dawgwinfrey
What is my issue based on these logs?
What is my issue based on the logs below...
. 2025.09.20 09:33:05 - Eddie version: 2.24.6 / windows_x64, System: Windows, Name: Windows 10 Home, Version: 10.0.26100.0, Framework: v4.0.30319
. 2025.09.20 09:33:05 - Command line arguments (1): path="home"
. 2025.09.20 09:33:05 - Collect network information
. 2025.09.20 09:33:06 - Reading options from C:\Users\dawgw\AppData\Local\Eddie\default.profile
. 2025.09.20 09:33:07 - OpenVPN - Version: 2.6.12 - OpenSSL 3.3.1 4 Jun 2024, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2025.09.20 09:33:07 - SSH - Version: OpenSSH_for_Windows_9.5p2, LibreSSL 3.8.2 (C:\WINDOWS\System32\OpenSSH\\ssh.exe)
. 2025.09.20 09:33:07 - SSL - Version: 5.69 (C:\Program Files\AirVPN\stunnel.exe)
I 2025.09.20 09:33:08 - Ready
. 2025.09.20 09:33:08 - Collect information about AirVPN completed
I 2025.09.20 09:33:13 - Session starting.
. 2025.09.20 09:33:14 - Activation of Network Lock - Windows Filtering Platform
I 2025.09.20 09:33:14 - Checking authorization ...
! 2025.09.20 09:33:14 - Connecting to Algorab (Sweden, Uppsala)
. 2025.09.20 09:33:15 - Routes, add 62.102.148.198/32 for interface "Ethernet (Realtek Gaming GbE Family Controller)".
. 2025.09.20 09:33:15 - WireGuard > Setup start
. 2025.09.20 09:33:16 - WireGuard > Setup complete
. 2025.09.20 09:33:16 - WireGuard > Starting WireGuard/0.5.3 (Windows 10.0.26100; amd64)
. 2025.09.20 09:33:16 - WireGuard > Watching network interfaces
. 2025.09.20 09:33:16 - WireGuard > Resolving DNS names
. 2025.09.20 09:33:16 - WireGuard > Creating network adapter
. 2025.09.20 09:33:16 - WireGuard > Using existing driver 0.10
. 2025.09.20 09:33:16 - WireGuard > Creating adapter
. 2025.09.20 09:33:16 - WireGuard > Using WireGuardNT/0.10
. 2025.09.20 09:33:16 - WireGuard > Dropping privileges
. 2025.09.20 09:33:16 - WireGuard > Interface created
. 2025.09.20 09:33:16 - WireGuard > Setup interface
. 2025.09.20 09:33:16 - WireGuard > Setting interface configuration
. 2025.09.20 09:33:16 - WireGuard > Peer 1 created
. 2025.09.20 09:33:16 - WireGuard > Setting device v6 addresses
. 2025.09.20 09:33:16 - WireGuard > Interface up
. 2025.09.20 09:33:16 - WireGuard > Setting device v4 addresses
. 2025.09.20 09:33:16 - WireGuard > Startup complete
. 2025.09.20 09:33:26 - WireGuard > Handshake for peer 1 (62.102.148.198:1637) did not complete after 5 seconds, retrying (try 2)
. 2025.09.20 09:33:36 - WireGuard > Handshake for peer 1 (62.102.148.198:1637) did not complete after 5 seconds, retrying (try 2)
. 2025.09.20 09:33:41 - WireGuard > Handshake for peer 1 (62.102.148.198:1637) did not complete after 5 seconds, retrying (try 2)
. 2025.09.20 09:34:07 - Above log line repeated 5 times more
W 2025.09.20 09:34:07 - WireGuard > Handshake timeout
! 2025.09.20 09:34:07 - Disconnecting
. 2025.09.20 09:34:07 - WireGuard > Stop request received
. 2025.09.20 09:34:07 - WireGuard > Stopping
. 2025.09.20 09:34:08 - WireGuard > Completed
. 2025.09.20 09:34:08 - Routes, delete 0.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.09.20 09:34:08 - Routes, delete 128.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.09.20 09:34:09 - Routes, delete ::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.09.20 09:34:09 - Routes, delete 8000::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.09.20 09:34:09 - Routes, delete 62.102.148.198/32 for interface "Ethernet (Realtek Gaming GbE Family Controller)".
. 2025.09.20 09:34:10 - Routes, delete 62.102.148.166/32 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.09.20 09:34:10 - Collect network information
. 2025.09.20 09:34:10 - Connection terminated.
I 2025.09.20 09:34:13 - Checking authorization ...
! 2025.09.20 09:34:14 - Connecting to Musica (Netherlands, Alblasserdam)
. 2025.09.20 09:34:14 - Routes, add 213.152.161.251/32 for interface "Ethernet (Realtek Gaming GbE Family Controller)".
. 2025.09.20 09:34:14 - WireGuard > Setup start
. 2025.09.20 09:34:15 - WireGuard > Setup complete
. 2025.09.20 09:34:15 - WireGuard > Starting WireGuard/0.5.3 (Windows 10.0.26100; amd64)
. 2025.09.20 09:34:15 - WireGuard > Watching network interfaces
. 2025.09.20 09:34:15 - WireGuard > Resolving DNS names
. 2025.09.20 09:34:15 - WireGuard > Creating network adapter
. 2025.09.20 09:34:15 - WireGuard > Using existing driver 0.10
. 2025.09.20 09:34:15 - WireGuard > Creating adapter
. 2025.09.20 09:34:15 - WireGuard > Using WireGuardNT/0.10
. 2025.09.20 09:34:15 - WireGuard > Dropping privileges
. 2025.09.20 09:34:15 - WireGuard > Interface created
. 2025.09.20 09:34:15 - WireGuard > Setup interface
. 2025.09.20 09:34:16 - WireGuard > Setting interface configuration
. 2025.09.20 09:34:16 - WireGuard > Peer 1 created
. 2025.09.20 09:34:16 - WireGuard > Setting device v6 addresses
. 2025.09.20 09:34:16 - WireGuard > Interface up
. 2025.09.20 09:34:16 - WireGuard > Setting device v4 addresses
. 2025.09.20 09:34:16 - WireGuard > Startup complete
