Not connected, Your IP: 216.73.217.0
filair
WireGuard > Handshake timeout
For a while now, I’ve been getting “WireGuard > Handshake timeout” errors, with the connection dropping and reconnecting several times a day.
This has never happened to me before (I’ve been using AirVPN for several years).
Any ideas?
Try to lower keepalive (in seconds) for Wireguard. It's under Advanced toggle in config generator. It used to be 17s, now 15s. If this doesn't help, then it wasn't the issue.
What device are we talking about? How long do connections persist until this happens? How active is the connection when this happens? Keepalive packet is only used when there has been zero communication for this amount of time.
I am using Wireguard on Android and Linux - my Keepalive is set to 25 seconds.  To be clear this is not using Airvpn for this situation but just commenting that my connection will run as long as I want it to.  Never have I lost the tunnel.
I also use Wireguard via Eddie on my "daily cruiser" computer and it too has never lost the tunnel due to handshake!
