OlDirty 0 Posted ... (edited) Hi everyone, I have a Windows 10 VM on which I use Eddie with a network lock to let all traffic go through AirVPN. This has worked fine for many years already, but a couple weeks ago I've updated my Eddie client to the latest version and since then Eddie constantly disconnects every more or less 3,5 minutes. In between the disconnects, it does work well. Below you can find the log file of my Eddie. Does anyone know how I can resolve this? Thanks Eddie System/Environment Report - 19/05/2025 - 9:05 UTC Eddie version: 2.24.6 Eddie OS build: windows_x64 Eddie architecture: x64 OS type: Windows OS name: Windows 10 Pro OS version: 10.0.19045.0 OS architecture: x64 Framework: v4.0.30319 OpenVPN: 2.6.12 - OpenSSL 3.3.1 4 Jun 2024, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) Hummingbird: Not available WireGuard: 0.10.1 SSH: OpenSSH_for_Windows_9.5p1, LibreSSL 3.8.2 (C:\WINDOWS\System32\OpenSSH\\ssh.exe) SSL: 5.69 (C:\Program Files\AirVPN\stunnel.exe) Profile path: C:\Users\odb\AppData\Local\Eddie\default.profile Data path: C:\Users\odb\AppData\Local\Eddie Application path: C:\Program Files\AirVPN Executable path: C:\Program Files\AirVPN\Eddie-UI.exe Command line arguments: (0 args) Network Lock Active: Yes, Windows Filtering Platform Connected to VPN: Yes, Muscida OS support IPv4: Yes OS support IPv6: Yes Detected DNS: 84.200.69.80,84.200.70.40 Test DNS IPv4: Ok Test DNS IPv6: Ok Test Ping IPv4: 15 ms Test Ping IPv6: 23 ms Test HTTP IPv4: Ok Test HTTP IPv6: Ok Test HTTPS: Ok ---------------------------- Important options not at defaults: login: (omissis) password: (omissis) remember: True connect: True servers.allowlist: e38589d59b2a57483bddbec1edcc2eda610c76040c27d8230290ffe278bec6cf,30bf61cb9977915afbe44dd93309dec19fa92c49976f5ab39296d5e7bda9aba6 servers.startlast: True log.level.debug: True proxy.mode: none routes.custom: 176.9.xx.xx,out,censored;74.118.xx.xx,out,censored;5.196.xx.xx,out,censored;192.168.0.10,out,NAS dns.servers: 84.200.69.80,84.200.70.40 netlock: True netlock.allowlist.incoming.ips: 192.168.0.10 netlock.allowlist.outgoing.ips: 192.168.0.10 advanced.expert: True gui.start_minimized: True gui.exit_confirm: False ---------------------------- Logs: . 2025.05.19 11:00:18 - Elevated: Command:route-list . 2025.05.19 11:00:18 - Elevated: Command:route . 2025.05.19 11:00:18 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 del route prefix="176.9.xx.xx/32" interface="3" nexthop="192.168.0.1" store=active', exit:0, out:'Ok.' . 2025.05.19 11:00:18 - Routes, delete 176.9.xx.xx/32 for interface "Ethernet1 2 (vmxnet3 Ethernet Adapter #2)". . 2025.05.19 11:00:18 - Elevated: Command:route-list . 2025.05.19 11:00:19 - Elevated: Command:route . 2025.05.19 11:00:19 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 del route prefix="74.118.xx.xx/32" interface="3" nexthop="192.168.0.1" store=active', exit:0, out:'Ok.' . 2025.05.19 11:00:19 - Routes, delete 74.118.xx.xx/32 for interface "Ethernet1 2 (vmxnet3 Ethernet Adapter #2)". . 2025.05.19 11:00:19 - Elevated: Command:route-list . 2025.05.19 11:00:19 - Elevated: Command:route . 2025.05.19 11:00:19 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 del route prefix="5.196.xx.xx/32" interface="3" nexthop="192.168.0.1" store=active', exit:0, out:'Ok.' . 2025.05.19 11:00:19 - Routes, delete 5.196.xx.xx/32 for interface "Ethernet1 2 (vmxnet3 Ethernet Adapter #2)". . 2025.05.19 11:00:19 - Elevated: Command:route-list . 2025.05.19 11:00:19 - Elevated: Command:route . 2025.05.19 11:00:19 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 del route prefix="192.168.0.10/32" interface="3" nexthop="192.168.0.1" store=active', exit:0, out:'Ok.' . 2025.05.19 11:00:19 - Routes, delete 192.168.0.10/32 for interface "Ethernet1 2 (vmxnet3 Ethernet Adapter #2)". . 2025.05.19 11:00:19 - Elevated: Command:windows-dns . 2025.05.19 11:00:19 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 set dns name="Eddie" source=dhcp register=primary validate=no', exit:0 . 2025.05.19 11:00:19 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic) . 2025.05.19 11:00:19 - Elevated: Command:windows-dns . 2025.05.19 11:00:19 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 set dns name="Ethernet0 2" source=dhcp register=primary validate=no', exit:0 . 2025.05.19 11:00:19 - DNS IPv4 of a network adapter restored to original settings (Ethernet0 2, to automatic) . 2025.05.19 11:00:19 - Elevated: Command:windows-dns . 2025.05.19 11:00:19 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 set dns name="Ethernet1 2" source=dhcp register=primary validate=no', exit:0 . 2025.05.19 11:00:19 - DNS IPv4 of a network adapter restored to original settings (Ethernet1 2, to automatic) . 2025.05.19 11:00:19 - Elevated: Command:wfp . 2025.05.19 11:00:19 - Elevated: Command:wfp . 2025.05.19 11:00:19 - Elevated: Command:wfp . 2025.05.19 11:00:19 - Above log line repeated 3 times more . 2025.05.19 11:00:19 - DNS leak protection with packet filtering disabled. . 2025.05.19 11:00:19 - Collect network information . 2025.05.19 11:00:19 - Elevated: Command:route-list . 2025.05.19 11:00:19 - Elevated: Command:wfp . 2025.05.19 11:00:19 - Elevated: Command:wfp . 2025.05.19 11:00:19 - Elevated: Command:wfp . 2025.05.19 11:00:19 - Above log line repeated 3 times more . 2025.05.19 11:00:19 - Connection terminated. I 2025.05.19 11:00:22 - Checking authorization ... ! 2025.05.19 11:00:22 - Connecting to Muscida (Netherlands, Alblasserdam) . 2025.05.19 11:00:23 - Elevated: Command:route-list . 2025.05.19 11:00:23 - Elevated: Command:route . 2025.05.19 11:00:23 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add route prefix="213.152.162.156/32" interface="3" nexthop="192.168.0.1" metric=0 store=active', exit:0, out:'Ok.' . 2025.05.19 11:00:23 - Routes, add 213.152.162.156/32 for interface "Ethernet1 2 (vmxnet3 Ethernet Adapter #2)". . 2025.05.19 11:00:23 - Elevated: Command:route-list . 2025.05.19 11:00:23 - Elevated: Command:route . 2025.05.19 11:00:23 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add route prefix="176.9.xx.xx/32" interface="3" nexthop="192.168.0.1" metric=0 store=active', exit:0, out:'Ok.' . 2025.05.19 11:00:23 - Routes, add 176.9.xx.xx/32 for interface "Ethernet1 2 (vmxnet3 Ethernet Adapter #2)". . 2025.05.19 11:00:23 - Elevated: Command:route-list . 2025.05.19 11:00:23 - Elevated: Command:route . 2025.05.19 11:00:23 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add route prefix="74.118.xx.xx/32" interface="3" nexthop="192.168.0.1" metric=0 store=active', exit:0, out:'Ok.' . 2025.05.19 11:00:23 - Routes, add 74.118.xx.xx/32 for interface "Ethernet1 2 (vmxnet3 Ethernet Adapter #2)". . 2025.05.19 11:00:23 - Elevated: Command:route-list . 2025.05.19 11:00:23 - Elevated: Command:route . 2025.05.19 11:00:23 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add route prefix="5.196.xx.xx/32" interface="3" nexthop="192.168.0.1" metric=0 store=active', exit:0, out:'Ok.' . 2025.05.19 11:00:23 - Routes, add 5.196.xx.xx/32 for interface "Ethernet1 2 (vmxnet3 Ethernet Adapter #2)". . 2025.05.19 11:00:23 - Elevated: Command:route-list . 2025.05.19 11:00:23 - Elevated: Command:route . 2025.05.19 11:00:23 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add route prefix="192.168.0.10/32" interface="3" nexthop="192.168.0.1" metric=0 store=active', exit:0, out:'Ok.' . 2025.05.19 11:00:23 - Routes, add 192.168.0.10/32 for interface "Ethernet1 2 (vmxnet3 Ethernet Adapter #2)". . 2025.05.19 11:00:23 - Elevated: Command:wireguard . 2025.05.19 11:00:23 - WireGuard > Setup start . 2025.05.19 11:00:24 - WireGuard > Setup complete . 2025.05.19 11:00:24 - WireGuard > Starting WireGuard/0.5.3 (Windows 10.0.19045; amd64) . 2025.05.19 11:00:24 - WireGuard > Watching network interfaces . 2025.05.19 11:00:24 - WireGuard > Resolving DNS names . 2025.05.19 11:00:24 - WireGuard > Creating network adapter . 2025.05.19 11:00:24 - WireGuard > Using existing driver 0.10 . 2025.05.19 11:00:24 - WireGuard > Creating adapter . 2025.05.19 11:00:24 - WireGuard > Using WireGuardNT/0.10 . 2025.05.19 11:00:24 - WireGuard > Dropping privileges . 2025.05.19 11:00:24 - WireGuard > Setup interface . 2025.05.19 11:00:24 - Elevated: Command:wfp . 2025.05.19 11:00:24 - Elevated: Command:wfp . 2025.05.19 11:00:24 - Elevated: Command:wfp . 2025.05.19 11:00:24 - Above log line repeated 3 times more . 2025.05.19 11:00:24 - WireGuard > Setting interface configuration . 2025.05.19 11:00:24 - WireGuard > Interface created . 2025.05.19 11:00:24 - WireGuard > Peer 1 created . 2025.05.19 11:00:24 - WireGuard > Setting device v4 addresses . 2025.05.19 11:00:24 - WireGuard > Interface up . 2025.05.19 11:00:24 - WireGuard > Received first handshake . 2025.05.19 11:00:24 - Interface Eddie metric changed from Automatic to 3, layer IPv4 . 2025.05.19 11:00:24 - Elevated: Command:set-interface-metric . 2025.05.19 11:00:24 - Interface Eddie metric changed from Automatic to 3, layer IPv6 . 2025.05.19 11:00:24 - Elevated: Command:set-interface-metric . 2025.05.19 11:00:24 - Elevated: Command:wfp . 2025.05.19 11:00:24 - Elevated: Command:wfp . 2025.05.19 11:00:24 - Elevated: Command:wfp . 2025.05.19 11:00:24 - Above log line repeated 3 times more . 2025.05.19 11:00:24 - DNS leak protection with packet filtering enabled. . 2025.05.19 11:00:24 - Elevated: Command:route-list . 2025.05.19 11:00:24 - Elevated: Command:windows-dns . 2025.05.19 11:00:24 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 set dns name="Eddie" source=static address=84.200.69.80 register=primary validate=no', exit:0 . 2025.05.19 11:00:24 - Elevated: Command:windows-dns . 2025.05.19 11:00:25 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add dnsserver name="Eddie" address=84.200.70.40 validate=no', exit:0 . 2025.05.19 11:00:25 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 84.200.69.80,84.200.70.40) . 2025.05.19 11:00:25 - Elevated: Command:windows-dns . 2025.05.19 11:00:25 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 set dns name="Ethernet0 2" source=static address=84.200.69.80 register=primary validate=no', exit:0 . 2025.05.19 11:00:25 - Elevated: Command:windows-dns . 2025.05.19 11:00:25 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add dnsserver name="Ethernet0 2" address=84.200.70.40 validate=no', exit:0 . 2025.05.19 11:00:25 - DNS IPv4 of a network adapter forced (Ethernet0 2, from automatic to 84.200.69.80,84.200.70.40) . 2025.05.19 11:00:25 - Elevated: Command:windows-dns . 2025.05.19 11:00:25 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 set dns name="Ethernet1 2" source=static address=84.200.69.80 register=primary validate=no', exit:0 . 2025.05.19 11:00:25 - Elevated: Command:windows-dns . 2025.05.19 11:00:25 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add dnsserver name="Ethernet1 2" address=84.200.70.40 validate=no', exit:0 . 2025.05.19 11:00:25 - DNS IPv4 of a network adapter forced (Ethernet1 2, from automatic to 84.200.69.80,84.200.70.40) . 2025.05.19 11:00:25 - Elevated: Command:route-list . 2025.05.19 11:00:25 - Elevated: Command:route . 2025.05.19 11:00:25 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add route prefix="0.0.0.0/1" interface="46" metric=0 store=active', exit:0, out:'Ok.' . 2025.05.19 11:00:25 - Routes, add 0.0.0.0/1 for interface "Eddie (WireGuard Tunnel)". . 2025.05.19 11:00:25 - Elevated: Command:route-list . 2025.05.19 11:00:25 - Elevated: Command:route . 2025.05.19 11:00:25 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add route prefix="128.0.0.0/1" interface="46" metric=0 store=active', exit:0, out:'Ok.' . 2025.05.19 11:00:25 - Routes, add 128.0.0.0/1 for interface "Eddie (WireGuard Tunnel)". . 2025.05.19 11:00:25 - Elevated: Command:route-list . 2025.05.19 11:00:25 - Elevated: Command:route . 2025.05.19 11:00:25 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv6 add route prefix="::/1" interface="46" metric=0 store=active', exit:0, out:'Ok.' . 2025.05.19 11:00:25 - Routes, add ::/1 for interface "Eddie (WireGuard Tunnel)". . 2025.05.19 11:00:25 - Elevated: Command:route-list . 2025.05.19 11:00:25 - Elevated: Command:route . 2025.05.19 11:00:25 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv6 add route prefix="8000::/1" interface="46" metric=0 store=active', exit:0, out:'Ok.' . 2025.05.19 11:00:25 - Routes, add 8000::/1 for interface "Eddie (WireGuard Tunnel)". . 2025.05.19 11:00:26 - Elevated: Command:route-list . 2025.05.19 11:00:26 - Elevated: Command:route . 2025.05.19 11:00:26 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add route prefix="213.152.162.154/32" interface="46" metric=0 store=active', exit:0, out:'Ok.' . 2025.05.19 11:00:26 - Routes, add 213.152.162.154/32 for interface "Eddie (WireGuard Tunnel)". . 2025.05.19 11:00:26 - Elevated: Command:route-list . 2025.05.19 11:00:26 - Routes, add 2a00:1678:2470:5:3568:e603:2b4d:aeb6/128 for interface "Eddie (WireGuard Tunnel)", already exists. . 2025.05.19 11:00:26 - Flushing DNS . 2025.05.19 11:00:26 - Elevated: Command:dns-flush . 2025.05.19 11:00:26 - Elevated: Exec, path:'C:\WINDOWS\system32\ipconfig.exe', arg:'/flushdns', exit:0, out:'Windows IP Configuration . 2025.05.19 11:00:26 - Successfully flushed the DNS Resolver Cache.' . 2025.05.19 11:00:26 - Exec(1135) of 'C:\WINDOWS\system32\ipconfig.exe', 1 args: '/flushdns'; . 2025.05.19 11:00:26 - Exec(1135) done in 31 ms, exit: 0, out: 'Windows IP Configuration . 2025.05.19 11:00:26 - Successfully flushed the DNS Resolver Cache.' I 2025.05.19 11:00:26 - Checking route IPv4 I 2025.05.19 11:00:26 - Checking route IPv6 . 2025.05.19 11:00:26 - Collect network information . 2025.05.19 11:00:26 - Elevated: Command:route-list ! 2025.05.19 11:00:26 - Connected. . 2025.05.19 11:00:26 - WireGuard > Invalid handshake response from 213.152.162.156:1637 . 2025.05.19 11:00:26 - WireGuard > Setting device v6 addresses . 2025.05.19 11:00:26 - WireGuard > Startup complete . 2025.05.19 11:00:26 - WireGuard > Packet has invalid nonce 0 (max 2) . 2025.05.19 11:00:26 - WireGuard > Packet has invalid nonce 1 (max 2) . 2025.05.19 11:00:26 - WireGuard > Packet has invalid nonce 2 (max 3) . 2025.05.19 11:00:26 - WireGuard > Packet has invalid nonce 3 (max 4) . 2025.05.19 11:00:26 - WireGuard > Packet has invalid nonce 4 (max 6) . 2025.05.19 11:00:26 - WireGuard > Packet has invalid nonce 5 (max 6) . 2025.05.19 11:00:29 - WireGuard > 16421 log lines swallowed by rate limiting . 2025.05.19 11:00:29 - WireGuard > Packet has invalid nonce 17993 (max 17994) . 2025.05.19 11:00:29 - WireGuard > Packet has invalid nonce 17994 (max 17995) . 2025.05.19 11:00:29 - WireGuard > Packet has invalid nonce 17995 (max 17996) . 2025.05.19 11:00:29 - WireGuard > Packet has invalid nonce 17996 (max 17997) . 2025.05.19 11:00:29 - WireGuard > Packet has invalid nonce 17997 (max 17998) . 2025.05.19 11:00:29 - WireGuard > Packet has invalid nonce 17998 (max 17999) . 2025.05.19 11:00:29 - WireGuard > Packet has invalid nonce 17999 (max 18000) . 2025.05.19 11:00:29 - WireGuard > Packet has invalid nonce 18000 (max 18002) . 2025.05.19 11:00:29 - WireGuard > Packet has invalid nonce 18001 (max 18002) . 2025.05.19 11:00:29 - WireGuard > Packet has invalid nonce 18002 (max 18005) . 2025.05.19 11:00:29 - WireGuard > Packet has invalid nonce 18003 (max 18005) . 2025.05.19 11:00:34 - WireGuard > 34250 log lines swallowed by rate limiting . 2025.05.19 11:00:34 - WireGuard > Packet has invalid nonce 60129 (max 60133) . 2025.05.19 11:00:34 - WireGuard > Packet has invalid nonce 60130 (max 60133) . 2025.05.19 11:00:34 - WireGuard > Packet has invalid nonce 60131 (max 60135) . 2025.05.19 11:00:34 - WireGuard > Packet has invalid nonce 60133 (max 60135) . 2025.05.19 11:00:34 - WireGuard > Packet has invalid nonce 60134 (max 60135) . 2025.05.19 11:00:34 - WireGuard > Packet has invalid nonce 60135 (max 60137) . 2025.05.19 11:00:34 - WireGuard > Packet has invalid nonce 60136 (max 60137) . 2025.05.19 11:00:34 - WireGuard > Packet has invalid nonce 60137 (max 60139) . 2025.05.19 11:00:34 - WireGuard > Packet has invalid nonce 60138 (max 60139) . 2025.05.19 11:00:34 - WireGuard > Packet has invalid nonce 60139 (max 60140) . 2025.05.19 11:00:34 - WireGuard > Packet has invalid nonce 60140 (max 60142) . 2025.05.19 11:00:39 - WireGuard > 34422 log lines swallowed by rate limiting . 2025.05.19 11:00:39 - WireGuard > Packet has invalid nonce 100207 (max 100217) . 2025.05.19 11:00:39 - WireGuard > Packet has invalid nonce 100208 (max 100217) . 2025.05.19 11:00:39 - WireGuard > Packet has invalid nonce 100209 (max 100217) . 2025.05.19 11:00:39 - WireGuard > Packet has invalid nonce 100210 (max 100217) . 2025.05.19 11:00:39 - WireGuard > Packet has invalid nonce 100211 (max 100217) . 2025.05.19 11:00:39 - WireGuard > Packet has invalid nonce 100212 (max 100217) . 2025.05.19 11:00:39 - WireGuard > Packet has invalid nonce 100213 (max 100217) . 2025.05.19 11:00:39 - WireGuard > Packet has invalid nonce 100214 (max 100217) . 2025.05.19 11:00:39 - WireGuard > Packet has invalid nonce 100215 (max 100217) . 2025.05.19 11:00:39 - WireGuard > Packet has invalid nonce 100216 (max 100217) . 2025.05.19 11:00:39 - WireGuard > Packet has invalid nonce 100217 (max 100227) . 2025.05.19 11:00:44 - WireGuard > 41953 log lines swallowed by rate limiting . 2025.05.19 11:00:44 - WireGuard > Packet has invalid nonce 148828 (max 148829) . 2025.05.19 11:00:44 - WireGuard > Packet has invalid nonce 148827 (max 148830) . 2025.05.19 11:00:44 - WireGuard > Packet has invalid nonce 148829 (max 148830) . 2025.05.19 11:00:44 - WireGuard > Packet has invalid nonce 148830 (max 148835) . 2025.05.19 11:00:44 - WireGuard > Packet has invalid nonce 148831 (max 148835) . 2025.05.19 11:00:44 - WireGuard > Packet has invalid nonce 148832 (max 148835) . 2025.05.19 11:00:44 - WireGuard > Packet has invalid nonce 148833 (max 148835) . 2025.05.19 11:00:44 - WireGuard > Packet has invalid nonce 148834 (max 148835) . 2025.05.19 11:00:44 - WireGuard > Packet has invalid nonce 148835 (max 148837) . 2025.05.19 11:00:44 - WireGuard > Packet has invalid nonce 148836 (max 148837) . 2025.05.19 11:00:44 - WireGuard > Packet has invalid nonce 148837 (max 148838) . 2025.05.19 11:00:49 - WireGuard > 33314 log lines swallowed by rate limiting . 2025.05.19 11:00:49 - WireGuard > Packet has invalid nonce 182867 (max 182868) . 2025.05.19 11:00:49 - WireGuard > Packet has invalid nonce 182868 (max 182871) . 2025.05.19 11:00:49 - WireGuard > Packet has invalid nonce 182869 (max 182871) . 2025.05.19 11:00:49 - WireGuard > Packet has invalid nonce 182870 (max 182871) . 2025.05.19 11:00:49 - WireGuard > Packet has invalid nonce 182871 (max 182872) . 2025.05.19 11:00:49 - WireGuard > Packet has invalid nonce 182872 (max 182873) . 2025.05.19 11:00:49 - WireGuard > Packet has invalid nonce 182873 (max 182875) . 2025.05.19 11:00:49 - WireGuard > Packet has invalid nonce 182874 (max 182875) . 2025.05.19 11:00:49 - WireGuard > Packet has invalid nonce 182875 (max 182877) . 2025.05.19 11:00:49 - WireGuard > Packet has invalid nonce 182876 (max 182877) . 2025.05.19 11:00:49 - WireGuard > Packet has invalid nonce 182877 (max 182878) . 2025.05.19 11:00:54 - WireGuard > 37980 log lines swallowed by rate limiting . 2025.05.19 11:00:54 - WireGuard > Packet has invalid nonce 227915 (max 227923) . 2025.05.19 11:00:54 - WireGuard > Packet has invalid nonce 227916 (max 227923) . 2025.05.19 11:00:54 - WireGuard > Packet has invalid nonce 227917 (max 227923) . 2025.05.19 11:00:54 - WireGuard > Packet has invalid nonce 227918 (max 227923) . 2025.05.19 11:00:54 - WireGuard > Packet has invalid nonce 227919 (max 227923) . 2025.05.19 11:00:54 - WireGuard > Packet has invalid nonce 227922 (max 227923) . 2025.05.19 11:00:54 - WireGuard > Packet has invalid nonce 227923 (max 227931) . 2025.05.19 11:00:54 - WireGuard > Packet has invalid nonce 227924 (max 227931) . 2025.05.19 11:00:54 - WireGuard > Packet has invalid nonce 227925 (max 227931) . 2025.05.19 11:00:54 - WireGuard > Packet has invalid nonce 227926 (max 227931) . 2025.05.19 11:00:54 - WireGuard > Packet has invalid nonce 227927 (max 227931) . 2025.05.19 11:00:59 - WireGuard > 41837 log lines swallowed by rate limiting . 2025.05.19 11:00:59 - WireGuard > Packet has invalid nonce 276819 (max 276829) . 2025.05.19 11:00:59 - WireGuard > Packet has invalid nonce 276820 (max 276829) . 2025.05.19 11:00:59 - WireGuard > Packet has invalid nonce 276821 (max 276829) . 2025.05.19 11:00:59 - WireGuard > Packet has invalid nonce 276822 (max 276829) . 2025.05.19 11:00:59 - WireGuard > Packet has invalid nonce 276823 (max 276829) . 2025.05.19 11:00:59 - WireGuard > Packet has invalid nonce 276824 (max 276829) . 2025.05.19 11:00:59 - WireGuard > Packet has invalid nonce 276825 (max 276829) . 2025.05.19 11:00:59 - WireGuard > Packet has invalid nonce 276826 (max 276829) . 2025.05.19 11:00:59 - WireGuard > Packet has invalid nonce 276827 (max 276829) . 2025.05.19 11:00:59 - WireGuard > Packet has invalid nonce 276828 (max 276829) . 2025.05.19 11:00:59 - WireGuard > Packet has invalid nonce 276829 (max 276832) . 2025.05.19 11:01:04 - WireGuard > 44497 log lines swallowed by rate limiting . 2025.05.19 11:01:04 - WireGuard > Packet has invalid nonce 323704 (max 323711) . 2025.05.19 11:01:04 - WireGuard > Packet has invalid nonce 323705 (max 323711) . 2025.05.19 11:01:04 - WireGuard > Packet has invalid nonce 323706 (max 323711) . 2025.05.19 11:01:04 - WireGuard > Packet has invalid nonce 323707 (max 323711) . 2025.05.19 11:01:04 - WireGuard > Packet has invalid nonce 323708 (max 323711) . 2025.05.19 11:01:04 - WireGuard > Packet has invalid nonce 323709 (max 323711) . 2025.05.19 11:01:04 - WireGuard > Packet has invalid nonce 323710 (max 323711) . 2025.05.19 11:01:04 - WireGuard > Packet has invalid nonce 323711 (max 323712) . 2025.05.19 11:01:04 - WireGuard > Packet has invalid nonce 323712 (max 323714) . 2025.05.19 11:01:04 - WireGuard > Packet has invalid nonce 323713 (max 323714) . 2025.05.19 11:01:04 - WireGuard > Packet has invalid nonce 323714 (max 323716) . 2025.05.19 11:01:09 - WireGuard > 44272 log lines swallowed by rate limiting . 2025.05.19 11:01:09 - WireGuard > Packet has invalid nonce 369717 (max 369727) . 2025.05.19 11:01:09 - WireGuard > Packet has invalid nonce 369718 (max 369727) . 2025.05.19 11:01:09 - WireGuard > Packet has invalid nonce 369719 (max 369727) . 2025.05.19 11:01:09 - WireGuard > Packet has invalid nonce 369720 (max 369727) . 2025.05.19 11:01:09 - WireGuard > Packet has invalid nonce 369721 (max 369727) . 2025.05.19 11:01:09 - WireGuard > Packet has invalid nonce 369722 (max 369727) . 2025.05.19 11:01:09 - WireGuard > Packet has invalid nonce 369723 (max 369727) . 2025.05.19 11:01:09 - WireGuard > Packet has invalid nonce 369724 (max 369727) . 2025.05.19 11:01:09 - WireGuard > Packet has invalid nonce 369725 (max 369727) . 2025.05.19 11:01:09 - WireGuard > Packet has invalid nonce 369726 (max 369727) . 2025.05.19 11:01:09 - WireGuard > Packet has invalid nonce 369727 (max 369737) . 2025.05.19 11:01:14 - WireGuard > 45168 log lines swallowed by rate limiting . 2025.05.19 11:01:14 - WireGuard > Packet has invalid nonce 415627 (max 415631) . 2025.05.19 11:01:14 - WireGuard > Packet has invalid nonce 415628 (max 415631) . 2025.05.19 11:01:14 - WireGuard > Packet has invalid nonce 415629 (max 415631) . 2025.05.19 11:01:14 - WireGuard > Packet has invalid nonce 415630 (max 415631) . 2025.05.19 11:01:14 - WireGuard > Packet has invalid nonce 415631 (max 415636) . 2025.05.19 11:01:14 - WireGuard > Packet has invalid nonce 415632 (max 415636) . 2025.05.19 11:01:14 - WireGuard > Packet has invalid nonce 415633 (max 415636) . 2025.05.19 11:01:14 - WireGuard > Packet has invalid nonce 415634 (max 415636) . 2025.05.19 11:01:14 - WireGuard > Packet has invalid nonce 415635 (max 415636) . 2025.05.19 11:01:14 - WireGuard > Packet has invalid nonce 415636 (max 415637) . 2025.05.19 11:01:14 - WireGuard > Packet has invalid nonce 415637 (max 415639) . 2025.05.19 11:01:19 - WireGuard > 44482 log lines swallowed by rate limiting . 2025.05.19 11:01:19 - WireGuard > Packet has invalid nonce 461781 (max 461793) . 2025.05.19 11:01:19 - WireGuard > Packet has invalid nonce 461782 (max 461793) . 2025.05.19 11:01:19 - WireGuard > Packet has invalid nonce 461783 (max 461793) . 2025.05.19 11:01:19 - WireGuard > Packet has invalid nonce 461785 (max 461793) . 2025.05.19 11:01:19 - WireGuard > Packet has invalid nonce 461786 (max 461793) . 2025.05.19 11:01:19 - WireGuard > Packet has invalid nonce 461784 (max 461793) . 2025.05.19 11:01:19 - WireGuard > Packet has invalid nonce 461787 (max 461793) . 2025.05.19 11:01:19 - WireGuard > Packet has invalid nonce 461788 (max 461793) . 2025.05.19 11:01:19 - WireGuard > Packet has invalid nonce 461792 (max 461793) . 2025.05.19 11:01:19 - WireGuard > Packet has invalid nonce 461789 (max 461793) . 2025.05.19 11:01:19 - WireGuard > Packet has invalid nonce 461793 (max 461801) . 2025.05.19 11:01:24 - WireGuard > 40880 log lines swallowed by rate limiting . 2025.05.19 11:01:24 - WireGuard > Packet has invalid nonce 505212 (max 505222) . 2025.05.19 11:01:24 - WireGuard > Packet has invalid nonce 505213 (max 505222) . 2025.05.19 11:01:24 - WireGuard > Packet has invalid nonce 505214 (max 505222) . 2025.05.19 11:01:24 - WireGuard > Packet has invalid nonce 505215 (max 505222) . 2025.05.19 11:01:24 - WireGuard > Packet has invalid nonce 505216 (max 505222) . 2025.05.19 11:01:24 - WireGuard > Packet has invalid nonce 505217 (max 505222) . 2025.05.19 11:01:24 - WireGuard > Packet has invalid nonce 505218 (max 505222) . 2025.05.19 11:01:24 - WireGuard > Packet has invalid nonce 505219 (max 505222) . 2025.05.19 11:01:24 - WireGuard > Packet has invalid nonce 505220 (max 505222) . 2025.05.19 11:01:24 - WireGuard > Packet has invalid nonce 505221 (max 505222) . 2025.05.19 11:01:24 - WireGuard > Packet has invalid nonce 505222 (max 505223) . 2025.05.19 11:01:29 - WireGuard > 43269 log lines swallowed by rate limiting . 2025.05.19 11:01:29 - WireGuard > Packet has invalid nonce 551356 (max 551358) . 2025.05.19 11:01:29 - WireGuard > Packet has invalid nonce 551357 (max 551358) . 2025.05.19 11:01:29 - WireGuard > Packet has invalid nonce 551358 (max 551361) . 2025.05.19 11:01:29 - WireGuard > Packet has invalid nonce 551359 (max 551361) . 2025.05.19 11:01:29 - WireGuard > Packet has invalid nonce 551360 (max 551361) . 2025.05.19 11:01:29 - WireGuard > Packet has invalid nonce 551361 (max 551373) . 2025.05.19 11:01:29 - WireGuard > Packet has invalid nonce 551370 (max 551373) . 2025.05.19 11:01:29 - WireGuard > Packet has invalid nonce 551371 (max 551373) . 2025.05.19 11:01:29 - WireGuard > Packet has invalid nonce 551372 (max 551373) . 2025.05.19 11:01:29 - WireGuard > Packet has invalid nonce 551378 (max 551380) . 2025.05.19 11:01:29 - WireGuard > Packet has invalid nonce 551379 (max 551380) . 2025.05.19 11:01:34 - WireGuard > 41630 log lines swallowed by rate limiting . 2025.05.19 11:01:34 - WireGuard > Packet has invalid nonce 597108 (max 597110) . 2025.05.19 11:01:34 - WireGuard > Packet has invalid nonce 597109 (max 597110) . 2025.05.19 11:01:34 - WireGuard > Packet has invalid nonce 597110 (max 597114) . 2025.05.19 11:01:34 - WireGuard > Packet has invalid nonce 597111 (max 597114) . 2025.05.19 11:01:34 - WireGuard > Packet has invalid nonce 597112 (max 597114) . 2025.05.19 11:01:34 - WireGuard > Packet has invalid nonce 597113 (max 597114) . 2025.05.19 11:01:34 - WireGuard > Packet has invalid nonce 597114 (max 597118) . 2025.05.19 11:01:34 - WireGuard > Packet has invalid nonce 597115 (max 597118) . 2025.05.19 11:01:34 - WireGuard > Packet has invalid nonce 597116 (max 597118) . 2025.05.19 11:01:34 - WireGuard > Packet has invalid nonce 597117 (max 597118) . 2025.05.19 11:01:34 - WireGuard > Packet has invalid nonce 597118 (max 597120) . 2025.05.19 11:01:39 - WireGuard > 41866 log lines swallowed by rate limiting . 2025.05.19 11:01:39 - WireGuard > Packet has invalid nonce 642551 (max 642552) . 2025.05.19 11:01:39 - WireGuard > Packet has invalid nonce 642552 (max 642553) . 2025.05.19 11:01:39 - WireGuard > Packet has invalid nonce 642553 (max 642554) . 2025.05.19 11:01:39 - WireGuard > Packet has invalid nonce 642554 (max 642555) . 2025.05.19 11:01:39 - WireGuard > Packet has invalid nonce 642555 (max 642556) . 2025.05.19 11:01:39 - WireGuard > Packet has invalid nonce 642556 (max 642559) . 2025.05.19 11:01:39 - WireGuard > Packet has invalid nonce 642557 (max 642559) . 2025.05.19 11:01:39 - WireGuard > Packet has invalid nonce 642558 (max 642559) . 2025.05.19 11:01:39 - WireGuard > Packet has invalid nonce 642559 (max 642564) . 2025.05.19 11:01:39 - WireGuard > Packet has invalid nonce 642560 (max 642564) . 2025.05.19 11:01:39 - WireGuard > Packet has invalid nonce 642561 (max 642564) . 2025.05.19 11:01:44 - WireGuard > 39618 log lines swallowed by rate limiting . 2025.05.19 11:01:44 - WireGuard > Packet has invalid nonce 688164 (max 688169) . 2025.05.19 11:01:44 - WireGuard > Packet has invalid nonce 688165 (max 688169) . 2025.05.19 11:01:44 - WireGuard > Packet has invalid nonce 688166 (max 688169) . 2025.05.19 11:01:44 - WireGuard > Packet has invalid nonce 688167 (max 688169) . 2025.05.19 11:01:44 - WireGuard > Packet has invalid nonce 688168 (max 688169) . 2025.05.19 11:01:44 - WireGuard > Packet has invalid nonce 688169 (max 688175) . 2025.05.19 11:01:44 - WireGuard > Packet has invalid nonce 688170 (max 688175) . 2025.05.19 11:01:44 - WireGuard > Packet has invalid nonce 688171 (max 688175) . 2025.05.19 11:01:44 - WireGuard > Packet has invalid nonce 688172 (max 688175) . 2025.05.19 11:01:44 - WireGuard > Packet has invalid nonce 688173 (max 688175) . 2025.05.19 11:01:44 - WireGuard > Packet has invalid nonce 688174 (max 688175) . 2025.05.19 11:01:49 - WireGuard > 37767 log lines swallowed by rate limiting . 2025.05.19 11:01:49 - WireGuard > Packet has invalid nonce 730548 (max 730549) . 2025.05.19 11:01:49 - WireGuard > Packet has invalid nonce 730547 (max 730549) . 2025.05.19 11:01:49 - WireGuard > Packet has invalid nonce 730549 (max 730550) . 2025.05.19 11:01:49 - WireGuard > Packet has invalid nonce 730550 (max 730552) . 2025.05.19 11:01:49 - WireGuard > Packet has invalid nonce 730551 (max 730552) . 2025.05.19 11:01:49 - WireGuard > Packet has invalid nonce 730552 (max 730553) . 2025.05.19 11:01:49 - WireGuard > Packet has invalid nonce 730553 (max 730554) . 2025.05.19 11:01:49 - WireGuard > Packet has invalid nonce 730554 (max 730555) . 2025.05.19 11:01:49 - WireGuard > Packet has invalid nonce 730555 (max 730557) . 2025.05.19 11:01:49 - WireGuard > Packet has invalid nonce 730556 (max 730557) . 2025.05.19 11:01:49 - WireGuard > Packet has invalid nonce 730557 (max 730558) . 2025.05.19 11:01:54 - WireGuard > 37521 log lines swallowed by rate limiting . 2025.05.19 11:01:54 - WireGuard > Packet has invalid nonce 772450 (max 772451) . 2025.05.19 11:01:54 - WireGuard > Packet has invalid nonce 772451 (max 772452) . 2025.05.19 11:01:54 - WireGuard > Packet has invalid nonce 772452 (max 772455) . 2025.05.19 11:01:54 - WireGuard > Packet has invalid nonce 772454 (max 772455) . 2025.05.19 11:01:54 - WireGuard > Packet has invalid nonce 772455 (max 772466) . 2025.05.19 11:01:54 - WireGuard > Packet has invalid nonce 772456 (max 772466) . 2025.05.19 11:01:54 - WireGuard > Packet has invalid nonce 772458 (max 772466) . 2025.05.19 11:01:54 - WireGuard > Packet has invalid nonce 772459 (max 772466) . 2025.05.19 11:01:54 - WireGuard > Packet has invalid nonce 772460 (max 772466) . 2025.05.19 11:01:54 - WireGuard > Packet has invalid nonce 772461 (max 772466) . 2025.05.19 11:01:54 - WireGuard > Packet has invalid nonce 772457 (max 772466) . 2025.05.19 11:01:59 - WireGuard > 39043 log lines swallowed by rate limiting . 2025.05.19 11:01:59 - WireGuard > Packet has invalid nonce 815844 (max 815848) . 2025.05.19 11:01:59 - WireGuard > Packet has invalid nonce 815846 (max 815848) . 2025.05.19 11:01:59 - WireGuard > Packet has invalid nonce 815847 (max 815848) . 2025.05.19 11:01:59 - WireGuard > Packet has invalid nonce 815848 (max 815853) . 2025.05.19 11:01:59 - WireGuard > Packet has invalid nonce 815849 (max 815853) . 2025.05.19 11:01:59 - WireGuard > Packet has invalid nonce 815850 (max 815853) . 2025.05.19 11:01:59 - WireGuard > Packet has invalid nonce 815851 (max 815853) . 2025.05.19 11:01:59 - WireGuard > Packet has invalid nonce 815852 (max 815853) . 2025.05.19 11:01:59 - WireGuard > Packet has invalid nonce 815854 (max 815856) . 2025.05.19 11:01:59 - WireGuard > Packet has invalid nonce 815855 (max 815856) . 2025.05.19 11:01:59 - WireGuard > Packet has invalid nonce 815856 (max 815858) . 2025.05.19 11:02:04 - WireGuard > 39237 log lines swallowed by rate limiting . 2025.05.19 11:02:04 - WireGuard > Packet has invalid nonce 858002 (max 858005) . 2025.05.19 11:02:04 - WireGuard > Packet has invalid nonce 858003 (max 858005) . 2025.05.19 11:02:04 - WireGuard > Packet has invalid nonce 858004 (max 858005) . 2025.05.19 11:02:04 - WireGuard > Packet has invalid nonce 858005 (max 858010) . 2025.05.19 11:02:04 - WireGuard > Packet has invalid nonce 858006 (max 858010) . 2025.05.19 11:02:04 - WireGuard > Packet has invalid nonce 858007 (max 858010) . 2025.05.19 11:02:04 - WireGuard > Packet has invalid nonce 858008 (max 858010) . 2025.05.19 11:02:04 - WireGuard > Packet has invalid nonce 858009 (max 858010) . 2025.05.19 11:02:04 - WireGuard > Packet has invalid nonce 858010 (max 858013) . 2025.05.19 11:02:04 - WireGuard > Packet has invalid nonce 858011 (max 858013) . 2025.05.19 11:02:04 - WireGuard > Packet has invalid nonce 858012 (max 858013) . 2025.05.19 11:02:09 - WireGuard > 39492 log lines swallowed by rate limiting . 2025.05.19 11:02:09 - WireGuard > Packet has invalid nonce 899812 (max 899815) . 2025.05.19 11:02:09 - WireGuard > Packet has invalid nonce 899813 (max 899815) . 2025.05.19 11:02:09 - WireGuard > Packet has invalid nonce 899814 (max 899815) . 2025.05.19 11:02:09 - WireGuard > Packet has invalid nonce 899815 (max 899817) . 2025.05.19 11:02:09 - WireGuard > Packet has invalid nonce 899816 (max 899817) . 2025.05.19 11:02:09 - WireGuard > Packet has invalid nonce 899817 (max 899820) . 2025.05.19 11:02:09 - WireGuard > Packet has invalid nonce 899818 (max 899820) . 2025.05.19 11:02:09 - WireGuard > Packet has invalid nonce 899819 (max 899820) . 2025.05.19 11:02:09 - WireGuard > Packet has invalid nonce 899820 (max 899821) . 2025.05.19 11:02:09 - WireGuard > Packet has invalid nonce 899821 (max 899829) . 2025.05.19 11:02:09 - WireGuard > Packet has invalid nonce 899822 (max 899829) . 2025.05.19 11:02:14 - WireGuard > 40133 log lines swallowed by rate limiting . 2025.05.19 11:02:14 - WireGuard > Packet has invalid nonce 942753 (max 942759) . 2025.05.19 11:02:14 - WireGuard > Packet has invalid nonce 942754 (max 942759) . 2025.05.19 11:02:14 - WireGuard > Packet has invalid nonce 942755 (max 942759) . 2025.05.19 11:02:14 - WireGuard > Packet has invalid nonce 942756 (max 942759) . 2025.05.19 11:02:14 - WireGuard > Packet has invalid nonce 942757 (max 942759) . 2025.05.19 11:02:14 - WireGuard > Packet has invalid nonce 942758 (max 942759) . 2025.05.19 11:02:14 - WireGuard > Packet has invalid nonce 942759 (max 942761) . 2025.05.19 11:02:14 - WireGuard > Packet has invalid nonce 942760 (max 942761) . 2025.05.19 11:02:14 - WireGuard > Packet has invalid nonce 942761 (max 942763) . 2025.05.19 11:02:14 - WireGuard > Packet has invalid nonce 942762 (max 942763) . 2025.05.19 11:02:14 - WireGuard > Packet has invalid nonce 942763 (max 942767) . 2025.05.19 11:02:19 - WireGuard > 39457 log lines swallowed by rate limiting . 2025.05.19 11:02:19 - WireGuard > Packet has invalid nonce 985905 (max 985915) . 2025.05.19 11:02:19 - WireGuard > Packet has invalid nonce 985906 (max 985915) . 2025.05.19 11:02:19 - WireGuard > Packet has invalid nonce 985907 (max 985915) . 2025.05.19 11:02:19 - WireGuard > Packet has invalid nonce 985908 (max 985915) . 2025.05.19 11:02:19 - WireGuard > Packet has invalid nonce 985909 (max 985915) . 2025.05.19 11:02:19 - WireGuard > Packet has invalid nonce 985910 (max 985915) . 2025.05.19 11:02:19 - WireGuard > Packet has invalid nonce 985911 (max 985915) . 2025.05.19 11:02:19 - WireGuard > Packet has invalid nonce 985912 (max 985915) . 2025.05.19 11:02:19 - WireGuard > Packet has invalid nonce 985913 (max 985915) . 2025.05.19 11:02:19 - WireGuard > Packet has invalid nonce 985914 (max 985915) . 2025.05.19 11:02:19 - WireGuard > Packet has invalid nonce 985915 (max 985925) . 2025.05.19 11:02:24 - WireGuard > 40048 log lines swallowed by rate limiting . 2025.05.19 11:02:24 - WireGuard > Packet has invalid nonce 1029816 (max 1029818) . 2025.05.19 11:02:24 - WireGuard > Packet has invalid nonce 1029817 (max 1029818) . 2025.05.19 11:02:24 - WireGuard > Packet has invalid nonce 1029818 (max 1029819) . 2025.05.19 11:02:24 - WireGuard > Packet has invalid nonce 1029819 (max 1029822) . 2025.05.19 11:02:24 - WireGuard > Packet has invalid nonce 1029820 (max 1029822) . 2025.05.19 11:02:24 - WireGuard > Packet has invalid nonce 1029821 (max 1029822) . 2025.05.19 11:02:24 - WireGuard > Packet has invalid nonce 1029822 (max 1029824) . 2025.05.19 11:02:24 - WireGuard > Packet has invalid nonce 1029823 (max 1029824) . 2025.05.19 11:02:24 - WireGuard > Packet has invalid nonce 1029824 (max 1029830) . 2025.05.19 11:02:24 - WireGuard > Packet has invalid nonce 1029826 (max 1029830) . 2025.05.19 11:02:24 - WireGuard > Packet has invalid nonce 1029825 (max 1029830) . 2025.05.19 11:02:29 - WireGuard > 40607 log lines swallowed by rate limiting . 2025.05.19 11:02:29 - WireGuard > Packet has invalid nonce 44991 (max 44992) . 2025.05.19 11:02:29 - WireGuard > Packet has invalid nonce 44992 (max 44995) . 2025.05.19 11:02:29 - WireGuard > Packet has invalid nonce 44993 (max 44995) . 2025.05.19 11:02:29 - WireGuard > Packet has invalid nonce 44994 (max 44995) . 2025.05.19 11:02:29 - WireGuard > Packet has invalid nonce 44995 (max 45004) . 2025.05.19 11:02:29 - WireGuard > Packet has invalid nonce 44996 (max 45004) . 2025.05.19 11:02:29 - WireGuard > Packet has invalid nonce 44998 (max 45004) . 2025.05.19 11:02:29 - WireGuard > Packet has invalid nonce 44999 (max 45004) . 2025.05.19 11:02:29 - WireGuard > Packet has invalid nonce 45000 (max 45004) . 2025.05.19 11:02:29 - WireGuard > Packet has invalid nonce 45001 (max 45004) . 2025.05.19 11:02:29 - WireGuard > Packet has invalid nonce 45002 (max 45004) . 2025.05.19 11:02:34 - WireGuard > 40144 log lines swallowed by rate limiting . 2025.05.19 11:02:34 - WireGuard > Packet has invalid nonce 88598 (max 88599) . 2025.05.19 11:02:34 - WireGuard > Packet has invalid nonce 88599 (max 88602) . 2025.05.19 11:02:34 - WireGuard > Packet has invalid nonce 88600 (max 88602) . 2025.05.19 11:02:34 - WireGuard > Packet has invalid nonce 88601 (max 88602) . 2025.05.19 11:02:34 - WireGuard > Packet has invalid nonce 88602 (max 88604) . 2025.05.19 11:02:34 - WireGuard > Packet has invalid nonce 88603 (max 88604) . 2025.05.19 11:02:34 - WireGuard > Packet has invalid nonce 88604 (max 88608) . 2025.05.19 11:02:34 - WireGuard > Packet has invalid nonce 88605 (max 88608) . 2025.05.19 11:02:34 - WireGuard > Packet has invalid nonce 88606 (max 88608) . 2025.05.19 11:02:34 - WireGuard > Packet has invalid nonce 88607 (max 88608) . 2025.05.19 11:02:34 - WireGuard > Packet has invalid nonce 88608 (max 88612) . 2025.05.19 11:02:39 - WireGuard > 39465 log lines swallowed by rate limiting . 2025.05.19 11:02:39 - WireGuard > Packet has invalid nonce 130629 (max 130630) . 2025.05.19 11:02:39 - WireGuard > Packet has invalid nonce 130630 (max 130633) . 2025.05.19 11:02:39 - WireGuard > Packet has invalid nonce 130631 (max 130633) . 2025.05.19 11:02:39 - WireGuard > Packet has invalid nonce 130632 (max 130633) . 2025.05.19 11:02:39 - WireGuard > Packet has invalid nonce 130633 (max 130636) . 2025.05.19 11:02:39 - WireGuard > Packet has invalid nonce 130634 (max 130636) . 2025.05.19 11:02:39 - WireGuard > Packet has invalid nonce 130635 (max 130636) . 2025.05.19 11:02:39 - WireGuard > Packet has invalid nonce 130636 (max 130639) . 2025.05.19 11:02:39 - WireGuard > Packet has invalid nonce 130637 (max 130639) . 2025.05.19 11:02:39 - WireGuard > Packet has invalid nonce 130638 (max 130639) . 2025.05.19 11:02:39 - WireGuard > Packet has invalid nonce 130639 (max 130642) . 2025.05.19 11:02:44 - WireGuard > 37649 log lines swallowed by rate limiting . 2025.05.19 11:02:44 - WireGuard > Packet has invalid nonce 170202 (max 170208) . 2025.05.19 11:02:44 - WireGuard > Packet has invalid nonce 170203 (max 170208) . 2025.05.19 11:02:44 - WireGuard > Packet has invalid nonce 170204 (max 170208) . 2025.05.19 11:02:44 - WireGuard > Packet has invalid nonce 170205 (max 170208) . 2025.05.19 11:02:44 - WireGuard > Packet has invalid nonce 170206 (max 170208) . 2025.05.19 11:02:44 - WireGuard > Packet has invalid nonce 170207 (max 170208) . 2025.05.19 11:02:44 - WireGuard > Packet has invalid nonce 170208 (max 170210) . 2025.05.19 11:02:44 - WireGuard > Packet has invalid nonce 170209 (max 170210) . 2025.05.19 11:02:44 - WireGuard > Packet has invalid nonce 170210 (max 170213) . 2025.05.19 11:02:44 - WireGuard > Packet has invalid nonce 170211 (max 170213) . 2025.05.19 11:02:44 - WireGuard > Packet has invalid nonce 170212 (max 170213) . 2025.05.19 11:02:49 - WireGuard > 37061 log lines swallowed by rate limiting . 2025.05.19 11:02:49 - WireGuard > Packet has invalid nonce 211116 (max 211117) . 2025.05.19 11:02:49 - WireGuard > Packet has invalid nonce 211117 (max 211118) . 2025.05.19 11:02:49 - WireGuard > Packet has invalid nonce 211118 (max 211119) . 2025.05.19 11:02:49 - WireGuard > Packet has invalid nonce 211119 (max 211120) . 2025.05.19 11:02:49 - WireGuard > Packet has invalid nonce 211120 (max 211126) . 2025.05.19 11:02:49 - WireGuard > Packet has invalid nonce 211121 (max 211126) . 2025.05.19 11:02:49 - WireGuard > Packet has invalid nonce 211122 (max 211126) . 2025.05.19 11:02:49 - WireGuard > Packet has invalid nonce 211123 (max 211126) . 2025.05.19 11:02:49 - WireGuard > Packet has invalid nonce 211124 (max 211126) . 2025.05.19 11:02:49 - WireGuard > Packet has invalid nonce 211125 (max 211126) . 2025.05.19 11:02:49 - WireGuard > Packet has invalid nonce 211126 (max 211128) . 2025.05.19 11:02:54 - WireGuard > 36700 log lines swallowed by rate limiting . 2025.05.19 11:02:54 - WireGuard > Packet has invalid nonce 250943 (max 250944) . 2025.05.19 11:02:54 - WireGuard > Packet has invalid nonce 250944 (max 250946) . 2025.05.19 11:02:54 - WireGuard > Packet has invalid nonce 250945 (max 250946) . 2025.05.19 11:02:54 - WireGuard > Packet has invalid nonce 250946 (max 250947) . 2025.05.19 11:02:54 - WireGuard > Packet has invalid nonce 250947 (max 250952) . 2025.05.19 11:02:54 - WireGuard > Packet has invalid nonce 250948 (max 250952) . 2025.05.19 11:02:54 - WireGuard > Packet has invalid nonce 250949 (max 250952) . 2025.05.19 11:02:54 - WireGuard > Packet has invalid nonce 250950 (max 250952) . 2025.05.19 11:02:54 - WireGuard > Packet has invalid nonce 250951 (max 250952) . 2025.05.19 11:02:54 - WireGuard > Packet has invalid nonce 250952 (max 250954) . 2025.05.19 11:02:54 - WireGuard > Packet has invalid nonce 250953 (max 250954) . 2025.05.19 11:02:59 - WireGuard > 37447 log lines swallowed by rate limiting . 2025.05.19 11:02:59 - WireGuard > Packet has invalid nonce 292611 (max 292615) . 2025.05.19 11:02:59 - WireGuard > Packet has invalid nonce 292612 (max 292615) . 2025.05.19 11:02:59 - WireGuard > Packet has invalid nonce 292613 (max 292615) . 2025.05.19 11:02:59 - WireGuard > Packet has invalid nonce 292614 (max 292615) . 2025.05.19 11:02:59 - WireGuard > Packet has invalid nonce 292615 (max 292617) . 2025.05.19 11:02:59 - WireGuard > Packet has invalid nonce 292616 (max 292617) . 2025.05.19 11:02:59 - WireGuard > Packet has invalid nonce 292617 (max 292622) . 2025.05.19 11:02:59 - WireGuard > Packet has invalid nonce 292618 (max 292622) . 2025.05.19 11:02:59 - WireGuard > Packet has invalid nonce 292619 (max 292622) . 2025.05.19 11:02:59 - WireGuard > Packet has invalid nonce 292620 (max 292622) . 2025.05.19 11:02:59 - WireGuard > Packet has invalid nonce 292621 (max 292622) . 2025.05.19 11:03:04 - WireGuard > 36384 log lines swallowed by rate limiting . 2025.05.19 11:03:04 - WireGuard > Packet has invalid nonce 332826 (max 332829) . 2025.05.19 11:03:04 - WireGuard > Packet has invalid nonce 332827 (max 332829) . 2025.05.19 11:03:04 - WireGuard > Packet has invalid nonce 332828 (max 332829) . 2025.05.19 11:03:04 - WireGuard > Packet has invalid nonce 332829 (max 332835) . 2025.05.19 11:03:04 - WireGuard > Packet has invalid nonce 332830 (max 332835) . 2025.05.19 11:03:04 - WireGuard > Packet has invalid nonce 332831 (max 332835) . 2025.05.19 11:03:04 - WireGuard > Packet has invalid nonce 332832 (max 332835) . 2025.05.19 11:03:04 - WireGuard > Packet has invalid nonce 332833 (max 332835) . 2025.05.19 11:03:04 - WireGuard > Packet has invalid nonce 332834 (max 332835) . 2025.05.19 11:03:04 - WireGuard > Packet has invalid nonce 332835 (max 332845) . 2025.05.19 11:03:04 - WireGuard > Packet has invalid nonce 332836 (max 332845) . 2025.05.19 11:03:09 - WireGuard > 35803 log lines swallowed by rate limiting . 2025.05.19 11:03:09 - WireGuard > Packet has invalid nonce 371622 (max 371628) . 2025.05.19 11:03:09 - WireGuard > Packet has invalid nonce 371623 (max 371628) . 2025.05.19 11:03:09 - WireGuard > Packet has invalid nonce 371624 (max 371628) . 2025.05.19 11:03:09 - WireGuard > Packet has invalid nonce 371626 (max 371628) . 2025.05.19 11:03:09 - WireGuard > Packet has invalid nonce 371627 (max 371628) . 2025.05.19 11:03:09 - WireGuard > Packet has invalid nonce 371628 (max 371629) . 2025.05.19 11:03:09 - WireGuard > Packet has invalid nonce 371630 (max 371638) . 2025.05.19 11:03:09 - WireGuard > Packet has invalid nonce 371631 (max 371638) . 2025.05.19 11:03:09 - WireGuard > Packet has invalid nonce 371632 (max 371638) . 2025.05.19 11:03:09 - WireGuard > Packet has invalid nonce 371633 (max 371638) . 2025.05.19 11:03:09 - WireGuard > Packet has invalid nonce 371635 (max 371638) . 2025.05.19 11:03:14 - WireGuard > 37236 log lines swallowed by rate limiting . 2025.05.19 11:03:14 - WireGuard > Packet has invalid nonce 412661 (max 412664) . 2025.05.19 11:03:14 - WireGuard > Packet has invalid nonce 412662 (max 412664) . 2025.05.19 11:03:14 - WireGuard > Packet has invalid nonce 412663 (max 412664) . 2025.05.19 11:03:14 - WireGuard > Packet has invalid nonce 412664 (max 412667) . 2025.05.19 11:03:14 - WireGuard > Packet has invalid nonce 412665 (max 412667) . 2025.05.19 11:03:14 - WireGuard > Packet has invalid nonce 412666 (max 412667) . 2025.05.19 11:03:14 - WireGuard > Packet has invalid nonce 412667 (max 412670) . 2025.05.19 11:03:14 - WireGuard > Packet has invalid nonce 412668 (max 412670) . 2025.05.19 11:03:14 - WireGuard > Packet has invalid nonce 412669 (max 412670) . 2025.05.19 11:03:14 - WireGuard > Packet has invalid nonce 412670 (max 412675) . 2025.05.19 11:03:14 - WireGuard > Packet has invalid nonce 412671 (max 412675) . 2025.05.19 11:03:19 - WireGuard > 37455 log lines swallowed by rate limiting . 2025.05.19 11:03:19 - WireGuard > Packet has invalid nonce 452329 (max 452338) . 2025.05.19 11:03:19 - WireGuard > Packet has invalid nonce 452330 (max 452338) . 2025.05.19 11:03:19 - WireGuard > Packet has invalid nonce 452331 (max 452338) . 2025.05.19 11:03:19 - WireGuard > Packet has invalid nonce 452332 (max 452338) . 2025.05.19 11:03:19 - WireGuard > Packet has invalid nonce 452333 (max 452338) . 2025.05.19 11:03:19 - WireGuard > Packet has invalid nonce 452334 (max 452338) . 2025.05.19 11:03:19 - WireGuard > Packet has invalid nonce 452335 (max 452338) . 2025.05.19 11:03:19 - WireGuard > Packet has invalid nonce 452336 (max 452338) . 2025.05.19 11:03:19 - WireGuard > Packet has invalid nonce 452337 (max 452338) . 2025.05.19 11:03:19 - WireGuard > Packet has invalid nonce 452338 (max 452341) . 2025.05.19 11:03:19 - WireGuard > Packet has invalid nonce 452340 (max 452341) . 2025.05.19 11:03:24 - WireGuard > 38026 log lines swallowed by rate limiting . 2025.05.19 11:03:24 - WireGuard > Packet has invalid nonce 492713 (max 492723) . 2025.05.19 11:03:24 - WireGuard > Packet has invalid nonce 492714 (max 492723) . 2025.05.19 11:03:24 - WireGuard > Packet has invalid nonce 492715 (max 492723) . 2025.05.19 11:03:24 - WireGuard > Packet has invalid nonce 492716 (max 492723) . 2025.05.19 11:03:24 - WireGuard > Packet has invalid nonce 492717 (max 492723) . 2025.05.19 11:03:24 - WireGuard > Packet has invalid nonce 492718 (max 492723) . 2025.05.19 11:03:24 - WireGuard > Packet has invalid nonce 492719 (max 492723) . 2025.05.19 11:03:24 - WireGuard > Packet has invalid nonce 492720 (max 492723) . 2025.05.19 11:03:24 - WireGuard > Packet has invalid nonce 492721 (max 492723) . 2025.05.19 11:03:24 - WireGuard > Packet has invalid nonce 492722 (max 492723) . 2025.05.19 11:03:24 - WireGuard > Packet has invalid nonce 492723 (max 492733) . 2025.05.19 11:03:29 - WireGuard > 38904 log lines swallowed by rate limiting . 2025.05.19 11:03:29 - WireGuard > Packet has invalid nonce 534012 (max 534013) . 2025.05.19 11:03:29 - WireGuard > Packet has invalid nonce 534013 (max 534014) . 2025.05.19 11:03:29 - WireGuard > Packet has invalid nonce 534014 (max 534015) . 2025.05.19 11:03:29 - WireGuard > Packet has invalid nonce 534015 (max 534016) . 2025.05.19 11:03:29 - WireGuard > Packet has invalid nonce 534016 (max 534017) . 2025.05.19 11:03:29 - WireGuard > Packet has invalid nonce 534017 (max 534018) . 2025.05.19 11:03:29 - WireGuard > Packet has invalid nonce 534018 (max 534020) . 2025.05.19 11:03:29 - WireGuard > Packet has invalid nonce 534019 (max 534020) . 2025.05.19 11:03:29 - WireGuard > Packet has invalid nonce 534020 (max 534021) . 2025.05.19 11:03:29 - WireGuard > Packet has invalid nonce 534021 (max 534023) . 2025.05.19 11:03:29 - WireGuard > Packet has invalid nonce 534022 (max 534023) . 2025.05.19 11:03:34 - WireGuard > 38435 log lines swallowed by rate limiting . 2025.05.19 11:03:34 - WireGuard > Packet has invalid nonce 574397 (max 574398) . 2025.05.19 11:03:34 - WireGuard > Packet has invalid nonce 574398 (max 574401) . 2025.05.19 11:03:34 - WireGuard > Packet has invalid nonce 574399 (max 574401) . 2025.05.19 11:03:34 - WireGuard > Packet has invalid nonce 574400 (max 574401) . 2025.05.19 11:03:34 - WireGuard > Packet has invalid nonce 574401 (max 574403) . 2025.05.19 11:03:34 - WireGuard > Packet has invalid nonce 574402 (max 574403) . 2025.05.19 11:03:34 - WireGuard > Packet has invalid nonce 574403 (max 574405) . 2025.05.19 11:03:34 - WireGuard > Packet has invalid nonce 574404 (max 574405) . 2025.05.19 11:03:34 - WireGuard > Packet has invalid nonce 574405 (max 574407) . 2025.05.19 11:03:34 - WireGuard > Packet has invalid nonce 574406 (max 574407) . 2025.05.19 11:03:34 - WireGuard > Packet has invalid nonce 574407 (max 574411) . 2025.05.19 11:03:39 - WireGuard > 37494 log lines swallowed by rate limiting . 2025.05.19 11:03:39 - WireGuard > Packet has invalid nonce 615148 (max 615158) . 2025.05.19 11:03:39 - WireGuard > Packet has invalid nonce 615149 (max 615158) . 2025.05.19 11:03:39 - WireGuard > Packet has invalid nonce 615150 (max 615158) . 2025.05.19 11:03:39 - WireGuard > Packet has invalid nonce 615151 (max 615158) . 2025.05.19 11:03:39 - WireGuard > Packet has invalid nonce 615152 (max 615158) . 2025.05.19 11:03:39 - WireGuard > Packet has invalid nonce 615153 (max 615158) . 2025.05.19 11:03:39 - WireGuard > Packet has invalid nonce 615154 (max 615158) . 2025.05.19 11:03:39 - WireGuard > Packet has invalid nonce 615155 (max 615158) . 2025.05.19 11:03:39 - WireGuard > Packet has invalid nonce 615156 (max 615158) . 2025.05.19 11:03:39 - WireGuard > Packet has invalid nonce 615157 (max 615158) . 2025.05.19 11:03:39 - WireGuard > Packet has invalid nonce 615158 (max 615168) . 2025.05.19 11:03:44 - WireGuard > 36764 log lines swallowed by rate limiting . 2025.05.19 11:03:44 - WireGuard > Packet has invalid nonce 655214 (max 655215) . 2025.05.19 11:03:44 - WireGuard > Packet has invalid nonce 655215 (max 655216) . 2025.05.19 11:03:44 - WireGuard > Packet has invalid nonce 655216 (max 655220) . 2025.05.19 11:03:44 - WireGuard > Packet has invalid nonce 655217 (max 655220) . 2025.05.19 11:03:44 - WireGuard > Packet has invalid nonce 655218 (max 655220) . 2025.05.19 11:03:44 - WireGuard > Packet has invalid nonce 655219 (max 655220) . 2025.05.19 11:03:44 - WireGuard > Packet has invalid nonce 655220 (max 655223) . 2025.05.19 11:03:44 - WireGuard > Packet has invalid nonce 655221 (max 655223) . 2025.05.19 11:03:44 - WireGuard > Packet has invalid nonce 655222 (max 655223) . 2025.05.19 11:03:44 - WireGuard > Packet has invalid nonce 655223 (max 655225) . 2025.05.19 11:03:44 - WireGuard > Packet has invalid nonce 655224 (max 655225) W 2025.05.19 11:03:45 - WireGuard > Handshake timeout ! 2025.05.19 11:03:45 - Disconnecting . 2025.05.19 11:03:45 - Elevated: Command:wireguard . 2025.05.19 11:03:45 - WireGuard > Stop request received . 2025.05.19 11:03:45 - WireGuard > Stopping . 2025.05.19 11:03:46 - WireGuard > Completed . 2025.05.19 11:03:46 - Elevated: Command:route-list . 2025.05.19 11:03:46 - Routes, delete 0.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists. . 2025.05.19 11:03:46 - Elevated: Command:route-list . 2025.05.19 11:03:46 - Routes, delete 128.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists. . 2025.05.19 11:03:46 - Elevated: Command:route-list . 2025.05.19 11:03:46 - Routes, delete ::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists. . 2025.05.19 11:03:46 - Elevated: Command:route-list . 2025.05.19 11:03:46 - Routes, delete 8000::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists. . 2025.05.19 11:03:46 - Elevated: Command:route-list . 2025.05.19 11:03:46 - Elevated: Command:route . 2025.05.19 11:03:46 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 del route prefix="213.152.162.156/32" interface="3" nexthop="192.168.0.1" store=active', exit:0, out:'Ok.' . 2025.05.19 11:03:46 - Routes, delete 213.152.162.156/32 for interface "Ethernet1 2 (vmxnet3 Ethernet Adapter #2)". . 2025.05.19 11:03:46 - Elevated: Command:route-list . 2025.05.19 11:03:46 - Routes, delete 213.152.162.154/32 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists. . 2025.05.19 11:03:46 - Elevated: Command:route-list . 2025.05.19 11:03:46 - Elevated: Command:route-list . 2025.05.19 11:03:46 - Elevated: Command:route . 2025.05.19 11:03:46 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 del route prefix="176.9.xx.xx/32" interface="3" nexthop="192.168.0.1" store=active', exit:0, out:'Ok.' . 2025.05.19 11:03:46 - Routes, delete 176.9.xx.xx/32 for interface "Ethernet1 2 (vmxnet3 Ethernet Adapter #2)". . 2025.05.19 11:03:46 - Elevated: Command:route-list . 2025.05.19 11:03:46 - Elevated: Command:route . 2025.05.19 11:03:47 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 del route prefix="74.118.xx.xx/32" interface="3" nexthop="192.168.0.1" store=active', exit:0, out:'Ok.' . 2025.05.19 11:03:47 - Routes, delete 74.118.xx.xx/32 for interface "Ethernet1 2 (vmxnet3 Ethernet Adapter #2)". . 2025.05.19 11:03:47 - Elevated: Command:route-list . 2025.05.19 11:03:47 - Elevated: Command:route . 2025.05.19 11:03:47 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 del route prefix="5.196.xx.xx/32" interface="3" nexthop="192.168.0.1" store=active', exit:0, out:'Ok.' . 2025.05.19 11:03:47 - Routes, delete 5.196.xx.xx/32 for interface "Ethernet1 2 (vmxnet3 Ethernet Adapter #2)". . 2025.05.19 11:03:47 - Elevated: Command:route-list . 2025.05.19 11:03:47 - Elevated: Command:route . 2025.05.19 11:03:47 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 del route prefix="192.168.0.10/32" interface="3" nexthop="192.168.0.1" store=active', exit:0, out:'Ok.' . 2025.05.19 11:03:47 - Routes, delete 192.168.0.10/32 for interface "Ethernet1 2 (vmxnet3 Ethernet Adapter #2)". . 2025.05.19 11:03:47 - Elevated: Command:windows-dns . 2025.05.19 11:03:47 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 set dns name="Eddie" source=dhcp register=primary validate=no', exit:0 . 2025.05.19 11:03:47 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic) . 2025.05.19 11:03:47 - Elevated: Command:windows-dns . 2025.05.19 11:03:47 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 set dns name="Ethernet0 2" source=dhcp register=primary validate=no', exit:0 . 2025.05.19 11:03:47 - DNS IPv4 of a network adapter restored to original settings (Ethernet0 2, to automatic) . 2025.05.19 11:03:47 - Elevated: Command:windows-dns . 2025.05.19 11:03:47 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 set dns name="Ethernet1 2" source=dhcp register=primary validate=no', exit:0 . 2025.05.19 11:03:47 - DNS IPv4 of a network adapter restored to original settings (Ethernet1 2, to automatic) . 2025.05.19 11:03:47 - Elevated: Command:wfp . 2025.05.19 11:03:47 - Elevated: Command:wfp . 2025.05.19 11:03:47 - Elevated: Command:wfp . 2025.05.19 11:03:47 - Above log line repeated 3 times more . 2025.05.19 11:03:47 - DNS leak protection with packet filtering disabled. . 2025.05.19 11:03:47 - Collect network information . 2025.05.19 11:03:47 - Elevated: Command:route-list . 2025.05.19 11:03:47 - Elevated: Command:wfp . 2025.05.19 11:03:47 - Elevated: Command:wfp . 2025.05.19 11:03:47 - Elevated: Command:wfp . 2025.05.19 11:03:47 - Above log line repeated 3 times more . 2025.05.19 11:03:47 - Connection terminated. I 2025.05.19 11:03:50 - Checking authorization ... ! 2025.05.19 11:03:50 - Connecting to Muscida (Netherlands, Alblasserdam) . 2025.05.19 11:03:50 - Elevated: Command:route-list . 2025.05.19 11:03:50 - Elevated: Command:route . 2025.05.19 11:03:51 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add route prefix="213.152.162.156/32" interface="3" nexthop="192.168.0.1" metric=0 store=active', exit:0, out:'Ok.' . 2025.05.19 11:03:51 - Routes, add 213.152.162.156/32 for interface "Ethernet1 2 (vmxnet3 Ethernet Adapter #2)". . 2025.05.19 11:03:51 - Elevated: Command:route-list . 2025.05.19 11:03:51 - Elevated: Command:route . 2025.05.19 11:03:51 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add route prefix="176.9.xx.xx/32" interface="3" nexthop="192.168.0.1" metric=0 store=active', exit:0, out:'Ok.' . 2025.05.19 11:03:51 - Routes, add 176.9.xx.xx/32 for interface "Ethernet1 2 (vmxnet3 Ethernet Adapter #2)". . 2025.05.19 11:03:51 - Elevated: Command:route-list . 2025.05.19 11:03:51 - Elevated: Command:route . 2025.05.19 11:03:51 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add route prefix="74.118.xx.xx/32" interface="3" nexthop="192.168.0.1" metric=0 store=active', exit:0, out:'Ok.' . 2025.05.19 11:03:51 - Routes, add 74.118.xx.xx/32 for interface "Ethernet1 2 (vmxnet3 Ethernet Adapter #2)". . 2025.05.19 11:03:51 - Elevated: Command:route-list . 2025.05.19 11:03:51 - Elevated: Command:route . 2025.05.19 11:03:51 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add route prefix="5.196.xx.xx/32" interface="3" nexthop="192.168.0.1" metric=0 store=active', exit:0, out:'Ok.' . 2025.05.19 11:03:51 - Routes, add 5.196.xx.xx/32 for interface "Ethernet1 2 (vmxnet3 Ethernet Adapter #2)". . 2025.05.19 11:03:51 - Elevated: Command:route-list . 2025.05.19 11:03:51 - Elevated: Command:route . 2025.05.19 11:03:51 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add route prefix="192.168.0.10/32" interface="3" nexthop="192.168.0.1" metric=0 store=active', exit:0, out:'Ok.' . 2025.05.19 11:03:51 - Routes, add 192.168.0.10/32 for interface "Ethernet1 2 (vmxnet3 Ethernet Adapter #2)". . 2025.05.19 11:03:51 - Elevated: Command:wireguard . 2025.05.19 11:03:51 - WireGuard > Setup start . 2025.05.19 11:03:52 - WireGuard > Setup complete . 2025.05.19 11:03:52 - WireGuard > Starting WireGuard/0.5.3 (Windows 10.0.19045; amd64) . 2025.05.19 11:03:52 - WireGuard > Watching network interfaces . 2025.05.19 11:03:52 - WireGuard > Resolving DNS names . 2025.05.19 11:03:52 - WireGuard > Creating network adapter . 2025.05.19 11:03:52 - WireGuard > Using existing driver 0.10 . 2025.05.19 11:03:52 - WireGuard > Creating adapter . 2025.05.19 11:03:52 - WireGuard > Using WireGuardNT/0.10 . 2025.05.19 11:03:52 - WireGuard > Dropping privileges . 2025.05.19 11:03:52 - WireGuard > Setup interface . 2025.05.19 11:03:52 - Elevated: Command:wfp . 2025.05.19 11:03:52 - Elevated: Command:wfp . 2025.05.19 11:03:52 - Elevated: Command:wfp . 2025.05.19 11:03:52 - Above log line repeated 3 times more . 2025.05.19 11:03:52 - WireGuard > Setting interface configuration . 2025.05.19 11:03:52 - WireGuard > Interface created . 2025.05.19 11:03:52 - WireGuard > Peer 1 created . 2025.05.19 11:03:52 - WireGuard > Setting device v4 addresses . 2025.05.19 11:03:52 - WireGuard > Interface up . 2025.05.19 11:03:52 - WireGuard > Received first handshake . 2025.05.19 11:03:52 - Interface Eddie metric changed from Automatic to 3, layer IPv4 . 2025.05.19 11:03:52 - Elevated: Command:set-interface-metric . 2025.05.19 11:03:52 - Interface Eddie metric changed from Automatic to 3, layer IPv6 . 2025.05.19 11:03:52 - Elevated: Command:set-interface-metric . 2025.05.19 11:03:52 - Elevated: Command:wfp . 2025.05.19 11:03:52 - Elevated: Command:wfp . 2025.05.19 11:03:52 - Elevated: Command:wfp . 2025.05.19 11:03:52 - Above log line repeated 3 times more . 2025.05.19 11:03:52 - DNS leak protection with packet filtering enabled. . 2025.05.19 11:03:52 - Elevated: Command:route-list . 2025.05.19 11:03:52 - Elevated: Command:windows-dns . 2025.05.19 11:03:52 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 set dns name="Eddie" source=static address=84.200.69.80 register=primary validate=no', exit:0 . 2025.05.19 11:03:52 - Elevated: Command:windows-dns . 2025.05.19 11:03:52 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add dnsserver name="Eddie" address=84.200.70.40 validate=no', exit:0 . 2025.05.19 11:03:52 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 84.200.69.80,84.200.70.40) . 2025.05.19 11:03:52 - Elevated: Command:windows-dns . 2025.05.19 11:03:52 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 set dns name="Ethernet0 2" source=static address=84.200.69.80 register=primary validate=no', exit:0 . 2025.05.19 11:03:52 - Elevated: Command:windows-dns . 2025.05.19 11:03:52 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add dnsserver name="Ethernet0 2" address=84.200.70.40 validate=no', exit:0 . 2025.05.19 11:03:52 - DNS IPv4 of a network adapter forced (Ethernet0 2, from automatic to 84.200.69.80,84.200.70.40) . 2025.05.19 11:03:52 - Elevated: Command:windows-dns . 2025.05.19 11:03:53 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 set dns name="Ethernet1 2" source=static address=84.200.69.80 register=primary validate=no', exit:0 . 2025.05.19 11:03:53 - Elevated: Command:windows-dns . 2025.05.19 11:03:53 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add dnsserver name="Ethernet1 2" address=84.200.70.40 validate=no', exit:0 . 2025.05.19 11:03:53 - DNS IPv4 of a network adapter forced (Ethernet1 2, from automatic to 84.200.69.80,84.200.70.40) . 2025.05.19 11:03:53 - Elevated: Command:route-list . 2025.05.19 11:03:53 - Elevated: Command:route . 2025.05.19 11:03:53 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add route prefix="0.0.0.0/1" interface="46" metric=0 store=active', exit:0, out:'Ok.' . 2025.05.19 11:03:53 - Routes, add 0.0.0.0/1 for interface "Eddie (WireGuard Tunnel)". . 2025.05.19 11:03:53 - Elevated: Command:route-list . 2025.05.19 11:03:53 - Elevated: Command:route . 2025.05.19 11:03:53 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add route prefix="128.0.0.0/1" interface="46" metric=0 store=active', exit:0, out:'Ok.' . 2025.05.19 11:03:53 - Routes, add 128.0.0.0/1 for interface "Eddie (WireGuard Tunnel)". . 2025.05.19 11:03:53 - Elevated: Command:route-list . 2025.05.19 11:03:53 - Elevated: Command:route . 2025.05.19 11:03:53 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv6 add route prefix="::/1" interface="46" metric=0 store=active', exit:0, out:'Ok.' . 2025.05.19 11:03:53 - Routes, add ::/1 for interface "Eddie (WireGuard Tunnel)". . 2025.05.19 11:03:53 - Elevated: Command:route-list . 2025.05.19 11:03:53 - Elevated: Command:route . 2025.05.19 11:03:53 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv6 add route prefix="8000::/1" interface="46" metric=0 store=active', exit:0, out:'Ok.' . 2025.05.19 11:03:53 - Routes, add 8000::/1 for interface "Eddie (WireGuard Tunnel)". . 2025.05.19 11:03:53 - Elevated: Command:route-list . 2025.05.19 11:03:53 - Elevated: Command:route . 2025.05.19 11:03:53 - Elevated: Exec, path:'C:\WINDOWS\system32\netsh.exe', arg:'interface ipv4 add route prefix="213.152.162.154/32" interface="46" metric=0 store=active', exit:0, out:'Ok.' . 2025.05.19 11:03:53 - Routes, add 213.152.162.154/32 for interface "Eddie (WireGuard Tunnel)". . 2025.05.19 11:03:53 - Elevated: Command:route-list . 2025.05.19 11:03:53 - Routes, add 2a00:1678:2470:5:3568:e603:2b4d:aeb6/128 for interface "Eddie (WireGuard Tunnel)", already exists. . 2025.05.19 11:03:53 - Flushing DNS . 2025.05.19 11:03:53 - Elevated: Command:dns-flush . 2025.05.19 11:03:53 - Elevated: Exec, path:'C:\WINDOWS\system32\ipconfig.exe', arg:'/flushdns', exit:0, out:'Windows IP Configuration . 2025.05.19 11:03:53 - Successfully flushed the DNS Resolver Cache.' . 2025.05.19 11:03:53 - Exec(1136) of 'C:\WINDOWS\system32\ipconfig.exe', 1 args: '/flushdns'; . 2025.05.19 11:03:53 - Exec(1136) done in 32 ms, exit: 0, out: 'Windows IP Configuration . 2025.05.19 11:03:53 - Successfully flushed the DNS Resolver Cache.' I 2025.05.19 11:03:53 - Checking route IPv4 I 2025.05.19 11:03:54 - Checking route IPv6 . 2025.05.19 11:03:54 - Collect network information . 2025.05.19 11:03:54 - Elevated: Command:route-list ! 2025.05.19 11:03:54 - Connected. . 2025.05.19 11:03:54 - WireGuard > Invalid handshake response from 213.152.162.156:1637 . 2025.05.19 11:03:54 - WireGuard > Setting device v6 addresses . 2025.05.19 11:03:54 - WireGuard > Startup complete . 2025.05.19 11:03:54 - WireGuard > Packet has invalid nonce 0 (max 1) . 2025.05.19 11:03:54 - WireGuard > Packet has invalid nonce 1 (max 2) . 2025.05.19 11:03:54 - WireGuard > Packet has invalid nonce 2 (max 3) . 2025.05.19 11:03:54 - WireGuard > Packet has invalid nonce 3 (max 4) . 2025.05.19 11:03:54 - WireGuard > Packet has invalid nonce 4 (max 5) . 2025.05.19 11:03:54 - WireGuard > Packet has invalid nonce 5 (max 6) . 2025.05.19 11:03:57 - WireGuard > 13456 log lines swallowed by rate limiting . 2025.05.19 11:03:57 - WireGuard > Packet has invalid nonce 13821 (max 13828) . 2025.05.19 11:03:57 - WireGuard > Packet has invalid nonce 13822 (max 13828) . 2025.05.19 11:03:57 - WireGuard > Packet has invalid nonce 13823 (max 13828) . 2025.05.19 11:03:57 - WireGuard > Packet has invalid nonce 13824 (max 13828) . 2025.05.19 11:03:57 - WireGuard > Packet has invalid nonce 13825 (max 13828) . 2025.05.19 11:03:57 - WireGuard > Packet has invalid nonce 13826 (max 13828) . 2025.05.19 11:03:57 - WireGuard > Packet has invalid nonce 13827 (max 13828) . 2025.05.19 11:03:57 - WireGuard > Packet has invalid nonce 13828 (max 13832) . 2025.05.19 11:03:57 - WireGuard > Packet has invalid nonce 13829 (max 13832) . 2025.05.19 11:03:57 - WireGuard > Packet has invalid nonce 13830 (max 13832) . 2025.05.19 11:03:57 - WireGuard > Packet has invalid nonce 13831 (max 13832) . 2025.05.19 11:04:02 - WireGuard > 43418 log lines swallowed by rate limiting . 2025.05.19 11:04:02 - WireGuard > Packet has invalid nonce 57480 (max 57481) . 2025.05.19 11:04:02 - WireGuard > Packet has invalid nonce 57481 (max 57482) . 2025.05.19 11:04:02 - WireGuard > Packet has invalid nonce 57482 (max 57486) . 2025.05.19 11:04:02 - WireGuard > Packet has invalid nonce 57483 (max 57486) . 2025.05.19 11:04:02 - WireGuard > Packet has invalid nonce 57484 (max 57486) . 2025.05.19 11:04:02 - WireGuard > Packet has invalid nonce 57485 (max 57486) . 2025.05.19 11:04:02 - WireGuard > Packet has invalid nonce 57486 (max 57489) . 2025.05.19 11:04:02 - WireGuard > Packet has invalid nonce 57487 (max 57489) . 2025.05.19 11:04:02 - WireGuard > Packet has invalid nonce 57488 (max 57489) . 2025.05.19 11:04:02 - WireGuard > Packet has invalid nonce 57489 (max 57491) . 2025.05.19 11:04:02 - WireGuard > Packet has invalid nonce 57490 (max 57491) . 2025.05.19 11:04:07 - WireGuard > 48052 log lines swallowed by rate limiting . 2025.05.19 11:04:07 - WireGuard > Packet has invalid nonce 107647 (max 107653) . 2025.05.19 11:04:07 - WireGuard > Packet has invalid nonce 107648 (max 107653) . 2025.05.19 11:04:07 - WireGuard > Packet has invalid nonce 107649 (max 107653) . 2025.05.19 11:04:07 - WireGuard > Packet has invalid nonce 107650 (max 107653) . 2025.05.19 11:04:07 - WireGuard > Packet has invalid nonce 107651 (max 107653) . 2025.05.19 11:04:07 - WireGuard > Packet has invalid nonce 107652 (max 107653) . 2025.05.19 11:04:07 - WireGuard > Packet has invalid nonce 107653 (max 107656) . 2025.05.19 11:04:07 - WireGuard > Packet has invalid nonce 107654 (max 107656) . 2025.05.19 11:04:07 - WireGuard > Packet has invalid nonce 107655 (max 107656) . 2025.05.19 11:04:07 - WireGuard > Packet has invalid nonce 107656 (max 107657) . 2025.05.19 11:04:07 - WireGuard > Packet has invalid nonce 107657 (max 107662) . 2025.05.19 11:04:12 - WireGuard > 45929 log lines swallowed by rate limiting . 2025.05.19 11:04:12 - WireGuard > Packet has invalid nonce 158614 (max 158617) . 2025.05.19 11:04:12 - WireGuard > Packet has invalid nonce 158615 (max 158617) . 2025.05.19 11:04:12 - WireGuard > Packet has invalid nonce 158616 (max 158617) . 2025.05.19 11:04:12 - WireGuard > Packet has invalid nonce 158617 (max 158621) . 2025.05.19 11:04:12 - WireGuard > Packet has invalid nonce 158618 (max 158621) . 2025.05.19 11:04:12 - WireGuard > Packet has invalid nonce 158619 (max 158621) . 2025.05.19 11:04:12 - WireGuard > Packet has invalid nonce 158620 (max 158621) . 2025.05.19 11:04:12 - WireGuard > Packet has invalid nonce 158621 (max 158626) . 2025.05.19 11:04:12 - WireGuard > Packet has invalid nonce 158622 (max 158626) . 2025.05.19 11:04:12 - WireGuard > Packet has invalid nonce 158623 (max 158626) . 2025.05.19 11:04:12 - WireGuard > Packet has invalid nonce 158624 (max 158626) . 2025.05.19 11:04:17 - WireGuard > 46086 log lines swallowed by rate limiting . 2025.05.19 11:04:17 - WireGuard > Packet has invalid nonce 210542 (max 210547) . 2025.05.19 11:04:17 - WireGuard > Packet has invalid nonce 210543 (max 210547) . 2025.05.19 11:04:17 - WireGuard > Packet has invalid nonce 210545 (max 210547) . 2025.05.19 11:04:17 - WireGuard > Packet has invalid nonce 210546 (max 210547) . 2025.05.19 11:04:17 - WireGuard > Packet has invalid nonce 210547 (max 210560) . 2025.05.19 11:04:17 - WireGuard > Packet has invalid nonce 210548 (max 210560) . 2025.05.19 11:04:17 - WireGuard > Packet has invalid nonce 210550 (max 210560) . 2025.05.19 11:04:17 - WireGuard > Packet has invalid nonce 210556 (max 210560) . 2025.05.19 11:04:17 - WireGuard > Packet has invalid nonce 210559 (max 210560) . 2025.05.19 11:04:17 - WireGuard > Packet has invalid nonce 210560 (max 210563) . 2025.05.19 11:04:17 - WireGuard > Packet has invalid nonce 210561 (max 210563) . 2025.05.19 11:04:22 - WireGuard > 44995 log lines swallowed by rate limiting . 2025.05.19 11:04:22 - WireGuard > Packet has invalid nonce 260656 (max 260660) . 2025.05.19 11:04:22 - WireGuard > Packet has invalid nonce 260657 (max 260660) . 2025.05.19 11:04:22 - WireGuard > Packet has invalid nonce 260658 (max 260660) . 2025.05.19 11:04:22 - WireGuard > Packet has invalid nonce 260659 (max 260660) . 2025.05.19 11:04:22 - WireGuard > Packet has invalid nonce 260660 (max 260661) . 2025.05.19 11:04:22 - WireGuard > Packet has invalid nonce 260661 (max 260665) . 2025.05.19 11:04:22 - WireGuard > Packet has invalid nonce 260662 (max 260665) . 2025.05.19 11:04:22 - WireGuard > Packet has invalid nonce 260663 (max 260665) . 2025.05.19 11:04:22 - WireGuard > Packet has invalid nonce 260664 (max 260665) . 2025.05.19 11:04:22 - WireGuard > Packet has invalid nonce 260665 (max 260667) . 2025.05.19 11:04:22 - WireGuard > Packet has invalid nonce 260666 (max 260667) . 2025.05.19 11:04:27 - WireGuard > 45982 log lines swallowed by rate limiting . 2025.05.19 11:04:27 - WireGuard > Packet has invalid nonce 308747 (max 308748) . 2025.05.19 11:04:27 - WireGuard > Packet has invalid nonce 308748 (max 308750) . 2025.05.19 11:04:27 - WireGuard > Packet has invalid nonce 308749 (max 308750) . 2025.05.19 11:04:27 - WireGuard > Packet has invalid nonce 308750 (max 308751) . 2025.05.19 11:04:27 - WireGuard > Packet has invalid nonce 308751 (max 308752) . 2025.05.19 11:04:27 - WireGuard > Packet has invalid nonce 308752 (max 308753) . 2025.05.19 11:04:27 - WireGuard > Packet has invalid nonce 308753 (max 308756) . 2025.05.19 11:04:27 - WireGuard > Packet has invalid nonce 308754 (max 308756) . 2025.05.19 11:04:27 - WireGuard > Packet has invalid nonce 308755 (max 308756) . 2025.05.19 11:04:27 - WireGuard > Packet has invalid nonce 308756 (max 308757) . 2025.05.19 11:04:27 - WireGuard > Packet has invalid nonce 308757 (max 308759) . 2025.05.19 11:04:32 - WireGuard > 50270 log lines swallowed by rate limiting . 2025.05.19 11:04:32 - WireGuard > Packet has invalid nonce 361060 (max 361063) . 2025.05.19 11:04:32 - WireGuard > Packet has invalid nonce 361061 (max 361063) . 2025.05.19 11:04:32 - WireGuard > Packet has invalid nonce 361062 (max 361063) . 2025.05.19 11:04:32 - WireGuard > Packet has invalid nonce 361063 (max 361068) . 2025.05.19 11:04:32 - WireGuard > Packet has invalid nonce 361064 (max 361068) . 2025.05.19 11:04:32 - WireGuard > Packet has invalid nonce 361065 (max 361068) . 2025.05.19 11:04:32 - WireGuard > Packet has invalid nonce 361066 (max 361068) . 2025.05.19 11:04:32 - WireGuard > Packet has invalid nonce 361067 (max 361068) . 2025.05.19 11:04:32 - WireGuard > Packet has invalid nonce 361068 (max 361069) . 2025.05.19 11:04:32 - WireGuard > Packet has invalid nonce 361070 (max 361074) . 2025.05.19 11:04:32 - WireGuard > Packet has invalid nonce 361069 (max 361074) . 2025.05.19 11:04:37 - WireGuard > 47544 log lines swallowed by rate limiting . 2025.05.19 11:04:37 - WireGuard > Packet has invalid nonce 409820 (max 409830) . 2025.05.19 11:04:37 - WireGuard > Packet has invalid nonce 409821 (max 409830) . 2025.05.19 11:04:37 - WireGuard > Packet has invalid nonce 409822 (max 409830) . 2025.05.19 11:04:37 - WireGuard > Packet has invalid nonce 409823 (max 409830) . 2025.05.19 11:04:37 - WireGuard > Packet has invalid nonce 409824 (max 409830) . 2025.05.19 11:04:37 - WireGuard > Packet has invalid nonce 409825 (max 409830) . 2025.05.19 11:04:37 - WireGuard > Packet has invalid nonce 409826 (max 409830) . 2025.05.19 11:04:37 - WireGuard > Packet has invalid nonce 409827 (max 409830) . 2025.05.19 11:04:37 - WireGuard > Packet has invalid nonce 409828 (max 409830) . 2025.05.19 11:04:37 - WireGuard > Packet has invalid nonce 409829 (max 409830) . 2025.05.19 11:04:37 - WireGuard > Packet has invalid nonce 409830 (max 409831) . 2025.05.19 11:04:42 - WireGuard > 51528 log lines swallowed by rate limiting . 2025.05.19 11:04:42 - WireGuard > Packet has invalid nonce 463789 (max 463791) . 2025.05.19 11:04:42 - WireGuard > Packet has invalid nonce 463790 (max 463791) . 2025.05.19 11:04:42 - WireGuard > Packet has invalid nonce 463791 (max 463793) . 2025.05.19 11:04:42 - WireGuard > Packet has invalid nonce 463792 (max 463793) . 2025.05.19 11:04:42 - WireGuard > Packet has invalid nonce 463793 (max 463794) . 2025.05.19 11:04:42 - WireGuard > Packet has invalid nonce 463795 (max 463796) . 2025.05.19 11:04:42 - WireGuard > Packet has invalid nonce 463794 (max 463796) . 2025.05.19 11:04:42 - WireGuard > Packet has invalid nonce 463796 (max 463800) . 2025.05.19 11:04:42 - WireGuard > Packet has invalid nonce 463797 (max 463800) . 2025.05.19 11:04:42 - WireGuard > Packet has invalid nonce 463798 (max 463800) . 2025.05.19 11:04:42 - WireGuard > Packet has invalid nonce 463799 (max 463800) . 2025.05.19 11:04:47 - WireGuard > 45308 log lines swallowed by rate limiting . 2025.05.19 11:04:47 - WireGuard > Packet has invalid nonce 510792 (max 510802) . 2025.05.19 11:04:47 - WireGuard > Packet has invalid nonce 510793 (max 510802) . 2025.05.19 11:04:47 - WireGuard > Packet has invalid nonce 510794 (max 510802) . 2025.05.19 11:04:47 - WireGuard > Packet has invalid nonce 510795 (max 510802) . 2025.05.19 11:04:47 - WireGuard > Packet has invalid nonce 510796 (max 510802) . 2025.05.19 11:04:47 - WireGuard > Packet has invalid nonce 510797 (max 510802) . 2025.05.19 11:04:47 - WireGuard > Packet has invalid nonce 510798 (max 510802) . 2025.05.19 11:04:47 - WireGuard > Packet has invalid nonce 510799 (max 510802) . 2025.05.19 11:04:47 - WireGuard > Packet has invalid nonce 510800 (max 510802) . 2025.05.19 11:04:47 - WireGuard > Packet has invalid nonce 510801 (max 510802) . 2025.05.19 11:04:47 - WireGuard > Packet has invalid nonce 510802 (max 510812) . 2025.05.19 11:04:52 - WireGuard > 46040 log lines swallowed by rate limiting . 2025.05.19 11:04:52 - WireGuard > Packet has invalid nonce 559166 (max 559171) . 2025.05.19 11:04:52 - WireGuard > Packet has invalid nonce 559167 (max 559171) . 2025.05.19 11:04:52 - WireGuard > Packet has invalid nonce 559168 (max 559171) . 2025.05.19 11:04:52 - WireGuard > Packet has invalid nonce 559169 (max 559171) . 2025.05.19 11:04:52 - WireGuard > Packet has invalid nonce 559170 (max 559171) . 2025.05.19 11:04:52 - WireGuard > Packet has invalid nonce 559171 (max 559172) . 2025.05.19 11:04:52 - WireGuard > Packet has invalid nonce 559172 (max 559178) . 2025.05.19 11:04:52 - WireGuard > Packet has invalid nonce 559173 (max 559178) . 2025.05.19 11:04:52 - WireGuard > Packet has invalid nonce 559174 (max 559178) . 2025.05.19 11:04:52 - WireGuard > Packet has invalid nonce 559175 (max 559178) . 2025.05.19 11:04:52 - WireGuard > Packet has invalid nonce 559176 (max 559178) . 2025.05.19 11:04:57 - WireGuard > 48409 log lines swallowed by rate limiting . 2025.05.19 11:04:57 - WireGuard > Packet has invalid nonce 610343 (max 610348) . 2025.05.19 11:04:57 - WireGuard > Packet has invalid nonce 610344 (max 610348) . 2025.05.19 11:04:57 - WireGuard > Packet has invalid nonce 610347 (max 610348) . 2025.05.19 11:04:57 - WireGuard > Packet has invalid nonce 610346 (max 610348) . 2025.05.19 11:04:57 - WireGuard > Packet has invalid nonce 610349 (max 610351) . 2025.05.19 11:04:57 - WireGuard > Packet has invalid nonce 610350 (max 610351) . 2025.05.19 11:04:57 - WireGuard > Packet has invalid nonce 610351 (max 610356) . 2025.05.19 11:04:57 - WireGuard > Packet has invalid nonce 610352 (max 610356) . 2025.05.19 11:04:57 - WireGuard > Packet has invalid nonce 610353 (max 610356) . 2025.05.19 11:04:57 - WireGuard > Packet has invalid nonce 610354 (max 610356) . 2025.05.19 11:04:57 - WireGuard > Packet has invalid nonce 610355 (max 610356) . 2025.05.19 11:05:02 - WireGuard > 46271 log lines swallowed by rate limiting . 2025.05.19 11:05:02 - WireGuard > Packet has invalid nonce 659637 (max 659639) . 2025.05.19 11:05:02 - WireGuard > Packet has invalid nonce 659638 (max 659639) . 2025.05.19 11:05:02 - WireGuard > Packet has invalid nonce 659639 (max 659646) . 2025.05.19 11:05:02 - WireGuard > Packet has invalid nonce 659640 (max 659646) . 2025.05.19 11:05:02 - WireGuard > Packet has invalid nonce 659641 (max 659646) . 2025.05.19 11:05:02 - WireGuard > Packet has invalid nonce 659642 (max 659646) . 2025.05.19 11:05:02 - WireGuard > Packet has invalid nonce 659643 (max 659646) . 2025.05.19 11:05:02 - WireGuard > Packet has invalid nonce 659645 (max 659646) . 2025.05.19 11:05:02 - WireGuard > Packet has invalid nonce 659644 (max 659647) . 2025.05.19 11:05:02 - WireGuard > Packet has invalid nonce 659646 (max 659647) . 2025.05.19 11:05:02 - WireGuard > Packet has invalid nonce 659650 (max 659651) . 2025.05.19 11:05:07 - WireGuard > 49957 log lines swallowed by rate limiting . 2025.05.19 11:05:07 - WireGuard > Packet has invalid nonce 711887 (max 711892) . 2025.05.19 11:05:07 - WireGuard > Packet has invalid nonce 711888 (max 711892) . 2025.05.19 11:05:07 - WireGuard > Packet has invalid nonce 711889 (max 711892) . 2025.05.19 11:05:07 - WireGuard > Packet has invalid nonce 711890 (max 711892) . 2025.05.19 11:05:07 - WireGuard > Packet has invalid nonce 711891 (max 711892) . 2025.05.19 11:05:07 - WireGuard > Packet has invalid nonce 711892 (max 711893) . 2025.05.19 11:05:07 - WireGuard > Packet has invalid nonce 711893 (max 711895) . 2025.05.19 11:05:07 - WireGuard > Packet has invalid nonce 711894 (max 711895) . 2025.05.19 11:05:07 - WireGuard > Packet has invalid nonce 711895 (max 711900) . 2025.05.19 11:05:07 - WireGuard > Packet has invalid nonce 711896 (max 711900) . 2025.05.19 11:05:07 - WireGuard > Packet has invalid nonce 711897 (max 711900) . 2025.05.19 11:05:12 - WireGuard > 49246 log lines swallowed by rate limiting . 2025.05.19 11:05:12 - WireGuard > Packet has invalid nonce 764286 (max 764288) . 2025.05.19 11:05:12 - WireGuard > Packet has invalid nonce 764287 (max 764288) . 2025.05.19 11:05:12 - WireGuard > Packet has invalid nonce 764288 (max 764289) . 2025.05.19 11:05:12 - WireGuard > Packet has invalid nonce 764289 (max 764290) . 2025.05.19 11:05:12 - WireGuard > Packet has invalid nonce 764290 (max 764293) . 2025.05.19 11:05:12 - WireGuard > Packet has invalid nonce 764291 (max 764293) . 2025.05.19 11:05:12 - WireGuard > Packet has invalid nonce 764292 (max 764293) . 2025.05.19 11:05:12 - WireGuard > Packet has invalid nonce 764293 (max 764294) . 2025.05.19 11:05:12 - WireGuard > Packet has invalid nonce 764294 (max 764295) . 2025.05.19 11:05:12 - WireGuard > Packet has invalid nonce 764295 (max 764296) . 2025.05.19 11:05:12 - WireGuard > Packet has invalid nonce 764296 (max 764297) . 2025.05.19 11:05:17 - WireGuard > 49641 log lines swallowed by rate limiting . 2025.05.19 11:05:17 - WireGuard > Packet has invalid nonce 816297 (max 816300) . 2025.05.19 11:05:17 - WireGuard > Packet has invalid nonce 816298 (max 816300) . 2025.05.19 11:05:17 - WireGuard > Packet has invalid nonce 816299 (max 816300) . 2025.05.19 11:05:17 - WireGuard > Packet has invalid nonce 816300 (max 816302) . 2025.05.19 11:05:17 - WireGuard > Packet has invalid nonce 816301 (max 816302) . 2025.05.19 11:05:17 - WireGuard > Packet has invalid nonce 816302 (max 816305) . 2025.05.19 11:05:17 - WireGuard > Packet has invalid nonce 816303 (max 816305) . 2025.05.19 11:05:17 - WireGuard > Packet has invalid nonce 816304 (max 816305) . 2025.05.19 11:05:17 - WireGuard > Packet has invalid nonce 816306 (max 816307) . 2025.05.19 11:05:17 - WireGuard > Packet has invalid nonce 816307 (max 816308) . 2025.05.19 11:05:17 - WireGuard > Packet has invalid nonce 816308 (max 816311) ---------------------------- Network Info: { "routes": [ { "destination": "0.0.0.0\/0", "gateway": "192.168.0.1", "interface_index": 3, "metric": 0, "interface": "{0909970E-3991-4E60-A22E-C2F1A14DEECF}" }, { "destination": "0.0.0.0\/0", "gateway": "192.168.65.2", "interface_index": 22, "metric": 0, "interface": "{F95E031C-21BA-498B-A458-063C699B9E78}" }, { "destination": "0.0.0.0\/1", "gateway": "0.0.0.0", "interface_index": 46, "metric": 0, "interface": "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}" }, { "destination": "5.196.xx.xx\/32", "gateway": "192.168.0.1", "interface_index": 3, "metric": 0, "interface": "{0909970E-3991-4E60-A22E-C2F1A14DEECF}" }, { "destination": "10.191.25.51\/32", "gateway": "0.0.0.0", "interface_index": 46, "metric": 256, "interface": "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}" }, { "destination": "74.118.xx.xx\/32", "gateway": "192.168.0.1", "interface_index": 3, "metric": 0, "interface": "{0909970E-3991-4E60-A22E-C2F1A14DEECF}" }, { "destination": "127.0.0.0\/8", "gateway": "0.0.0.0", "interface_index": 1, "metric": 256, "interface": "{6369AE9F-BA74-11E7-8C05-806E6F6E6963}" }, { "destination": "127.0.0.1\/32", "gateway": "0.0.0.0", "interface_index": 1, "metric": 256, "interface": "{6369AE9F-BA74-11E7-8C05-806E6F6E6963}" }, { "destination": "127.255.255.255\/32", "gateway": "0.0.0.0", "interface_index": 1, "metric": 256, "interface": "{6369AE9F-BA74-11E7-8C05-806E6F6E6963}" }, { "destination": "127.255.255.255\/32", "gateway": "0.0.0.0", "interface_index": 46, "metric": 256, "interface": "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}" }, { "destination": "128.0.0.0\/1", "gateway": "0.0.0.0", "interface_index": 46, "metric": 0, "interface": "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}" }, { "destination": "176.9.xx.xx\/32", "gateway": "192.168.0.1", "interface_index": 3, "metric": 0, "interface": "{0909970E-3991-4E60-A22E-C2F1A14DEECF}" }, { "destination": "192.168.0.0\/24", "gateway": "0.0.0.0", "interface_index": 3, "metric": 256, "interface": "{0909970E-3991-4E60-A22E-C2F1A14DEECF}" }, { "destination": "192.168.0.10\/32", "gateway": "192.168.0.1", "interface_index": 3, "metric": 0, "interface": "{0909970E-3991-4E60-A22E-C2F1A14DEECF}" }, { "destination": "192.168.0.110\/32", "gateway": "0.0.0.0", "interface_index": 3, "metric": 256, "interface": "{0909970E-3991-4E60-A22E-C2F1A14DEECF}" }, { "destination": "192.168.0.255\/32", "gateway": "0.0.0.0", "interface_index": 3, "metric": 256, "interface": "{0909970E-3991-4E60-A22E-C2F1A14DEECF}" }, { "destination": "192.168.65.0\/24", "gateway": "0.0.0.0", "interface_index": 22, "metric": 256, "interface": "{F95E031C-21BA-498B-A458-063C699B9E78}" }, { "destination": "192.168.65.132\/32", "gateway": "0.0.0.0", "interface_index": 22, "metric": 256, "interface": "{F95E031C-21BA-498B-A458-063C699B9E78}" }, { "destination": "192.168.65.255\/32", "gateway": "0.0.0.0", "interface_index": 22, "metric": 256, "interface": "{F95E031C-21BA-498B-A458-063C699B9E78}" }, { "destination": "213.152.162.154\/32", "gateway": "0.0.0.0", "interface_index": 46, "metric": 0, "interface": "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}" }, { "destination": "213.152.162.156\/32", "gateway": "192.168.0.1", "interface_index": 3, "metric": 0, "interface": "{0909970E-3991-4E60-A22E-C2F1A14DEECF}" }, { "destination": "224.0.0.0\/4", "gateway": "0.0.0.0", "interface_index": 1, "metric": 256, "interface": "{6369AE9F-BA74-11E7-8C05-806E6F6E6963}" }, { "destination": "224.0.0.0\/4", "gateway": "0.0.0.0", "interface_index": 20, "metric": 256, "interface": "{E83A5875-9A6E-42EF-A401-B6A0B82BEA39}" }, { "destination": "224.0.0.0\/4", "gateway": "0.0.0.0", "interface_index": 3, "metric": 256, "interface": "{0909970E-3991-4E60-A22E-C2F1A14DEECF}" }, { "destination": "224.0.0.0\/4", "gateway": "0.0.0.0", "interface_index": 22, "metric": 256, "interface": "{F95E031C-21BA-498B-A458-063C699B9E78}" }, { "destination": "224.0.0.0\/4", "gateway": "0.0.0.0", "interface_index": 10, "metric": 256, "interface": "{4E6C1D82-D9A2-472B-A24F-896C7EA88124}" }, { "destination": "224.0.0.0\/4", "gateway": "0.0.0.0", "interface_index": 46, "metric": 256, "interface": "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}" }, { "destination": "255.255.255.255\/32", "gateway": "0.0.0.0", "interface_index": 1, "metric": 256, "interface": "{6369AE9F-BA74-11E7-8C05-806E6F6E6963}" }, { "destination": "255.255.255.255\/32", "gateway": "0.0.0.0", "interface_index": 20, "metric": 256, "interface": "{E83A5875-9A6E-42EF-A401-B6A0B82BEA39}" }, { "destination": "255.255.255.255\/32", "gateway": "0.0.0.0", "interface_index": 3, "metric": 256, "interface": "{0909970E-3991-4E60-A22E-C2F1A14DEECF}" }, { "destination": "255.255.255.255\/32", "gateway": "0.0.0.0", "interface_index": 22, "metric": 256, "interface": "{F95E031C-21BA-498B-A458-063C699B9E78}" }, { "destination": "255.255.255.255\/32", "gateway": "0.0.0.0", "interface_index": 10, "metric": 256, "interface": "{4E6C1D82-D9A2-472B-A24F-896C7EA88124}" }, { "destination": "255.255.255.255\/32", "gateway": "0.0.0.0", "interface_index": 46, "metric": 256, "interface": "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}" }, { "destination": "::\/1", "gateway": "::", "interface_index": 46, "metric": 0, "interface": "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}" }, { "destination": "::1\/128", "gateway": "::", "interface_index": 1, "metric": 256, "interface": "{6369AE9F-BA74-11E7-8C05-806E6F6E6963}" }, { "destination": "2a00:1678:1337:7a23:1a11:385:cef5:8d8d\/128", "gateway": "fde6:7a:7d20:a0a::1", "interface_index": 10, "metric": 256, "interface": "{4E6C1D82-D9A2-472B-A24F-896C7EA88124}" }, { "destination": "2a00:1678:1337:7a23:1a11:385:cef5:8d8d\/128", "gateway": "fde6:7a:7d20:a1a::1", "interface_index": 10, "metric": 256, "interface": "{4E6C1D82-D9A2-472B-A24F-896C7EA88124}" }, { "destination": "2a00:1678:2470:5:3568:e603:2b4d:aeb6\/128", "gateway": "fde6:7a:7d20:149e::1", "interface_index": 10, "metric": 256, "interface": "{4E6C1D82-D9A2-472B-A24F-896C7EA88124}" }, { "destination": "2a00:1678:2470:5:3568:e603:2b4d:aeb6\/128", "gateway": "fde6:7a:7d20:1496::1", "interface_index": 10, "metric": 256, "interface": "{4E6C1D82-D9A2-472B-A24F-896C7EA88124}" }, { "destination": "8000::\/1", "gateway": "::", "interface_index": 46, "metric": 0, "interface": "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}" }, { "destination": "fd7d:76ee:e68f:a993:16ef:c15e:b9e:d6a3\/128", "gateway": "::", "interface_index": 46, "metric": 256, "interface": "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}" }, { "destination": "fe80::\/64", "gateway": "::", "interface_index": 20, "metric": 256, "interface": "{E83A5875-9A6E-42EF-A401-B6A0B82BEA39}" }, { "destination": "fe80::\/64", "gateway": "::", "interface_index": 3, "metric": 256, "interface": "{0909970E-3991-4E60-A22E-C2F1A14DEECF}" }, { "destination": "fe80::\/64", "gateway": "::", "interface_index": 22, "metric": 256, "interface": "{F95E031C-21BA-498B-A458-063C699B9E78}" }, { "destination": "fe80::\/64", "gateway": "::", "interface_index": 10, "metric": 256, "interface": "{4E6C1D82-D9A2-472B-A24F-896C7EA88124}" }, { "destination": "fe80::7ccf:9304:5368:3429\/128", "gateway": "::", "interface_index": 22, "metric": 256, "interface": "{F95E031C-21BA-498B-A458-063C699B9E78}" }, { "destination": "fe80::88fc:c58b:6683:32f9\/128", "gateway": "::", "interface_index": 20, "metric": 256, "interface": "{E83A5875-9A6E-42EF-A401-B6A0B82BEA39}" }, { "destination": "fe80::ce65:f597:2d9d:9b97\/128", "gateway": "::", "interface_index": 10, "metric": 256, "interface": "{4E6C1D82-D9A2-472B-A24F-896C7EA88124}" }, { "destination": "fe80::ed18:875c:653f:9651\/128", "gateway": "::", "interface_index": 3, "metric": 256, "interface": "{0909970E-3991-4E60-A22E-C2F1A14DEECF}" }, { "destination": "ff00::\/8", "gateway": "::", "interface_index": 1, "metric": 256, "interface": "{6369AE9F-BA74-11E7-8C05-806E6F6E6963}" }, { "destination": "ff00::\/8", "gateway": "::", "interface_index": 20, "metric": 256, "interface": "{E83A5875-9A6E-42EF-A401-B6A0B82BEA39}" }, { "destination": "ff00::\/8", "gateway": "::", "interface_index": 3, "metric": 256, "interface": "{0909970E-3991-4E60-A22E-C2F1A14DEECF}" }, { "destination": "ff00::\/8", "gateway": "::", "interface_index": 22, "metric": 256, "interface": "{F95E031C-21BA-498B-A458-063C699B9E78}" }, { "destination": "ff00::\/8", "gateway": "::", "interface_index": 10, "metric": 256, "interface": "{4E6C1D82-D9A2-472B-A24F-896C7EA88124}" }, { "destination": "ff00::\/8", "gateway": "::", "interface_index": 46, "metric": 256, "interface": "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}" } ], "ipv4-default-gateway": "192.168.0.1", "ipv4-default-interface": "{0909970E-3991-4E60-A22E-C2F1A14DEECF}", "interfaces": [ { "friendly": "Eddie", "id": "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", "name": "Eddie", "description": "WireGuard Tunnel", "type": "Virtual", "status": "Up", "bytes_received": "774487120", "bytes_sent": "37905472", "support_ipv4": true, "support_ipv6": true, "ips": [ "fd7d:76ee:e68f:a993:16ef:c15e:b9e:d6a3", "10.191.25.51" ], "bind": true, "dns4": "84.200.69.80,84.200.70.40", "dns6": "", "device_id": "WireGuard" }, { "friendly": "Eddie 1", "id": "{E83A5875-9A6E-42EF-A401-B6A0B82BEA39}", "name": "Eddie 1", "description": "Eddie Tunnel", "type": "Virtual", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::88fc:c58b:6683:32f9", "169.254.163.15" ], "bind": true, "dns4": "", "dns6": "", "device_id": "wintun" }, { "friendly": "Ethernet0 2", "id": "{F95E031C-21BA-498B-A458-063C699B9E78}", "name": "Ethernet0 2", "description": "vmxnet3 Ethernet Adapter", "type": "Ethernet", "status": "Up", "bytes_received": "16062839", "bytes_sent": "11397552", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::7ccf:9304:5368:3429", "192.168.65.132" ], "bind": true, "dns4": "84.200.69.80,84.200.70.40", "dns6": "", "device_id": "PCI\\VEN_15AD&DEV_07B0" }, { "friendly": "Ethernet1 2", "id": "{0909970E-3991-4E60-A22E-C2F1A14DEECF}", "name": "Ethernet1 2", "description": "vmxnet3 Ethernet Adapter #2", "type": "Ethernet", "status": "Up", "bytes_received": "246936126712", "bytes_sent": "69272470232", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::ed18:875c:653f:9651", "192.168.0.110" ], "bind": true, "dns4": "84.200.69.80,84.200.70.40", "dns6": "", "device_id": "PCI\\VEN_15AD&DEV_07B0" }, { "friendly": "Local Area Connection", "id": "{4E6C1D82-D9A2-472B-A24F-896C7EA88124}", "name": "Local Area Connection", "description": "TAP-Windows Adapter V9", "type": "Virtual", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::ce65:f597:2d9d:9b97", "169.254.82.42" ], "bind": true, "dns4": "84.200.69.80,84.200.70.40", "dns6": "fde6:7a:7d20:1496::1", "device_id": "tap0901" }, { "friendly": "Loopback Pseudo-Interface 1", "id": "{6369AE9F-BA74-11E7-8C05-806E6F6E6963}", "name": "Loopback Pseudo-Interface 1", "description": "Software Loopback Interface 1", "type": "Loopback", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "::1", "127.0.0.1" ], "bind": true, "dns4": "", "dns6": null } ] } ---------------------------- ovpn-dco version: wintun version: Automatic tap-windows6 version: ---------------------------- ipconfig /all: Windows IP Configuration Host Name . . . . . . . . . . . . : xxx Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : localdomain Unknown adapter Eddie: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : WireGuard Tunnel Physical Address. . . . . . . . . : DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes IPv6 Address. . . . . . . . . . . : fd7d:76ee:e68f:a993:16ef:c15e:b9e:d6a3(Preferred) IPv4 Address. . . . . . . . . . . : 10.191.25.51(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.255 Default Gateway . . . . . . . . . : DNS Servers . . . . . . . . . . . : 84.200.69.80 84.200.70.40 NetBIOS over Tcpip. . . . . . . . : Enabled Unknown adapter Eddie 1: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Eddie Tunnel Physical Address. . . . . . . . . : DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Ethernet adapter Ethernet0 2: Connection-specific DNS Suffix . : localdomain Description . . . . . . . . . . . : vmxnet3 Ethernet Adapter Physical Address. . . . . . . . . : 00-0C-29-26-47-D6 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::7ccf:9304:5368:3429%22(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.65.132(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : vrijdag 16 mei 2025 11:34:01 Lease Expires . . . . . . . . . . : maandag 19 mei 2025 11:20:42 Default Gateway . . . . . . . . . : 192.168.65.2 DHCP Server . . . . . . . . . . . : 192.168.65.254 DHCPv6 IAID . . . . . . . . . . . : 603982889 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-2A-B1-06-D2-00-0C-29-26-47-D6 DNS Servers . . . . . . . . . . . : 84.200.69.80 84.200.70.40 Primary WINS Server . . . . . . . : 192.168.65.2 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter Ethernet1 2: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : vmxnet3 Ethernet Adapter #2 Physical Address. . . . . . . . . : 00-0C-29-26-47-E0 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::ed18:875c:653f:9651%3(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.0.110(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : donderdag 15 mei 2025 8:10:35 Lease Expires . . . . . . . . . . : dinsdag 20 mei 2025 10:59:48 Default Gateway . . . . . . . . . : 192.168.0.1 DHCP Server . . . . . . . . . . . : 192.168.0.1 DHCPv6 IAID . . . . . . . . . . . : 620760105 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-2A-B1-06-D2-00-0C-29-26-47-D6 DNS Servers . . . . . . . . . . . : 84.200.69.80 84.200.70.40 NetBIOS over Tcpip. . . . . . . . : Enabled Unknown adapter Local Area Connection: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : TAP-Windows Adapter V9 Physical Address. . . . . . . . . : 00-FF-4E-6C-1D-82 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes . Edited ... by OpenSourcerer Switch system report format from code to LOG Quote Share this post Link to post
Tech Jedi Alex 1531 Posted ... This looks similar.. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
