Not connected, Your IP: 216.73.217.142
unpar
Eddi UI or Suite installing but not running on ubuntu 24.04.4 LTS Raspberry Pi 5 4gb
Hi! i has been looking another post in the forum but not gettig a idea what it colud be the problem
what is running good in my Ubuntu KDE desktop
I just get a Raspberry PI 5 4 gb and the lastest  official release of ubuntu for rasp 4 gb   avaible ( 24.04.4 LTS ? )  from the official website 24.04.4 LTS
First at all i tried the EDDI UI from this section
https://airvpn.org/linux/eddie/I
( Linux -> ARM64 ( adecuate for Rasp 5 4gb) -->    Eddi Gui-Cli --> Debian -> Grapich UI
.. and apparently it install  goes  well, and the icon appears on the Ubuntu Raspb.
But you click on it and apparently Eddi has no response.
A have read another similiar topics but n idea what could happens.
I tried unistall, and re install but the entire SUITE this time. ( i only undestand the UI not the terminal thing )
And the the Suit apparently is running in the process, but the installed  icon on Ubuntu Rasp  dont lauch the UI interface
Its not a major issue for me, but really would use AirVpn on my Rasp 5 , 4gb as backup pc from time to time
( i dont have much skills on linux terminal )
Any idea ? Thanks !
Hi Again!  i was trying to find a solution by myself "vibecoding"  the thing
I dont know use Linux for real. lolo
But i get this just in case give some clue.
The thing is that when i Try to launch   EDDI -UI  with terminal in  Ubuntu 26.04
i get some error related to    libtiff.so.5
cant remember it terminal show me a error about unable to acces to it, shared, no present on something in this line
After some terminal commads sugested by AI :
Was determined tat My Ubuntu has      libtiff.so.6 (libc6,AArch64) => /usr/lib/aarch64-linux-gnu/libtiff.so.6
A AI told me this :
In Ubuntu 26.04, it’s very likely that libtiff5 is no longer available in the standard repositories, so the problem isn’t that it “needs to be installed,” but rather that the app is requesting an older version. In that case, it’s best to update or reinstall the application, or use a newer version of libgdiplus or the package that includes it.
( reinstal the app didt fix it )
any clue ?
LOLO
i just learned how easy its using the Ubuntu VPN
Downloaded  the offered configuration by AIRVPN
in  https://airvpn.org/generator/
And finally i get VPN on Ubuntu Raspeberry suuuper easy
lolo was so easy the entire time :lol:
