Command:ping-request
