Not connected, Your IP: 216.73.216.172
ExplosiveKoala
VPN works intermittently - Beginner help
Hi everyone, I have installed eddie to mixed results.
Sometimes it works, sometimes it doesn't.
The results are poorly reproducible. Key pattern as follows:
System boots - eddie starts
If VPN connects - works for approximately 3 hours, then issues with connecting to VPN
I then restart PC
- Will sometimes connect, sometimes never connect
So far I have been repeatedly restarting PC until the VPN connects
I have tried changing protocols - seems to make no difference
Please see attached system logs - from an instance where the VPN is working and an instance where the VPN is not working.
Apologies if I am missing something big - I previously just used mullvad/proton - very simple clients. I have little knowledge of networking
working vpn.txt not working vpn log.txt
A couple of things I observed from the "not working" log:
ipv4-default-gateway: 25.255.255.254
interface: ZeroTier Virtual Port
your default route is not your router (192.168.1.1)
it’s your ZeroTier interface
Test DNS IPv6: Failed
Test Ping IPv6: Failed
IPv6 seems broken ...
Looks like a conflict between OpenVPN via Eddie and the ZeroTier virtual networking. Can you temporarily disable ZeroTier and check if you can connect with Eddie?
