rEpymK0hWF
pfSense WireGuard + AirVPN: tunnel comes up but no handshake (keys correct)
I’m trying to set up an AirVPN WireGuard tunnel on pfSense, but I cannot get a handshake, despite the configuration appearing correct.
Environment
  • pfSense (current release)
  • WireGuard package installed
  • Existing WireGuard tunnel with another provider works correctly (so pfSense + WG itself is functional)
What I’ve done
  • Generated the WireGuard configuration using AirVPN’s Config Generator
  • Created the WireGuard tunnel in pfSense using the provided:
        Private key
        Interface address (/32 as given)
        DNS (also tested without relying on tunnel DNS)
  • Added the peer with:
Correct public key
Endpoint IP and port from AirVPN
Allowed IPs as provided by AirVPN
  • Assigned the WireGuard interface
  • Created firewall rules allowing outbound traffic
  • NAT configured as expected (same approach as my working WG tunnel)
Symptoms
  • Tunnel shows as up
  • No handshake occurs
  • No RX/TX traffic on the WireGuard status page
  • Keys definitely match (regenerated multiple times)
  • Interface address added (though handshake should occur even without it)
What makes this confusing
  • Another WireGuard provider works perfectly on the same pfSense box
  • Same WAN, same firewall/NAT logic
  • AirVPN’s UI no longer shows the older “Devices → WireGuard” workflow, only the config generator
  • The same AirVPN config works when tested with wg-quick on Linux
What I’m wondering
  • Is there anything AirVPN-specific that pfSense requires (MTU, keepalive, endpoint handling)?
  • Any known issues with AirVPN WireGuard peers and pfSense?
  • Does AirVPN require a specific Allowed IPs or gateway configuration that differs from other providers?
If anyone has AirVPN + WireGuard working on pfSense, I’d really appreciate insight into what I might be missing.
Thank you for reading my post.
The other provider you use listens for connections on what port?  Personally I've had ISPs that block wireguard on the ports that AirVPN uses but not on port 80, for example.
Thank you for your feedback.
I am using another VPN provider and have set up three wire-guard tunnels. It works great.
I have decided to try Air-VPN.
They all (my current VPN and Air-VPN) use similar listening ports.
The Air-VPN tunnel peer does not handshake.
Finally, I have been able to use Air-VPN wire-guard to connect from my Linux box without issues. The Linux box is behind the Pfsense firewall.  The problem arises when I try to implement the connection on my Pfsense firewall/router.
Facing exactly the same issue on PfSense 2.8.1 CE. Have Mullvad tunnels working on it OK, with Air, under Status: tunnel shows up, but "Latest handshake": never. Have gone through the process couple of times, but with no avail...
I just connected to three different servers with wireguard configs on pfsense.
Are you using resolved hosts or the domain in the config?  Only thing I can think of considering other VPNs are working for you is if the domain isn't resolvable for you.
Tried several countries, using both with domain names and resolved addresses. Deleted even devices under client area, renewed, etc. The thing is, on my previous setup on pfsense I was able to connect wtih Air+Mullvad. Then after fresh Pfsense install it seems not to work in Air's case, Mullvad is fine.
I'm on pfsense+ 25.07.1.  I'm delaying updating to 25.11 for a bit longer.  Also I'm still using the wireguard package 0.2.9_5 instead of the latest version which is 0.2.11.
